Engine size. Car vs bike
The Dude
PostPosted: 13:16 - 17 Oct 2004    Post subject: Engine size. Car vs bike Reply with quote
Hi all. This is probably a dumb question but i'll ask it anyway. Lately my brother has been asking me the difference between a car and a bikes engine. Example. If you had a 1000cc bike and a 1000cc car. The bike does around 180mph tops and the car does 90mph tops. If the car is say 3 to 4 times heavier than the bike, why doesn't the bike go 3 to 4 times faster than the car taking into account power to weight differences? Help me explain it to him as if he was a 4 yearold.
Milo
PostPosted: 13:29 - 17 Oct 2004    Post subject: Reply with quote
It's sunday so I can't be arsed to explain it well...but because of air resistance (drag) and friction you need about 4 times the power to double the speed.
Shaft drives rule. Razz
1cyl
PostPosted: 13:56 - 17 Oct 2004    Post subject: Reply with quote
Car's are slow.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Silver
PostPosted: 14:02 - 17 Oct 2004    Post subject: Reply with quote
A car that weighs 640kg? I think the weight difference will be much bigger.
And, as Milo says, bikes are very un-aerodynamic. They have a similar drag factor to a transit van.
Bendy
Mrs Sensible
PostPosted: 14:08 - 17 Oct 2004    Post subject: Reply with quote
Also, a 1000cc car engine and a 1000cc bike engine are very different beasts, so they're really not comparable.
My old 1 litre Micra was listed as weighing about 660kg. Newer small cars are probably going to be heavier though, with all the safety gumph they stick in them.
Davo
Davo To The Rescue!
PostPosted: 14:20 - 17 Oct 2004    Post subject: Reply with quote
I have often wondered a similar thing, I own a Hayabusa and a Ford Ka they both have the same size engines. What I want to know is that the suzuki engine can develop approximately 180bhp, so how come ford can only get sixty ponies out of their engine.
180bhp in a Ford Ka, that'd be fun (for a car).
Silver
PostPosted: 14:22 - 17 Oct 2004    Post subject: Reply with quote
Well, that's probably half the reason. It'd be deadly - unless, they upgaded the brakes, chassis, suspension etc etc which would increase the price of the car and make it something it's not supposed to be.
1cyl
PostPosted: 14:31 - 17 Oct 2004    Post subject: Reply with quote
bike engines don't need much torque, so they can have more bhp, a car engine needs a lot of torque to get it to go anywhere, so the sacrafice the horses (i might be wrong).
You might also notice that your bike engine redlines at around 13,000 and your car at around 6'000. bike engines are built stronger and to a higher performance spec than your average ford ka's lump.
I stand by what i said earlier.
mrchips
Just spend 5 grand on an Sierra RS500 that will get you there quicker.
Spiral
PostPosted: 14:33 - 17 Oct 2004    Post subject: Reply with quote
170bhp cbr1000rr
13bhp cbr125r
Now i don't know why the cbr1000 does'nt go 15 times faster than the cbr125r look at it like the cbr125r top is 80mph that would make a cbr1000 do 1200mph which would just be silly.
****NORTHERN IRELAND NEWSFLASH!!**** According to a recent survey, 94% of loyalists said the best sex they ever had was in the shower; the other 6% haven't been to jail yet.***
Scotty
Scooter Boi
PostPosted: 15:05 - 17 Oct 2004    Post subject: Reply with quote
I'd say alot of cars arn't tunned to make the bhp. more the reliability , saftey and fuel consumption.
Also parts are alot heavier in the engines.
Regards
Scott
Bendy
Mrs Sensible
PostPosted: 15:09 - 17 Oct 2004    Post subject: Reply with quote
Bingo.
If car drivers had to do the amount of servicing that bike owners (certainly sportsbikes) do, they'd have a fit.
loply
PostPosted: 15:25 - 17 Oct 2004    Post subject: Reply with quote
Bike = 160kg
Car = 1500kg
Air resistance skyrockets as your speed increases, as does friction. Hence why the bike doesnt do 600mph or whatever.
The Dude
PostPosted: 15:35 - 17 Oct 2004    Post subject: Reply with quote
I think you've missed the point a little Spiral. I wasn't asking why a 1000cc bike doesn't do 1200mph. Of course thats silly. I was asking what the difference was between a 1000cc car engine and a 1000cc bike engine
loply
PostPosted: 15:57 - 17 Oct 2004    Post subject: Reply with quote
Bike engine has the following advantages:
Ligher parts (more expensive)
Higher stressed parts (servicing more)
Revs higher (noise and fuel and reliability burden)
Sporty power curve (would make cars frustrating to drive)
Generally tuned higher (noisy/revvy/unreliable)
All the above makes the engine a lot more expensive.
