1994 CBR600F2 Streetfighter Project
dextersaurus
PostPosted: 11:52 - 22 Jul 2012    Post subject: 1994 CBR600F2 Streetfighter Project Reply with quote
So my CBR has given up the ghost yet again. Assuming it's the stator as that's the only thing i never checked/replaced the last time.
So, bidding on one on the bay, and hopefully that should sort the problems. Gonna go over it with a mate to make sure everything is as it should be.
Now, i'm going to be buying a new hornet - waiting on the dealer getting back to me about finance deals, so i'll be fixing this up if i get it running again, and turning it into some form of mental stunter streetfighter that i can mess around on.
Something a bit like... this....
https://i133.photobucket.com/albums/q41/XxMustang281xX/Facebook/FOR%20SALE/120518_004.jpg
The subframe on my bike is modified slightly for an R6 tail to fit onto it, so i could get a race type tail fairing, and fit a 12 o'clock bar to it. Who knows, this could turn out pretty epic.
We shall see.
For now, i'll be fixing the issues, then i'll get onto cleaning it up Thumbs Up
Dunc
dextersaurus
PostPosted: 16:34 - 22 Jul 2012    Post subject: Reply with quote
Oh noes!
Started like this.
https://sphotos-c.ak.fbcdn.net/hphotos-ak-snc7/394624_3838286649411_1695386091_n.jpg
https://sphotos-e.ak.fbcdn.net/hphotos-ak-ash3/559249_3844853293573_2020274435_n.jpg
now...
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/394693_3897811057484_1124018625_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash3/562833_3897812657524_609529906_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-snc7/483224_3897813777552_893460701_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash3/578797_3897815217588_1087548980_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/399489_3897816617623_1871644727_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash3/578668_3897826177862_1529483412_n.jpg
Next stop... GET IT WORKING!
Casper
PostPosted: 20:28 - 22 Jul 2012    Post subject: Reply with quote
Think i would be more tempted to brake it and sell the parts on eBay.
dextersaurus
PostPosted: 22:25 - 22 Jul 2012    Post subject: Reply with quote
Will be if i can't get it running.
dextersaurus
PostPosted: 13:46 - 29 Jul 2012    Post subject: Reply with quote
So i made a bit of progress today.
I've re-routed all the cables so they hook up to the switchgear, and also re-routed the electrics so they sit under the coils (next to the fan...).
Stuck the old battery in just to make sure it wasn't the problem, and it started up...
I'm gonna have to test the whole charging system as something isn't right with it. But at least i know it's working. new battery, new stator, and at worst a new reg/rec will be needed I think. It's been put on hold till next month because i'm having to pay out £300 on the car this month Rolling Eyes
Anyway, gave it a quick wash. missed a few bits but it looks better at least Laughing
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/s720x720/376757_3923124370301_1443277039_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/s720x720/484135_3923124770311_1256029012_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/s720x720/306359_3923125290324_1577819243_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-snc6/s720x720/251963_3923125690334_224630468_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-snc7/s720x720/318874_3923126090344_1521513422_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/s720x720/376878_3923127170371_177470006_n.jpg
After i've sorted out the wiring and charging system, all that's left to buy is a headlight. gonna be a crosser style one because they are cheap and easy. rarely ride at night so the quality of the light isn't really much of an issue. Once the light is done, all that leaves is indicators and we're all set!
Dunc
funmonkee
PostPosted: 23:45 - 29 Jul 2012    Post subject: Reply with quote
Dunk you are a serial bike molester.
A new Hornet you say. Nice.
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
mysterious_rider
PostPosted: 10:45 - 30 Jul 2012    Post subject: Reply with quote
Mate test the voltage on the battery (while bike is running) with a multimeter.
It should be reading nearly 14v at idle. If its something like 12. Or 12.something then the charging system isnt working. I don't think I've ever had a regulator/rectifier die so I'd look at the stator plate.
