council garage
RichieZX6R
PostPosted: 11:59 - 09 Aug 2012    Post subject: council garage Reply with quote
Hi,
Just wondering if any one has any experience with them that they can pass on? I've got an opportunity to hire one for £5 a week. Its about a 3 min walk from home (no real space for a motorcycle apart from side of house) and its got maybe 6 garages either side and its a dead end. Seems reasonably quite but if any one see's me taking a 636 to it may that change?
Just wondering if any one else keeps a motorcycle garaged away from the home.
Guess it comes down to the whole, will it be safe cos i cant see it thing!
Thanks for any feedback in advance!
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
Ichy
PostPosted: 12:02 - 09 Aug 2012    Post subject: Reply with quote
Not something that I would be too keen on. When I lived in Birmingham it was quite common to see garages with the door torn off. If you go overboard with security then you are pointing out that something interesting is in there. In your case it may be a better area but the only person who is interested in protecting the contents is 3 minutes walk away.
mfactor
PostPosted: 12:06 - 09 Aug 2012    Post subject: Reply with quote
I had one for a while , but in a real quiet area and to access it you had to walk down a side road past a dozen off my neighbours houses and you would find a few of us down there in the summer, all on nodding terms.
Very handy but go on the area
fatjames
I've got one, but it's in a locked compound. Someone was telling me that you can get cheap alarm that will text you if you have a break in. You can also use a ground anchor and a decent sized lock in a garage.
It gives me somewhere to do my servicing / repairs etc which I'd have to go roadside otherwise.
£5 a week is quite cheap, in Bristol they're a fair bit more than that!
HTH
RichieZX6R
PostPosted: 12:22 - 09 Aug 2012    Post subject: Reply with quote
thanks for the replies guys! The alarm that texts you is a good idea! I like the idea that i can do my servicing etc in the dry. Do they have electricity?
I was going to take the tyres off this weekend to get them changed by if i cant move the bike i cant get the bin's past and the misses complains!
Also yeah its a great price. Really not bad at all. Might ask for the one with the most internal security! ha
Attached a quick map of the garages (hopefully this doesn't give too much away!).
nowhere.elysium
The Pork Lord
PostPosted: 12:29 - 09 Aug 2012    Post subject: Reply with quote
Mine's been fine for the past couple of years. Don't make the security too obvious - two slide bolts with padlocks should be more than enough. I would say that if you're in a particularly rough area that filling something large with concrete and chaining the bike(s) to that would make the most sense, though - it's not immediately visible, and it does mean that they're less likely to get away with your stuff.
mfactor
No electric in council ones, buy a generator Very Happy
fatjames
It wont have power. I recently bought a petrol generator from aldi for £60 and I've just hooked up some lights and stuck a socket on the wall. It's quite loud though, so I'm looking at getting some super big batteries and running them from that instead.
RichieZX6R
PostPosted: 12:36 - 09 Aug 2012    Post subject: Reply with quote
bolts sound good. Also would get the old man to make up some sort of anchor for the wall. Didn't realise about the power but it shouldn't be a massive problem. Only for sort of oil changes and storage anyways. Dont wana loose the 636 a few weeks after buying it!
PostPosted: 12:39 - 09 Aug 2012    Post subject: Reply with quote
I thought three slide bolts with padlocks would be enough, but turns out they can have the 'ears' bolt cropped off easily... Sad
RichieZX6R
PostPosted: 12:45 - 09 Aug 2012    Post subject: Reply with quote
Ar, do me mean a lock that is hopped? thats the usual that we use round here Sad
Flying Tiger
PostPosted: 12:49 - 09 Aug 2012    Post subject: Reply with quote
I keep a few bikes in a council garage, inside i've put a motion sensor alarm (just remember to de-activate it when you go in!) This is on the back wall, and it cant be got to to be smashed off. Also the bikes are chained together.
Also fitted a 'Garage defender' a the bottom of the door, as already mentioned sometimes security like this can make it obvious there is something of value inside, but again as mentioned take into account the area.
Joncrete Cungle
PostPosted: 12:50 - 09 Aug 2012    Post subject: Reply with quote
I am thinking of renting a garage 2 mins from the good ladys abode from a housing association. An old wheelie bin filled with concrete, hardcore & bits of metal should suffice as a ground anchor. I am on the lookout for something like a second hand gas cylinder cage but cheaper and stronger. If big enough to keep the bike in, or secure any tools &/or kit that may be left in side.
PostPosted: 12:52 - 09 Aug 2012    Post subject: Reply with quote
No, as far as I know they didn't damage the 'uncroppable' padlocks i bought, they just removed the sticky out bit that the padlock locks onto, and removed the bolts...
Nick 50
PostPosted: 14:04 - 09 Aug 2012    Post subject: Reply with quote
I've got one too, which is in a locked compound of about 15 garages.
Not had any issues.
