HELP RS WON'T START
RSJames
PostPosted: 21:02 - 23 Jul 2012    Post subject: HELP RS WON'T START Reply with quote
Right so i set off forgetting I left my fuel off, bike cuts out I turn the fuel back on lights still working but as I press the ignition it just clicks and doesn't even try. I can bump start so the bike is fine. Any ideas I need it for work Sad
Currently riding an aprilia RS 125 full power, yes it has blew up before.
DrSnoosnoo
PostPosted: 21:33 - 23 Jul 2012    Post subject: Reply with quote
Dead battery? give it a good run and try to charge the battery up. Failing that, get the old multimeter out and measure the voltage of the battery. Are all kill switches turned on/off, however you want to put it?
Chris750
PostPosted: 21:38 - 23 Jul 2012    Post subject: Reply with quote
Battery hasn't got enough power to turn the engine.
Put it on charge for a bit and it'll be fine.
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
Nope.
PostPosted: 23:30 - 23 Jul 2012    Post subject: Reply with quote
That, and next time post in the workshop.
RhynoCZ
PostPosted: 04:30 - 24 Jul 2012    Post subject: Reply with quote
My idea is to check the starter solenoid/relay, if it has one, don't know if newer bikes still has these. Well, I believe it does have one of these things Smile . It could be just a bad connection there if ''it'' clicks whenever you press the start button, as you say. And if it clicks somewhere else than the starter motor its self. Thumbs Up
I not sure, what term is right in english for this starter component, just that thing that let the power go to your starter motor when you press the start button.
doggone
PostPosted: 06:43 - 24 Jul 2012    Post subject: Reply with quote
If it started OK from cold, the battery couldn't have died in the time it took to realise the fuel was off.
Tenko
PostPosted: 07:18 - 24 Jul 2012    Post subject: Reply with quote
Charge up the battery 1st. If it still doesn't start and just 'clicks', take a rubber-handled screwdriver and bridge the solenoid terminals. Make sure there isn't any petrol about and do it in the dark as it looks better.
If this works, give the solenoid a whack, then see if it frees it off enough for it to work normally. If it doesn't, fit a new one.
The last post was made 13 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 51.51 Kb
