| titan666 |
 titan666 Scooby Slapper
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| at106 |
 at106 Brolly Dolly
 Posted: 22:16 - 27 Jul 2012 Post subject: |
There is also a filter inside the fuel tank which is part of the fuel tap, but it's easy enough to check fuel flow Make sure that with the inline filter fitted the fuel hose isnt twisted over itself! |
| titan666 |
 Posted: 23:37 - 27 Jul 2012 Post subject: |
cheers guys il check those and get back to you
anything else you can think of let me know and il do them too.
other than the issues the bike ran well even if it was at 40mph and 30 uphill(30ish) gotta check the tyre pressure of the rear later too as it felt weird and it actually made we aware of how much i was leaning:(
hint for anyone with a susuki gz marauder!
dont remove the standard airbox as its a pig to reconnect to the carb let alone get it back into its bay!...
(i didnt remove it,it was missing when i brought the bike)
still atleast the bike is VERY shiny now:)
cheers all
steve |
| titan666 |
| EazyDuz |
 EazyDuz World Chat Champion
| P.addy |
 P.addy Red Rocket
| titan666 |
| Im-a-Ridah |
| titan666 |
 Posted: 15:26 - 28 Jul 2012 Post subject: |
Yep i cleaned the bottom inlet in the float chamber and all fuel inlets but the top of carb where the main jet is has been half done as ive had to take the kids to some village event!
but il get back on it shortly and let you know if it helps as ive also got to reattach the airbox and carb as im removing the carb from its mount as its easier than trying to get at a screw thats hidden and id rather reattach the carb than dethread the screws to the carb
long winded but atleast il know ive done everything by the end!
steve |
| P.addy |
 P.addy Red Rocket
| titan666 |
 Posted: 16:59 - 28 Jul 2012 Post subject: |
all the jets and carb cleaned and back together nice and snug!!
now it is irratic on tickover(mid rpm to normal rpm )
drives now and reaches 25 but i just couldnt get more out without stalling it!
back to the drawing board and now im going to put that aftermarket filter back and see what happens after that incase it has been rejetted as said on here..
im starting to think i was sold a lemon!
but im going to win sooner or later!
steve |
| P.addy |
 P.addy Red Rocket
| titan666 |
| P.addy |
 P.addy Red Rocket
 Posted: 20:35 - 28 Jul 2012 Post subject: |
Would suggest its been fiddled with then.
Definitely worth taking a look  |
| titan666 |
 Posted: 00:16 - 29 Jul 2012 Post subject: |
Its kind of annoying, i dont like too much noise from my engines as im not one of these typical boyracers.
You know the type!they drive these girls cars round that they have added afew stickers too and afew other mods that make it look even more ridiculas!,then go and add an aftermarket filter and exhust that makes enough noise and vibration that you think your windows are going to vibrate to pieces and give you Tinnitus.
a car that sounds like its exhust has fallen off! and all that to a car that is usually a crappy clio or fiesta or something of that type which has usually got a stereo thats worth more than the car!
I wanted my bike to run as standard as the resale is better if you havnt messed with it!
But it does have its perks as there is a market for those kind of alterations! aslong as it doesnt affect the fuel consumption too badly then i can live with it as its not too noisy, and having one of these pod filters does add that extra vocal appearance of a bigger bike rather than a strangled whine!
But i do like my things standard as i know they wont affect things like MOT`S and emmissions tests plus having a bigger jet also affects its MPG.
But aslong as its done right and it isnt causing too much heat from running rich etc then its ok and aslong as its legal!
I did find gunk when i stripped the carb,it was in the main jet and look like jelly or white snot! but other than that it was pretty clean but cleaner now!
also its now mounted better onto the engine in its rubber thing..
I took it for another spin before i took my little one to bed and its running really well and i cranked it right over on the accelerator and not a hint of power issues!
very happy with it now and all i have left is the taillight to sort out and the oil leak from the rocker housing and shes done!
anyone know what tranmission fluid these engines take and how much?(it might help the neutral issue and while im draining i might take a gander at the gearbox(selector workings)as these bikes wouldnt have been shipped with this issue so im guessing its something that crops up after extented use and COULD be renew`d?(maybe)but its not a high priority job so maybe oneday but changing the fluid is a deffinate just for the sake of it!
steve |
| P.addy |
 P.addy Red Rocket
| titan666 |
 Posted: 01:01 - 29 Jul 2012 Post subject: |
nice one paddy:)cheers
il pick some extra stuff up when im back in the world of people:)
(not that im that far out 40+miles to my nearest town)bloomin 80+round trip
thus getting a bike and saving fuel!
steve ____________________ love my susuki gz 125 maraurder 1998 |
| EazyDuz |
| at106 |
 at106 Brolly Dolly
 Posted: 10:33 - 29 Jul 2012 Post subject: |
As said you need 10-40w oil, you need 850ml or 950ml if you're changing the filter as well.
The standard main jet is 102.5 so if you set the carb back to factory you will be able to run the standard airbox  |
There is a gap of 9 years, 353 days between these two posts... |
| yoeri111 |
 yoeri111 L Plate Warrior
The last post was made 4 years, 71 days ago. Instead of replying here, would creating a new thread be more useful? |
