MOT sneeky tricks...
mr.z
PostPosted: 21:02 - 16 Oct 2004    Post subject: MOT sneeky tricks... Reply with quote
My mot has been looming for a while, and its the first one ive ever took a bike for (sold my last with less than a week left on it)
So when i want with a mate while he got his tyre complete with 1 1/2" screw replaced (in the pishing rain too) i booked mine in for tuesday.. great... so off i go folloing my mate (squirming allover the place) and glance down at the rpm meter, which is dead Evil or Very Mad frickin thing!!! so i went and got a cable ready for when i feel like puttling the radiator, and other assorted stuff off to get at it... now apparently if you have an rpm counter it must work, so if its blocked off (with say gaffa tape) then it dosent matter yes? thats the plan, will it work??
The only other one was stinkys putting hose clips on the gaitors for leaky seals... i'm putting mine on just in case! Razz
But what other sneeky/handy hints can be given for the boarderline iffy motorcycle?
Also my fogs, they are not standard, they are on brackets and only come on with the main beam, so they can be as bright and dazzleing as they want right?
Oh the other concern, the headlight can't be adjusted (wireing behine pushes the springs so you can adjust it) its a little bit high, can you put tape over the bulb to lower it a little?
That is unless something falls off or snaps in the mean time Sad
Robby
Dirty Old Man
PostPosted: 22:18 - 16 Oct 2004    Post subject: Reply with quote
I assume its a round chrome headlight with a bolt at each side.
Just push the whole assembly so it tilts down, much easier than fiddling with adjusters.
Another fork seal bodge is to pack some cotton wool under the dust caps, should soak up any small leaks.
Don't know about the rev counter thing. A retest is free, so if it fails you could just take it off. Or replace the cable anyway, assuming that is the problem - you'll need one anyway.
Sparks!
Sir Tart-a-lot
PostPosted: 22:28 - 16 Oct 2004    Post subject: Reply with quote
The garage that MOT'ed my R6 want me to pay another £15.50 to retest and all they have to check is that I've stuck a reflector on it Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad
PostPosted: 22:55 - 16 Oct 2004    Post subject: Reply with quote
You can even go so far as to tape up all the lights and switches if they are dead ropy and get a daylight only jobby done on it.
Most importantly KNOW YOUR ENEMY.
If you think something is borderline, read the manual and fix it if it is a blatant fail. Remember they are NOT allowed to remove parts of the bike to test it. If they fail it on a point you think should pass according to the book, argue the toss. Make them show you in the manual where it is a fail.
A lot of testers just make stuff up as it suits them, I had one of them fail a bike for not having a split-pin through the rear wheel spindle despite there not being a hole in it and having showed him an exploded diagram in the workshop manual with no pin. I am a lot better informed and assertive with them now when they try that sort of thing on me and would threaten to report him to the vehicle inspectorate if he persisted in his claim that it was a fail.
You usually have two weeks to bring an MOT back for a free retest after a fail (they give you a list of what to fix).
If you turn-up with a load of tools and look like you are going to repair any points they fail it on in their carpark, a lot of them will give you a certificate just to make you Feck off. Smile
mr.z
I wish the headlight was that simple! Sad
Its pritty much fixed position, annoyingly, but since the first time the fork seals were done (i did mine more recently) the wireing has been a pushing it out again makeing adjustment impossible... i tryed for a couple of hours getting it sorted, suck a pita, when i get time i iwll get everything moved about properly...
I dont think they charge for retests, even so i will be makeing any "adjustments" in the car park just outside (or in the workshop in all likely hood) if i need any bits there is a breakers about 3 minutes ride away.. should not be a problem as they are pritty cool there apparently (a mate has had all his bikes from there for years)
I'm not 100% sure the headlight is out, it seems high to me but... how can you tell where it should be? its a couple of meters back and then so high right?
