Mad Question?
darthbuttchin
PostPosted: 22:15 - 22 Jul 2012    Post subject: Mad Question? Reply with quote
Okay, this may sound mad (and noobish), but I was riding about today, throttle wound right open (the only way to achieve 60 on the mighty (but ancient) CG) and I noticed my right arm getting more and more numb. It started in the hand but travelled up the arm slowly throughout the day, and seemed to happen quicker each time I started to ride again (i.e. after stopping for a drink or whatever).
I've looked into what it could be, and arm pump came up. Can you get arm pump riding on the roads? I thought it was only really in racing, due to the constant speed changes etc.
It could be im gripping too hard of course.
It could also be that I'm unused to riding without a backpack - could it be that Ive adapted my position to compensate for the weight of the backpack, so riding without it I'm putting too much stress on my wrist?
Basically, arms going numb when riding (even for short periods). anyone have any ideas what could be causing it?
cheers,
db
CG125-K1 (1978) - 35 years old and (mostly) going strong! (Restored and rebuilt by my own fair hands).
Call me Tomsk - I am the Flying Womble after all.
Eddie Hitler
PostPosted: 22:22 - 22 Jul 2012    Post subject: Reply with quote
Backpack could be too tight, throttling the blood at your shoulder?
I remember years ago it happening on me, but only once.
WannaBeDude
Backpack too tight, or bike fault contributing .. Confused
Or normal - how many miles at WOT ?
darthbuttchin
PostPosted: 22:34 - 22 Jul 2012    Post subject: Reply with quote
WOT?
wot is WOT? (see what I did there? Haha). But seriously, what do you mean?
PostPosted: 22:41 - 22 Jul 2012    Post subject: Reply with quote
Wide Open Throttle.
Could also be something as simple as your clothing being too tight in your armpit. I sometimes get this if I put on one jumper too many. Rucksack strap doing similar is a good bet.
If you MUST wear a rucksack on the bike (and therefore garaunteeing you slide face-down if you fall off). I'd suggest using the type with a waist strap. Do this up tight so the weight is sitting on your hips rather than hanging off your arms. Or slacken them right off so the weight is on the pillion seat.
Could also be vibration in which case altering the weight of the bars by changing the end-weights (if fitted) or by filling them with sand or similar can alter the resonant frequency.
J.M.
PostPosted: 00:11 - 23 Jul 2012    Post subject: Reply with quote
Definitely get one with a strap.
I was going down the motorway once and stretched my arms, the backpack came off my back but luckily my arms were angled and caught the straps so I didn't lose the bag. Not made that mistake again. Embarassed
I also did a lot of commuting with a laptop in a rucksack for college which was (the bag above) slackened off so that it rested on the pillion seat. Barely knew the bag was there. Smile
2004 R1 & 2018 XSR900
paddlesat16
PostPosted: 06:53 - 23 Jul 2012    Post subject: Reply with quote
You could try some bar end weights to stop the vibey bars as well.
Regards
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
map
Mr Calendar
PostPosted: 08:11 - 23 Jul 2012    Post subject: Reply with quote
Agree with the other comments on tight clothing and rucksac.
If cannot bungie 'sac to pillion maybe for long runs with a constant throttle setting a crampbuster throttle control may help? Can transfer it to a bigger/another bike if and when required.
https://www.championmotouk.com/avactis-images/Accessories/Scottoiler/Scottoiler_Crampbuster_Oversize_Lg.jpg
https://www.ducati.ms/forums/attachments/sport-touring/19935d1189530977-survey-what-grips-do-you-use-why-crampbuster-small.jpg
Ballpark price £7.
You can get that thin one or a wider one.
https://www.championmotouk.com/avactis-images/Accessories/Scottoiler/Scottoiler_Crampbuster_Wide_Lg.jpg
When not required you just turn it around the throttle so it hangs down out of the way (close throttle) and then use throttle normally.
HTH Thumbs Up
Andy_Pagin
PostPosted: 10:40 - 23 Jul 2012    Post subject: Reply with quote
Probably just a combination of too tight a grip on the throttle combined with the high frequency vibrations through the handle bars, try relaxing your grip a bit.
The last post was made 13 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 68.13 Kb
