| Matt- |
 Matt- World Chat Champion
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 15:41 - 08 Aug 2012 Post subject: |
I would have thought that if they worked and only cost £15 retail, manufacturers would be putting them on as standard. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| MarJay |
 MarJay But it's British!
| Matt- |
| N cee thirty |
 N cee thirty Banned
 Posted: 15:52 - 08 Aug 2012 Post subject: |
Yamama RXS 100 has the yeis system as standard
https://au.answers.yahoo.com/question/index?qid=20120308175317AAdCQ7B ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:05 - 08 Aug 2012 Post subject: |
Piston ported two strokes, work on the wheeja principle.
In theory they ought NOT work at all.
Think about it, piston rises, and opens hole in the cylinder wall, sucking fuel & air through the carb... but no valves, as piston starts to fall again, the hole in the cylinder wall will still be open...
So whatever got sucked in..... OUGHT to be blown back out!
ONLY thing that makes a piston ported two stroke work, is gas inertia; momentum of gas heading 'in' means it doesn't really want to turn around and come back out, and in the 'lag' of it trying to turn around... you manage to trap a bit before it does!
Other thing is 'reverse flow restriction', basically, long tapering inlet tract, and sharp edged port window at the end, flows easily on the way 'in', but once in the pot, to get back out, it gets 'jammed' in the narrow port opening, and has harder time getting back out than it did getting in, and you can trap a bit 'more' charge in the lag period between it flowing the wrong way!
So the piston ported two strokes, could not use big ports, or there would be no reverse flow restriction; and they couldn't use very wild port timing, limiting how much they could be tuned for perfomance.
Idea behind reed or disc valves is that putting a valve in the inlet tract... once you got charge in the crank-case.... valve stops it getting back out.
This little innovation almost doubled the trapping efficiency of the two stroke, and the power they made in one go..... BUT also aliviating the need to 'port' the engine for reverse flow restriction, allowed bigger ports and more 'agressive' port timing for even more power.
HOWEVER.... the reed valve two-stroke still has 'some' of the properties of the piston ported motor.
Reed valve only opens, or shuts when there is significant pressure difference between the inlet manifold and the crank case, and itself has 'lag' in responding to the change.
Now, on the piston ported two-stroke, one of the problems of setting up the carburation was 'tripple charging'.
As air was sucked into the engine, it would draw fuel up the mixture jets... but, as a proportion of that charge was blown BACK out the engine, it could pass back through the carburettor, and suck even more fuel into the air stream.... then if it hadn't escaped to atmosphere from the carburettor mouth, becouse of a long bell-mouth inlet, air-box or filter.... it double 'charged' air would be sucked back through the carb a third time, picking up even more fuel..... Made carburettor setting rather tricky.
With reed-valve lag, and much shorter inlet tracts modern two-strokes can suffer similar issues......
BUT, if you have an 'expansion bottle' on the inlet manifold, increasing manifold volume, without necesserily increasing manifold length......
Reverse flow can be 'cought' in the expansion bottle, and NOT reverse flow and tripple charge through the carb....
Means carburettor metering can be a lot more accurately tuned...
Also means that the reeds can be bigger and slightly less 'responsive' without loosing benefit.
So WAS a common tuning aid on early reed-valve motors, and Yamaha & I think Suzuki both used it on production bikes at some point.
But on more modern machines with more advanced reed-valves, and probably more 'evolved' inlet tracts.... benefits are possibly more marginal, or the 'principle' is incorporated into the reed-block / inlet port architecture without the need of external volume chamber.... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stevo as b4 |
| keggyhander |
 keggyhander World Chat Champion
| Matt- |
 Posted: 19:10 - 08 Aug 2012 Post subject: |
Thanks Mike
big help and nice explanation! ____________________ RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010 |
| Charlie |
 Charlie World Chat Champion
| ruck bodgers |
 ruck bodgers Trackday Trickster
 Posted: 23:37 - 08 Aug 2012 Post subject: |
i was told they need to be able to expand and compress so have a balloon inside . ..? johnny on a tube to suffice.
maybe a weak spring loaded cylinder thing you could knock up .
lol check this out .
https://www.youtube.com/watch?v=y80MOk3IpSs
| WannaBeDude |
 WannaBeDude World Chat Champion
 Posted: 23:41 - 08 Aug 2012 Post subject: |
Tldr version
The last post was made 13 years, 314 days ago. Instead of replying here, would creating a new thread be more useful? |
