| smegbrains |
 smegbrains Scooby Slapper
 Posted: 17:03 - 11 Aug 2012 Post subject: Should I take this back...? |
I'm sure I must be a brilliant customer as usually I'm far too English to haggle or complain, but this time I'm sorely tempted to actually say something as I'm really unhappy.
I took the bike ('99 CBR600F) into a local garage for a service, a new tyre fitting, and also asked while it was in there if they could have a go at fitting my pillion footpegs for me. The previous owner had taken them off to fit the non-standard can. I wanted to keep the can on as I love the sound it makes, but I'd also like the ability to take a passenger.
I'd had a quick go at trying to get them on myself but couldn't quite make it fit (I assume as the can is in a different position) so it wasn't going on for me.
There are three securing points, and while I could get the top two load-bearing ones in place, the third one at the bottom (where the OEM can attached to hang from I guess) was in the way. I thought I'd get someone with a bit more mechanical ability than me to have a go while they had the bike, assuming I might have been a bit of an idiot and missed something obvious. When I dropped the bike off I asked for them to try and fit these for me, and if not let me know so I could see how much getting some aftermarket or fabricated ones would be.
When I got the bike back they pointed out a couple of things I needed doing (small hole in collector box and cam chain tensioner) so we had a chat about that. I noticed the pegs were fitted and was pleased they'd managed to do it but we didn't discuss them. Paid up my money and rode off.
Went to pick my friend up the following day as he'd volunteered to be my first pillion, and he had a closer look at the pegs. I noticed that the bottom attachment point had been cut off, and the peg was pressed forcefully against the exhaust, bending it out of position and marking the can quite deeply under the sharp edge left from cutting. I was a bit narked about the peg being cut as I hadn't expected anything drastic like this without a phonecall asking me if it was OK first, at which I'd have said no because I want the original kit kept in good order - I've got the original can and carb jets etc so I can put the bike back to standard if I need to for selling it.
I've included a couple of pictures below which should hopefully illustrate it, you can see how it's forcing the can out of position on one of them, and the close up one should show the damage. Do you think I have something to reasonably complain about here, and what would be a reasonable outcome from a complaint? I don't expect the moon on a stick, a million pounds compo and a ride on his wife or anything, but I'm quite a bit put out as if I take the peg off now, there will be deep scratches on my can, and if I leave it I can see it wearing a hole into the can over time.
Thanks for your opinions
https://dl.dropbox.com/u/12188210/zorst.jpg
https://dl.dropbox.com/u/12188210/zorst1.jpg ____________________ Current Bike: Honda CBR 600F
Ex Bikes: Suzuki GX 125 |
| MarJay |
 MarJay But it's British!
 Posted: 17:09 - 11 Aug 2012 Post subject: |
Hang on, you asked them to fit pillion pegs when the exhaust is incompatible with pillion peg usage, and you're upset when it doesn't quite fit properly? If I were you, I'd remove the peg, grind a bit off of the back of the peg hanger, remove the exhaust, move the exhaust clamp to the inside of the mounting and try to tighten it all up shifted over a bit.
I wouldn't have asked a garage to do this, Its like asking someone for the impossible...
Its not great work, and they shouldn't have taken it on IMO, or they should have shimmed out the peg so it gave extra room for the exhaust. Even so, what you asked them to do is dubious... ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| smegbrains |
 Posted: 17:18 - 11 Aug 2012 Post subject: |
| MarJay wrote: | Hang on, you asked them to fit pillion pegs when the exhaust is incompatible with pillion peg usage, and you're upset when it doesn't quite fit properly? If I were you, I'd remove the peg, grind a bit off of the back of the peg hanger, remove the exhaust, move the exhaust clamp to the inside of the mounting and try to tighten it all up shifted over a bit.
Its not great work, and they shouldn't have taken it on IMO, or they should have shimmed out the peg so it gave extra room for the exhaust. Even so, what you asked them to do is dubious... |
Thanks, this is the sort of criticism and questioning I was after.
The intention behind me asking was to see if I'd missed something obvious, my fitting attempt was really limited to getting the peg out of the box of spare bits I'd been given and seeing if I could mate it all up in line with the holes, which I couldn't. The guy I bought it off said he thought it might go on but he never took pillions so had never bothered.
I explained to the garage I wasn't sure it would fit, and if I had to get one fabricated I would, but could they look and see if I'd been doing it wrong.
EDIT:
I'm not upset about it not fitting perfectly, just that it's causing damage. I would try grinding it back, but I don't have access to the tools or ability to use them without losing fingers. ____________________ Current Bike: Honda CBR 600F
| fozzym |
 fozzym Brolly Dolly
| Pete. |
 Pete. Super Spammer
 Posted: 17:22 - 11 Aug 2012 Post subject: |
They did what you asked, perhaps they should have phoned and mentioned that they needed to cut the hanger but if you didn't tell them that you needed to keep the exhaust mount intact I think your complaint will fall on deaf ears.
I agree with the issue about it digging into the can. I would have filed a flat on that sharp angle of the hanger to stop it digging it - as it is, where it is touching it's going to make for a very uncomfortable ride for any pillion because it will be transferring vibration from the can directly into the footpeg. Only way I can see out of that is to either move the can inboard as Marjay says or move the hanger outwards by packing the mount with spacers or heating & bending it. ____________________ a.k.a 'Geri'
| Ayrton |
 Ayrton World Chat Champion
| smegbrains |
| janner_10 |
 janner_10 World Chat Champion
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| smegbrains |
| el_oso |
 el_oso World Chat Champion
| smegbrains |
| swiftb |
 swiftb World Chat Champion
| Barnaby |
 Barnaby Banned
| Ayrton |
| robbyb |
 robbyb Scooby Slapper
| smegbrains |
| pendulum |
 pendulum Traffic Copper
| stinkwheel |
| Alex_B |
 Alex_B Brolly Dolly
 Posted: 14:58 - 12 Aug 2012 Post subject: |
Yea well.
As you say the exhaust can is going to be so FUBAR'd in a lil while. You are gonna have a nasty blow to put it mildly.
They shoulda asked, customers ask for shit and naively (maybe) expect the garage to do things a bit better than they could themselves or they wouldn't be fecking paying.
If I want a bodge job,I can do that myself
It's a bodge, take it back and give em some grief, can't hurt none!! ____________________ My Lane Position is always AWESOME!! |
The last post was made 13 years, 236 days ago. Instead of replying here, would creating a new thread be more useful? |
