Throttle hand numbness
Smiley.Sands
PostPosted: 16:15 - 27 Jul 2012    Post subject: Throttle hand numbness Reply with quote
Hi all.
I've recently started riding and I love it, but sometimes after a longish ride out, my throttle hand is numbish when I get home and sometimes I dont have much grip and can hardly get my key in the front door! Lol. Do you think it will strengthen over time or would hand exercises of some kind help?
Thanks
Sands
PostPosted: 16:30 - 27 Jul 2012    Post subject: Reply with quote
Best advice to give is not hold onto the bars so tight. Loosen your grip. That will help reduce the numbness.
Kaneda
PostPosted: 16:36 - 27 Jul 2012    Post subject: Reply with quote
As above, it's a problem I had too. Loosen up by waving your elbows like a chicken, and raising and dropping your shoulders. The tensing and gripping of the bars reduces bloodflow, which is why you feel numbness. Relaxing the muscles in the area reduces this, and longer term aches and pains.
Alan_BLD
PostPosted: 16:37 - 27 Jul 2012    Post subject: Wrist Rest Reply with quote
For long trips you could also try something like this
https://www.amazon.co.uk/Motorcycle-Cruise-Control-Throttle-Buster/dp/B002RAUV2I
yen_powell
PostPosted: 16:49 - 27 Jul 2012    Post subject: Re: Throttle hand numbness Reply with quote
Smiley.Sands wrote:
Hi all.
Thanks
Sands
Check that the handlebars are central in the clamp as this can cause one end to vibrate more than the other. Had this may years ago on a CX500 and used to end up with a weird tingle in one hand only after long rides. Moving the bars slightly cured it.
XT1200Z and a DR350 in bits
Smiley.Sands
PostPosted: 16:55 - 27 Jul 2012    Post subject: Reply with quote
Thanks guys. Thats given me a few things to try and to think about, some of which I wouldnt have even considered
supZ
PostPosted: 16:58 - 27 Jul 2012    Post subject: Reply with quote
people have already touched on the causes..
1. too tight a grip on the handlebars. a common problem with new riders. the 'deathgrip' goes with confidence but try to remember. handlebars are there to steer not to hang on to. try to keep your arms loose and your grip light.
as a side to that, try to hold on with your legs rather than your arms. will allow you to loosen your arms a lot more and let the bikes suspension work better as you're not pushing down on the front.
no numbness, bike handles better, win win Smile
2. vibration. if your bars are vibrating then that can cause numbness. are they? without knowing the bike its hard to guess what that would be but replacing/retighting/reseating bushes, bolts, bars, engine mounts, etc.. always help. check everythings buttoned/tightened up. not just around the handlebars but everywhere.
CBR954RR - Daily toy
CBR600RR - Trackbike
Smiley.Sands
PostPosted: 17:30 - 27 Jul 2012    Post subject: Reply with quote
thepuma
PostPosted: 18:26 - 27 Jul 2012    Post subject: Reply with quote
Had my CBT today and my right wrist was aching by the end. Probably due to what was said above, holding the grips too hard. I'm sure like any tendon/muscles, they will strengthen over time.
765 RS
PostPosted: 18:52 - 27 Jul 2012    Post subject: Reply with quote
https://www.msa-direct.co.uk/ProdImages/scott_crampbuster2.jpg
Works For Me.
Yes, lah-de-dah limp wristed foggotry.
Teflon-Mike
tl;dr
PostPosted: 19:33 - 27 Jul 2012    Post subject: Reply with quote
Works For Me.
A limp wristed pict, now there's a turn up for the books!
Gripping too hard and more than likely gripping twist grip too 'early'.
Think about this, while you are riding you have the throttle open, ie pulled right back.
When you get on the bike you let your hand fall to the grip at the natural angle, so when you twist throttle open..... you cramp your wrist.....
Solution, twist hand away from you when you sit the bike, so that when you are riding with the throttle half open THEN your wrist is at the normal 'rest' angle!
Its also not against the rules, to relax grip on the twist-grip and take a double 'bite', Ie use two fiungers to hold it where it is, then other two fingers to creep forwrds and get a littl ebit more twist from it, relaxing first two fingers to sort of 'walk' the grip in your palm.... in that way you can almost maintain the natural wrist-bar angle whatever the grip angle.
Skudd
PostPosted: 19:50 - 27 Jul 2012    Post subject: Reply with quote
Your gloves may too tight or fastened too around your wrist.
I had issues with a set of gloves that the thumbs were a shade too short when gripping, okwhen had them on as normal, but too small when gripping.
matto
PostPosted: 21:46 - 27 Jul 2012    Post subject: Reply with quote
Riding a big single cylinder bike could also add the problem.
LordShaftesbu...
PostPosted: 21:53 - 27 Jul 2012    Post subject: Re: Throttle hand numbness Reply with quote
Smiley.Sands wrote:
Hi all.
Thanks
Sands
Your symptoms suggest to me multiple sclerosis. That and the italics.
Davenaylor
PostPosted: 22:00 - 27 Jul 2012    Post subject: Reply with quote
Teflon-Mike wrote:
Works For Me.
Mike is this why, when I'm in a 40-50 zone on a 125 I have to release and the reach around ( Embarassed Rolling Eyes Shocked ) to grap more throttle? I'd tried to cure it doing what you said but it felt odd. I guess I need to get used to it?
Thanksnandnsorry for the thread hijack
Smiley.Sands
PostPosted: 22:21 - 27 Jul 2012    Post subject: Reply with quote
Thanks everyone. I'll try your suggestions. You've all been a great help. Smile
Smiley.Sands
PostPosted: 22:30 - 27 Jul 2012    Post subject: Reply with quote
LordShaftesbu...
PostPosted: 22:36 - 27 Jul 2012    Post subject: Reply with quote
No problem, glad to be of help.
LordShaftesbu...
PostPosted: 22:59 - 27 Jul 2012    Post subject: Reply with quote
I was also pleased to be of assistance.
PostPosted: 23:00 - 27 Jul 2012    Post subject: Reply with quote
I was also pleased to be of assistance twice.
Rogue_Shadow
PostPosted: 23:36 - 27 Jul 2012    Post subject: Reply with quote
I don't get it !
Rogue_Shadow
PostPosted: 23:37 - 27 Jul 2012    Post subject: Reply with quote
I still don't get it !
Smiley.Sands
PostPosted: 09:56 - 28 Jul 2012    Post subject: Reply with quote
There is a forum page somewhere that says can BCF fix the site because it keeps posting replies twice - something to do with it dropping connection...so not me I'm afraid Smile
sidewinder
PostPosted: 16:30 - 28 Jul 2012    Post subject: Reply with quote
Had the same problem my self got some slightly softer grips and that sorted it out for me Very Happy
The last post was made 13 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 128.29 Kb