They are cheap from wemoto, and are a piece of piss to fit (just time consuming, dropping engine oil etc)
My gs500 had to have it replaced, cost me £58 and worked perfect after that.
If you want to eliminate the rectifier from the equasion you could try disconnecting it I guess and testing the pos and neg that would lead to it from the stator, it should read something fairly high. Espesh when revved. (near 17or above when revved I believe) If its below then its the statorplate.
dextersaurus
PostPosted: 16:51 - 30 Jul 2012    Post subject: Reply with quote
Cheers Thumbs Up
Well the state of the previous reg/rec...
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash3/556672_3618095304765_1124786594_n.jpg
This model of cbr is prone to them failing due to them having no cooling capability.
I just assumed it was the issue and replaced the whole loom and bits and bobs, but never touched the stator...
Now it's failed again, i know that's the problem as it's the only thing i never replaced last time. I've fitted an R6 reg/rec which seemed to solve the problem.
I've got a clymer manual here which shows the resistance that should be between the points in the stator, so when it stops raining i'll head out and test it.
Dunc
Nick 50
PostPosted: 17:04 - 30 Jul 2012    Post subject: Reply with quote
That Reg/Rec Shocked
Out of interest, is there particular models of R6 Reg/Rec which can be used?
You seem to be getting there though Thumbs Up
dextersaurus
PostPosted: 17:47 - 30 Jul 2012    Post subject: Reply with quote
I think the older ones have 5 pins, which matches the one on the bike. you do need to bodge up the wiring to it.
The newer ones have 6 pins (one i'm using). If you need a hand wiring one with 6 in, give me a shout.
Dunc
dextersaurus
PostPosted: 21:45 - 07 Aug 2012    Post subject: Reply with quote
Got the bike running again but i'm not gonna be using it again till i can get my hands on a decent multimeter so i can test everything.
I'm thinking it might have just been a dodgy connection, but i'd rather not take any chances.
https://sphotos-c.ak.fbcdn.net/hphotos-ak-snc6/s720x720/255357_3959137190599_1587823344_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash3/s720x720/552055_3959135430555_751288979_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/s720x720/484111_3959134230525_204403126_n.jpg
https://sphotos-c.ak.fbcdn.net/hphotos-ak-snc7/s720x720/388076_3959133630510_1189652319_n.jpg
I'm using parts off my other bikes and what i've got laying around in the shed, so it's coming along nicely for me having spent £0 on it since it last ran.
From what I can tell, worst scenario i'll have to buy a new stator and fit that. not difficult, just a pain in the arse. Gives me an excuse to change the oil and filter anyway.
I'll also have to test the reg/rec. Once i've got my hands on a multimeter i'll have to check the stator, check the reg/rec, make sure the battery is okay then just go over everything with the multimeter.
I'm also quite happy i just found a 5L unopened bottle of castrol 10w40 oil so i'll be using that when it comes to change the oil. In the same box was a set of iridium plugs, which i must have bought ages ago and never bothered fitting.
Worst thing i've come across so far is a stripped thread on one of the bolts for the RHS coil (1&4). might helecoil it, might just secure it an easier way. not decided on that one yet Laughing
Anyway... shopping list:
Multimeter - £20
Tyres (diablos... £140 a pair in these crap sizes)
Stator - possibly - £50~
Reg/rec - possibly - £50~
Battery - possibly - £30
Then i start to dream and look up other things...
BROS 650 single sided swingarm - £100~
VFR750 hub/sprocket carrier/brake - £100~
VFR750 wheel (180 rear tyre - perfect) - £50~
GSXR600 front end & modified top/bottom yoke - £200~
R6 Tail - £30~
But then we know that isn't actually going to happen.
So i need about £300 to fix this completely, once and for all.
Probably better scrapping it.
Rolling Eyes
Oh, i forgot this.
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/s720x720/306373_3959134910542_1855218666_n.jpg
Moxey
PostPosted: 23:37 - 07 Aug 2012    Post subject: Reply with quote
Pre 2005 model R6 reg/recs are 5 pin Thumbs Up
very common mod on the CBR 400's seems the problem persisted on the 600F's which is a shame.