Hence why theyre more powerful.
Robby
Dirty Old Man
PostPosted: 16:08 - 17 Oct 2004    Post subject: Reply with quote
Its all to do with the revs.
Bike and car engine can deliver similar torque, in fact the bike can often be making more - Offhand a 4 cyl litre class sports bike should be making about 80 lb/ft of torque, against a 4 cyl litre class small car making about 60 lb/ft of torque AFAIK.
Car engine are in a softer state of tune to last about 4 times as long with service gaps 2 or 3 times that of bikes.
Car engines typically redline at about 6k rpm, whereas bike ones are redlining at around 12-14k now.
Remember torque is not the feeling of low down power - that is quite simply low down power. A twin does not make more torque than a four, it makes similar torque or less, just develops useable power lower down.
Power = torque x revs.
A bike engine also runs dirty compared to a car engine - only now are bikes having to run power robbing catalytic converters with fuel injection, which cars were doing 10 years ago.
Drag is less of a factor because bike drag is awful. The problem is weight and power holding cars back in comparison to bikes.
Spiral
PostPosted: 17:06 - 17 Oct 2004    Post subject: Reply with quote
Nah i was just making the point that 'cc' has very little to do with top end or even acceleration.
and as robby put it its all to do with the revs.
The Dude
PostPosted: 17:31 - 17 Oct 2004    Post subject: Reply with quote
Thanks dudes. Like i said, it was my bother thats been asking.
hugo-a-gogo
PostPosted: 18:33 - 17 Oct 2004    Post subject: Reply with quote
double the power doesn't equal double the speed
the power/speed graph is a curve
you need 4 times the power to double your speed (roughly)
and it's all about the drag and rolling resistance, weight doesn't affect top speed so much, just acceleration
"There are some things nobody needs in this world, and a bright-red, hunch-back, warp-speed 900cc cafe racer is one of them - but I want one anyway, and on some days I actually believe I need one. That is why they are dangerous."
Hunter S Thompson
clicky 4 bikey
Gazdaman
I did a trackday!!!
PostPosted: 19:22 - 17 Oct 2004    Post subject: Reply with quote
I think the inverse square law applies here.
Me being an A level physics student.
https://hyperphysics.phy-astr.gsu.edu/hbase/forces/isq.html
Prof. Gaz
PostPosted: 20:03 - 17 Oct 2004    Post subject: Reply with quote
Very true, and something people forget. Most 2 strokes produce more torque than the equivalent size 4 stroke.
Err, I know where you are coming from but a twin should develope more torque than a 4 as it will have a longer stroke. Longer stroke engines produce more torque.
stryker
PostPosted: 20:25 - 17 Oct 2004    Post subject: Reply with quote
Ever wondered why a 1000cc car engine is so much bigger than a 1000cc bike engine?
One word, "stress". A car engine has to be prepared to lug around 1500kg of car plus say 4 passengers. A bike engine, even on a large bike only pulls around a couple hundred kilos. Hence a car engine has heavier cams, bearings, crank shaft etc.
The materials used and design of your typical family car engine are designed to deliver smooth torque through the rpm range. Sports bikes are designed to carry more torque at the higher range of revs.
Interestingly enough, the reliant robin engine is happy up to 9k revs, at which point the shaft to the dizzy shatters and drops into the engine Shocked The people who race with those engines can do a few mods though to get round that. However the reliant 850cc engine carries a very light car round hence its particularly small size and inherent high rev range.
Now what?
stryker
PostPosted: 20:27 - 17 Oct 2004    Post subject: Reply with quote
Is the short stroke one of the factors that allows for high revs?
Now what?
Jebus
PostPosted: 21:30 - 17 Oct 2004    Post subject: Reply with quote
yeah, bike engines often have very short strokes compared to ccar engines, shorter stokes let engine rev more
Robby
Dirty Old Man
PostPosted: 22:30 - 17 Oct 2004    Post subject: Reply with quote
The limiting factor is piston speed, so a long stroke at 12000 rpm would have to have its pistons moving faster than a short stroke at 12000 rpm.
So yes, shorter stroke = higher revs. Longer stroke = more torque, and more time to burn to more efficient.
The last post was made 21 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 128.2 Kb