When I rang the housing association up they had 2 garages free so told me to come down and pick the keys up and choose which one I wanted. By the time I got down there a 3rd had become available. Picked up 3 sets of keys and went and had a look.
The 3rd garage that just came up was the last one I looked in. Opening up I spotted the poster of Lucy Pinder on the wall and then got even better when I spotted 2 ground anchors bolted to the floor at the back. Razz
Speaking to a few of the other garage owners, my garage was rented previously by a bloke with bikes too.
RichieZX6R
PostPosted: 15:17 - 09 Aug 2012    Post subject: Reply with quote
so they let you look round all the free ones? I'm yet to go and look at them so i'll see if i can pick the best one!
Thanks for the advice lads!
Nick 50
PostPosted: 15:55 - 09 Aug 2012    Post subject: Reply with quote
Yep, they gave me 3 sets of keys and just said to have a look, then go back down with my choice and sign the paperwork and hand the other 2 set of keys back.
Noxious89123
PostPosted: 16:20 - 09 Aug 2012    Post subject: Reply with quote
Fucking hell!
If I were in that position, and a scumbag, I'd have just got copies of the keys cut!
stevo as b4
PostPosted: 18:00 - 09 Aug 2012    Post subject: Reply with quote
Get the door lock changed from day one as a precaution, and use decent locks chains, to secure your bike to an internal ground anchor, preferably a concreted in one, but a decent tamper proof bolt down version should be nearly as good too.
If your 3mins away, a std alarm is pointless, but internal CCTV or cleverly concealed external CCTV would be worth having, but the problem is powering it. If your going to be doing much work in there then id use a couple of decent Leisure batteries, and make up a trolley for them so that you can lug them home to re-charge as required.
Oh and seeing as you've already got the generator, then you could look into building it a proper wood clad soundproofed enclousure, like they do for air compressor's etc. You should with a bit of effort be able to quieten it down by a noticable amount. Obviously youd need to provide through the wall some sort of exhaust and intake ducting, but i don't see it being a big problem or require big holes in the wall for a small generator either.
_mjs_
PostPosted: 20:33 - 09 Aug 2012    Post subject: Reply with quote
Another bit of advice; check it doesn't leak! Even the least bit of dampness will soon mank your bike up... tell the council to get any leaks sorted BEFORE you sign the tenancy agreement. Chasing it up after will inevitably result in finding your rent money has already been spent on jenkem and mud-pies for council estate scruffbags.
RichieZX6R
PostPosted: 20:37 - 09 Aug 2012    Post subject: Reply with quote
Some brilliant replies here! Never thought of the leak problems will look into that!
Thanks for the replies everyone! It's all helped keep my pride and joy safe! Thanks again.
Pie-Roe
PostPosted: 22:05 - 09 Aug 2012    Post subject: Reply with quote
I rent a council garage in a relatively nice student city (Canterbury) so can't really comment on crime rates and whatnot.
I just put two normal door locks on the bottom corners of the garage that open with the same key, so it can't just be kicked in at the middle.
Bikes are with steering lock. Have a couple ground anchors which I should use I guess.
fatjames
PostPosted: 10:48 - 10 Aug 2012    Post subject: Reply with quote
Any got any more views on this? After setting up my lights and power sockets to run from a gennerator I've quickly realised it's way too loud. It's quoted as 94db, but sounds louder. It's a 2t and sounds like a scrambler!
DMCpro
PostPosted: 12:37 - 10 Aug 2012    Post subject: Reply with quote
I know the one you have. the 94db is when its not under load... (not using anything - just idleing) you could make a baffle for the exhaust?
Honda CB-1, TS125X
VW Golf Estate
J.M.
PostPosted: 13:36 - 10 Aug 2012    Post subject: Reply with quote
Gave enough away for me to find the garage on Google Maps.
<take_advice_with_a_pinch_of_salt>
It looks like an okay area to my untrained eye however. You can do most of the journey on the main road where there may be scrotes hanging about and then quickly divert off the road until you reach the garage. Riding in, you'll be out of sight in seconds. Engine off, open garage, push bike in. Enterance doesn't look like somewhere I would imagine scrotes to hang out, so if they see you on the main road they'll have no idea if you're in the garages or in one of the houses. I'd just be worried if you start seeing scrotes loitering around the enterance after you've been there a while.
</take_advice_with_a_pinch_of_salt>
I wouldn't feel happy having my bike any distance away from me really, but then it's a case of whether you think it'll be safer in the garage.
I think an alarm that could alert you is a pretty good idea. If the bike is 3 mins away and you've got more than 3 mins worth of locks, you'll catch the scrotes red handed.
Old car batteries and motorcycle batteries can be handy to keep around. If you connect them all up you could probably get lighing for a while. They could be connected up to be charging whilst the generator is on too; that way you could have light at night for a few hours without annoying the resedential houses around the garage.
2004 R1 & 2018 XSR900
The last post was made 13 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 135.75 Kb