& Dunc if you start giving up don't scrap it..........RAT BIKE!!!! Very Happy
moppy
PostPosted: 00:14 - 08 Aug 2012    Post subject: Reply with quote
You can't count tyres as a cost, they're consumables that need replacing during the normal course of things anyway, so REALLY you only need to spend £150!
Yay! Laughing
dextersaurus
PostPosted: 22:24 - 08 Aug 2012    Post subject: Reply with quote
So I got tempted and ripped the bars off (the cables are all too short - need to buy longer ones for those bars to fit) and put the clipons back on.
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash3/s720x720/599995_3963781866713_31827014_n.jpg
Took it for a ride. Sounds VERY good without the two tubes going into the airbox.
It rides abolutely fine though, i can't tell what the issue was, so i'm assuming there was a dodgy connection somewhere.
took it out for a half hour, checked the battery and it was nice and cool, so doesn't seem to be the same problem.
The reg/rec was absolutely roasting though.
videooooo...
https://www.youtube.com/watch?v=OZ_xLTM6BbM
Casper
PostPosted: 05:29 - 09 Aug 2012    Post subject: Reply with quote
Move the reg/rec to an area where it will get better air flow or get an old computer fan and stick it on top and plumb the wires into the ignition. Or even better, both.
Ol
PostPosted: 14:29 - 10 Aug 2012    Post subject: Reply with quote
Mr Dunkable wrote:
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s720x720/599995_3963781866713_31827014_n.jpg
Get it Cafe Racer'd !
moppy
PostPosted: 15:32 - 10 Aug 2012    Post subject: Reply with quote
https://www.therevcounter.com/mechanics/80048-theres-lovely-honda-regulator-fan.html
Maybe that thread can be of some use to you Dunc?
PostPosted: 15:47 - 10 Aug 2012    Post subject: Reply with quote
What sizes do you need Dunc?
Garage local to me sold me 6mm tread supercorsas fitted for £75ish Laughing
dextersaurus
PostPosted: 07:59 - 11 Aug 2012    Post subject: Reply with quote
I'll have a look at that fan as it does get really bloody hot.
And i'm looking for 120/60-17 and 160/60-17s - like these
Dunc
PostPosted: 15:58 - 11 Aug 2012    Post subject: Reply with quote
They do those sizes in supercorsas Laughing
Casper
PostPosted: 04:47 - 17 Aug 2012    Post subject: Reply with quote
Forgot to say to you Dunc. Your after longer cables, try this crowd,
https://www.customizedchoppers.com/
Along the road from you at Hospital Road Haddington. A small Ind Estate just down from the hospital.
Timmeh
PostPosted: 14:16 - 17 Aug 2012    Post subject: Reply with quote
Dunc...
Prolly you've fixed it by now but the reg/rec of the 95-98 CBR600F3 is a straight swop and it's the type with the heatsink, so it might help.
I now have one of these on my RVF as mine was like yours and was getting a bit frazzled.
dextersaurus
PostPosted: 18:10 - 17 Aug 2012    Post subject: Reply with quote
Looks like the issue was a dodgy connector. done another 500 miles over the last couple of weeks and it's been spot on. not a problem Thumbs Up
So... shopping list now:
Tyres £? speaking to a breaker mate that might get me some part worns
While i'm there i'm also gonna see if he's still got the bits from the GPZ500s streetfighter i had. If he's got the speedo and bars, i'll be having them.
2008 R6 race tail fairing £70. shall be cutting the subframe down a tiny bit as it almosts fits, and will look pretty damn good.
Then i might go down the route of getting a single sided swingarm and some USD forks. We'll see how much cash i have.
Dunc
Edit: ALSO... Bars or clipons?
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash3/524480_3999341675686_1780772446_n.jpg
The last post was made 14 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 140.69 Kb
