Powerbands and CGs
Itxi
PostPosted: 22:57 - 22 Jul 2012    Post subject: Powerbands and CGs Reply with quote
Blue or Black?
On a more serious tone, is there any way to modify the powerband of my CG? I used to be able to do 60 with it no probs, well it was a slight struggle, but it still felt like the engine was pulling if that makes sense.
A few weeks ago a part of the carb somehow shook loose and when I put it back the powerband changed, I now have plenty of low-rev power and it accelerates like stink, but it'll now reach a maximum of 55 and the engine doesn't feel like it's really got any 'oomph' to it.
Now I have fitted a top-box and panniers in this time so I can understand how that may reduce the top speed on a 125, but it still feels like it has more low-rev torque than before.
I'm not trying to get more power out off it, just smooth out the powerband towards the higher revs.
Hastings Direct, Scum you say?
PostPosted: 23:06 - 22 Jul 2012    Post subject: Reply with quote
First thing I'd do is check that the part that fell off has been replaced properly.
Next thing I'd do is realise that adding a full luggage system will make my 11hp commuter slow.
Itxi
PostPosted: 23:45 - 22 Jul 2012    Post subject: Reply with quote
Part has been replaced fine.
I know the luggage is probably what's slowing it down, but is there any way to give it some more power in the higher revs to counteract the luggage? (need it for shopping)
Alpha-9
PostPosted: 23:56 - 22 Jul 2012    Post subject: Reply with quote
check your tappit clearances, should be 0.08mm I think
CGs are naturally a bit slow Thumbs Up
Fzr-600 1999
Itxi
PostPosted: 07:43 - 23 Jul 2012    Post subject: Reply with quote
Cheers, I'll look into changing the rear sprocket, so long as I can get a cheap one.
I may open the engine up if I have a spare weekend, see if I can do any maintenance. Thumbs Up
russell210276
PostPosted: 09:33 - 23 Jul 2012    Post subject: Reply with quote
or replace your front sprocket go 1 up its easier and from what i read going 1 up on the front equals taking 3 off the read
PostPosted: 10:44 - 23 Jul 2012    Post subject: Re: Powerbands and CGs Reply with quote
And you're asking us what changed?
If you really want help, tell us what mystery part somehow shook loose, and exactly how you put it back. Also tell us what else you fiddled with while you were doing that.
Itxi
PostPosted: 11:07 - 23 Jul 2012    Post subject: Reply with quote
Part 11, the main jet is what came loose.
https://cdn.bikechatforums.com/files/untitled_119.png
I just screwed it back in again. Didn't change anything else, taken the carb apart enough times to know where everything goes.
this thread may sound chavy, but I was just wondering if the powerband can be adjusted through tuning, not trying to up the power or anything.
russell210276
PostPosted: 11:35 - 23 Jul 2012    Post subject: Reply with quote
the power band or where the peak power is can be done by some engine tuning but your looking at bigbore kits and i think higher compression might play a part of shifting the power up or down aswell.
problem is the power band isnt like a 2 stroke or even vtec as with them 2 you no when you hit it i dont think theres much to be done to a cg as there is no aftermarket parts and plus its a pushrod engine doesnt make much power at the top due to valve overlap. theres more bottom end grunt than anything
Itxi
PostPosted: 11:53 - 23 Jul 2012    Post subject: Reply with quote
So not much I can do then, cheers for taking the time to reply.
I may look for a smaller rear sprocket.
PostPosted: 11:57 - 23 Jul 2012    Post subject: Reply with quote
Oh, I had that too. Very Happy
https://4.bp.blogspot.com/__DYtEEjm5wE/S27qgGcHuaI/AAAAAAAAAI8/Q9DUZX-bJho/s320/float-bowl-jet.jpg
How's your plug colour? Have you done a WOT plug chop?
I found on my CG-copy engined bike that upping the front sprocket by 1 and then 2 teeth gave more relaxed riding, but it didn't really increase the top end. Worth a fiddle for the price (under £5 a sprocket delivered), but it still sounds like something has changed in your bike to cause it to lose power.
Itxi
PostPosted: 12:10 - 23 Jul 2012    Post subject: Reply with quote
Haven't done a plug chop yet, may do when I get a paddock stand (actually I wont because everyone knows the engine needs to be under load Smile ) But typically the plug is fine, perhaps running a little rich but not massively so, and that could be the accelerator pump. (got given a later-version carb with the pump and thought I may as well put it on, but that was when I first got the bike)
Not sure what's causing the loss of power, could be the luggage but it's not just travelling slower, it does feel like there's less power from the engine.
cb1rocket
PostPosted: 12:19 - 23 Jul 2012    Post subject: Reply with quote
you can't do a plug chop on the paddock stand! engine must be under load..... Rolling Eyes
Itxi
PostPosted: 12:29 - 23 Jul 2012    Post subject: Reply with quote
As much as I have learnt over the past 7 months I still know very little Very Happy
PostPosted: 12:36 - 23 Jul 2012    Post subject: Reply with quote
Is there any chance that you've nobbled your needle? Again, I ask because I did that - after some fiddling with the height, I fumbled putting it back in, the clip worked loose and the needle was essentially only being held down by gravity. That resulted in running rich, decreased power, and increased fuel consumption.
Itxi
PostPosted: 13:12 - 23 Jul 2012    Post subject: Reply with quote
I'll have a look when i head home, pretty sure the needle is fine but it's possible.
DMCpro
PostPosted: 15:13 - 23 Jul 2012    Post subject: Reply with quote
have you tried fitting new powerbands? take the barrell off and put some new elastic bands around the piston
4strokes dont have powerbands Twisted Evil
Honda CB-1, TS125X
VW Golf Estate
symonh2000
PostPosted: 15:25 - 23 Jul 2012    Post subject: Reply with quote
Take the engine out and fit a 2 stroke. Twisted Evil
Four strokes is two strokes too many.
PostPosted: 17:59 - 23 Jul 2012    Post subject: Reply with quote
If the main jet (and presume possibly the attomiser tube) has come out then it is possible that the needle has been damaged. Take the carb slide out and inspect the needle carefully.
sickpup
Old Timer
PostPosted: 18:01 - 23 Jul 2012    Post subject: Reply with quote
I think its time for you to be quiet now.
DMCpro
PostPosted: 18:23 - 23 Jul 2012    Post subject: Reply with quote
I dont agree with your suggestion
Honda CB-1, TS125X
VW Golf Estate
stevo as b4
PostPosted: 18:46 - 23 Jul 2012    Post subject: Reply with quote
Compare a CG125 engine to a 125cc 4stroke lawnmower engine, and i think you'll find the CG has a nice pronouced power band probably in the 5000-9000rpm area. The CG isn't a dull bike and 11bhp has never been so much fun on a geared machine IMO.
I'll get my coat, but i always thought mine was quite nice and nippy around town, and so much less annoying than those 70cc race kitted scooter's that rev like a model aeroplane motor on Nitrous before you see any sign of acceleration in the slightest.
el_oso
PostPosted: 20:40 - 23 Jul 2012    Post subject: Reply with quote
of the few 125 bikes i have used i found that the cg was very boring. i found that it was better down the lower end of the rev range than the higher end.
the extra weight won't be causing a noticeable difference. what may be hampering your top speed would be extra wind resistance from extras you may have fitted. Even small changes in surface area of the bike against the wind can affect the top speed greatly, especially at higher speeds.
Duke 390
Car: Jeep Wrangler 4.0L
The last post was made 13 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 130.07 Kb
