Project no engine!
PostPosted: 22:45 - 08 Aug 2012    Post subject: Project no engine! Reply with quote
With our domination of the cycling in the Olympics I quite fancied a road/race bike.
I remember my dad had a race bike, I had ago about 10-12 years ago crashed it spectaclarly bent it and myself! It has been in the rafters of the garage since
https://img.photobucket.com/albums/v295/chris-red/869cb7bd.jpg
It was up here wedged between the kiddy bikes, it took about an hour to wiggle it out. It was stuck hard I was perched on top of a ladder with 3 motorbikes below me wiggling this this it was an experience! I was more sweaty than I ever will riding it.
https://img.photobucket.com/albums/v295/chris-red/5df970c5.jpg
Here it is in all it's glory the name on the bike is 'Sun Solo' alot of the parts say Rayleigh.
I took all the extras off, as most of them were fucked from the crash, mudgaurds lights etc.
https://img.photobucket.com/albums/v295/chris-red/d18cfc1b.jpg
Looks pretty slick!
The plan is new tires and tubes, new cables and a chain.
Any advice? I've never really worked on push bikes. What sizes do I need for tyres and the chain? Any other bits I should change? Brake blocks?
Both wheels are buckled slightly (it was a pretty big crash Laughing ) any guides on how to fix them something to do with loosening/tightening spokes.
Frost
PostPosted: 23:25 - 08 Aug 2012    Post subject: Reply with quote
Wheels can be straightened, but it might be worth getting some new ones, maybe with some tires already on?
Change the seat, that one looks shit. Soak all the moving bits in diesel for a while then lube them up before use.
f1fan111
PostPosted: 01:53 - 09 Aug 2012    Post subject: Reply with quote
check the sidewalls of the tyres for the size as could be 700c wheels or older style 27 1/4"
MattWadz
PostPosted: 08:22 - 09 Aug 2012    Post subject: Reply with quote
the seatpost might be stuck, ive found that alot with classic roadies, so id check that
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
PostPosted: 09:23 - 09 Aug 2012    Post subject: Reply with quote
All the moving parts seem good, the wheels turn well as does the crank, I'll have it apart to regrease it all anyway, anyone know what tools I need to remove the crank?
I haven't tried moving the seat post yet, that could be interesting!, does anyone have advice for any other special tools I would need?
A local bike shop will true the wheels for £9 each, I might just take it there save me fucking it up.
Alpha-9
PostPosted: 09:34 - 09 Aug 2012    Post subject: Reply with quote
If the seat's not capable of inserting into your anus at least 3 inches you're not a true cyclist.
Fzr-600 1999
PostPosted: 10:07 - 09 Aug 2012    Post subject: Reply with quote
Also this bike used to have a pump hanging off the top rail, it was aluminium with a red white and blue plastic band round part of it and it had a little air tube that came out of the handle and screwed onto the valve and pump.
You can still see how it clamped to the bike with the little brackets hanging from the top bar of the frame, they look factory fit anyone have an idea if I can get a replacement or what to look for?
MattWadz
PostPosted: 12:18 - 09 Aug 2012    Post subject: Reply with quote
chris red, youl need a crank puller probably a square taper to remove the cranks, theyre about 3 pounds from most cycle shops.
Aff
PostPosted: 15:49 - 09 Aug 2012    Post subject: Reply with quote
Looks like a Raleigh Falcon Sun Solo.
Think they had Reynolds 531 frames, if so, not to shabby. Thumbs Up
The problem with working on push bikes is you need a lot of specialised tools, each manufacturer uses their own versions, so if your going to try and remove anything like, BB, cassette or so on, your first going to have to find out what company made them. Then what version they are, so that you can buy the correct tool. Wheels will either be 700C or 650C (will say on the side of the tire), you'll probably want to buy 700/600 x 23C tires.
Electric Bike Project
PostPosted: 09:23 - 10 Aug 2012    Post subject: Reply with quote
The tires are 27" 1 1/4 this doesn't seem to be too common a size. I'll pop out at the weekend to try to find some.
Gonna get a new seat post and saddle and new brake cables tyres and tubes. The Gear cables seem fine and have a nice smooth action.
Anyone know what type of chain I'll need?
https://img.photobucket.com/albums/v295/chris-red/d4c531e9.jpg
Here is the bottom bracket any idea what tools I would need?
PostPosted: 09:28 - 10 Aug 2012    Post subject: Reply with quote
n the effort of getting it down from the garage I have pulled muscles all down my right side back and arm. I'm very sore Laughing
Aff
PostPosted: 10:22 - 10 Aug 2012    Post subject: Reply with quote
I didn't think it was that old. Shocked
Yea you will have to buy 27" x anything tires, you cant really interchange anything with a 27".