Thing with replaceing the cable the radiator has to come off, as does the fan and other assorted fiddley crap, i'd rather do it later if i can Very Happy somebody mentioned they have never had the mot tester even start their bike! Shocked
Anyways, thanks up to now for the help Thumbs Up
edit:
Laughing i can imagine, thats what i was planning on doing, a factory manual, socets spanners and everything else i can think of.... put it this way, they sold it to me, so anything thats wrong (appart from one or two bits) they passed it fine before (like the lack of a split pin on the torque arm)
also they mot'ed perviously mentiond mates' bike with full race system (though not obcenely loud, its obvious its not stock), he asked if he had the original, he said "yep" and passed him Thumbs Up
So i dont think they will be twatty about it, its not in their interests to have me use up an mot slot they could be makeing money out of either Wink
PostPosted: 23:01 - 16 Oct 2004    Post subject: Reply with quote
You bike doesn't have to be able to start, the engine is not part of the MOT...it doesn't even have to have an engine in it. If you were to present it with say, no sparkplugs in. They can't test your rev-counter. Simple. Wink
mr.z
PostPosted: 23:03 - 16 Oct 2004    Post subject: Reply with quote
Or no keys? mwahahahaha, thats ace Thumbs Up but um.. that would make rideing it there harder Razz unless i wip em out while i'm there, "i'm just takeing my ht leeds for a walk, back in a bit"
PostPosted: 23:05 - 16 Oct 2004    Post subject: Reply with quote
You need the keys or the lights won't work!
If it fails bigtime, post on the ratbike site, I can't imagine how many hundreds of years of cumulative experience at inveigling dodgy scoots through their MOT is present on that forum.
mr.z
PostPosted: 23:12 - 16 Oct 2004    Post subject: Reply with quote
Curses foiled again Very Happy
I think it will be ok anyways, if theres any problems i dont think they will be nobs about it, if i really have to i wil sort it in the car park Very Happy
I neeeeds to pass, i dont have time to mess about as i'm at uni all week and work at the weekend, tuesday is my day off Sad
Hopefully if something is wrong then i will be able to get a spare or bodge it, i'll remember to ask on ratbike.org tho Thumbs Up
Haveing read the mot manual bit you posted it dosent seem to mention the aim, i get the feeling its at the testers discression? i.e. has to be stupidly high? i could take some tape and "adjust" it in perviously mentioned cart park i guess?
I'm just being a bit paranoid i think, i need to learn to relax a bit i think...
Danny
Ask Me About Stoppie School
PostPosted: 00:00 - 17 Oct 2004    Post subject: Reply with quote
Interesting, my GPz550 failed it's MOT last year because the zaust was too loud (missing gaskets Embarassed ). The only way the guy knew the zuast was not right was by starting the engine. So in future I can tell 'em no to start the engine?
PostPosted: 00:12 - 17 Oct 2004    Post subject: Reply with quote
Friends of mine have MOTed a rolling chassis before in order to get it registered (you used to just have to get an MOT then take it and the bike to the DVLA local office to be issued with a registration mark).
I can find nothing in the manual that lists a missing or defective engine as a reason they can give for failing the MOT test unless it constitutes a structural part of the chassis (likewise plastic mudguards).
PostPosted: 01:09 - 17 Oct 2004    Post subject: Reply with quote
Also need it for the petrol cap. They now much check the seal in the petrol cap, so no way to open the cap = no test.
PsychoHippy
Jammy Git
PostPosted: 16:48 - 17 Oct 2004    Post subject: Reply with quote
If they don't need to start the bike to MOT it, how do they check the emissions?
Or don't they?
I spend all my money on bikes and beer, the rest I simply waste!
Spiral
PostPosted: 17:00 - 17 Oct 2004    Post subject: Reply with quote
What about exhaust emissions tests would'nt they need the engine to pass your bike on this Question
****NORTHERN IRELAND NEWSFLASH!!**** According to a recent survey, 94% of loyalists said the best sex they ever had was in the shower; the other 6% haven't been to jail yet.***
Robby
Dirty Old Man
PostPosted: 17:40 - 17 Oct 2004    Post subject: Reply with quote
No emissions tests on bikes.
PsychoHippy
Jammy Git
PostPosted: 17:44 - 17 Oct 2004    Post subject: Reply with quote
You learn something new every day - I shall consider myself informed Very Happy
PostPosted: 18:19 - 17 Oct 2004    Post subject: Reply with quote
I tried to get the guy at the MOT to do an emissions test on my T500 (30 year old, 500cc, 2-stroke twin) just to see what it was like. He refused on the basis that it would probably break the machine Very Happy
PostPosted: 01:15 - 18 Oct 2004    Post subject: Reply with quote
Good few years back I got a local MOT station to test the 1200 Bandit (at the time 1 year old and standard). From memory it was 3.2% CO (barely a pass for a non cat car). Cannot remember the HC figure. He wouldn't test a 2 stroke either.
The last post was made 21 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 110.45 Kb