How many gears on the cassette? 7? 8? you will have to buy a chain to match.
The bottom bracket looks like an old Cup and Cone, problem is they normally have a fixed cup and an adjustable cup, the left is normally adjustable and can be removed with a C Spanner and sometimes a pin spanner as well. However the fixed side usually needs some elaborate overpriced tool, these were sold to bike shops forcing people to pay to have the BB removed and installed. There are a few ways to bodge your own tools, there are some guide on the interwebs.
PostPosted: 11:00 - 10 Aug 2012    Post subject: Reply with quote
5 on the back 2 on the front. Will I need a 5 speed chain or will a 6/7 one work?
Aff
PostPosted: 11:03 - 10 Aug 2012    Post subject: Reply with quote
Yea pretty much anything below a 9 speed chain will work on a 5 speed. Get the lowest number you can as it will be stronger and last longer. 6 speed will be fine, 5's can be hard to find.
PostPosted: 11:07 - 10 Aug 2012    Post subject: Reply with quote
Is there pitch to worry about or are they all standard?
Aff
PostPosted: 12:06 - 10 Aug 2012    Post subject: Reply with quote
Pitch should be standard unless its some really obscure drivetrain, all that changes with the different speed chains is the width.
PostPosted: 17:07 - 15 Aug 2012    Post subject: Reply with quote
Have been slack updating this, I managed to true the front wheel reasonably wheel however the rear is proving very difficult, thinking of just taking to to a pro.
I have a chain on and gears set up front tyre on too, and a new saddle/seatpost. I have regreased the front wheel bearings and set it right.
I bought this which i think is amazing value. Really steadily built and fast delivery very impressed with it for the money. I would recomend it to anyone even for doing really minor work on a bike it makes it much easier.
https://img.photobucket.com/albums/v295/chris-red/B86DD780-2C8C-4D84-9AFE-14A85DC2A1D1-29700-00001B7EACB5AC1A.jpg
https://img.photobucket.com/albums/v295/chris-red/5B5C42F3-0BCD-48D1-96AE-C37EFFD77B68-29700-00001B7EA09A5468.jpg
All thats left to do is true the rear wheel replace the brake cables and wrap the bars Very Happy
400bandit
PostPosted: 19:45 - 15 Aug 2012    Post subject: Reply with quote
Looking tidy mate!
daverwheeler
PostPosted: 20:27 - 15 Aug 2012    Post subject: Reply with quote
I still think you ought rig a little 50cc motor on there somewhere, just to help with the hills.....
PostPosted: 09:43 - 16 Aug 2012    Post subject: Reply with quote
With a bit of training I should be able to whoop a 50cc on this. Cool
Timmeh
PostPosted: 10:19 - 16 Aug 2012    Post subject: Reply with quote
Soichiro Honda started out like that.
Mr Krispy
PostPosted: 15:53 - 16 Aug 2012    Post subject: Reply with quote
I used this type of removal tool. Can't vouch for the site though.
https://www.suntekstore.co.uk/goods.php?id=13002419&utm_source=gbuk
PostPosted: 09:48 - 14 Sep 2012    Post subject: Reply with quote
Me again,
I bought some new brakes for this as suggested by Stinkwheel I bought some double pivot Shimano Sora brakes. However they do not fit. The Rear is about 5-10mm too short on the calliper arms meaning the brakes rub bearly in the rim and on the tyre. The front's bolt that attaches to the frame is tiny, like 20mm whereas the existing brakes have a bolt about 60-70mm long.
Do they still sell modern brakes that are this fittment and what is it, also does anyone want a pair of Shimano Sora brakes Laughing
As for the rest of it I just need to replace all cables and sort the brakes out now. The rear wheel is true (ish) I took it for the maid voyage and snapped a gear cable So I will be replacing the lot.
PostPosted: 12:50 - 21 Sep 2012    Post subject: Reply with quote
All done!
Yet to give it a decent ride yet but it seems good.
https://sphotos-h.ak.fbcdn.net/hphotos-ak-ash3/45337_10151156313668476_1735380488_n.jpg
This could be moved to the new forum Thumbs Up
janner_10
PostPosted: 19:20 - 21 Sep 2012    Post subject: Reply with quote
I was chuffed to bits when I got my first racer for Christmas aged 14. Don't know about the rest of the country, but the fashion round here was to turn the handlebars up the other way.
The last post was made 14 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 132.75 Kb
