Petrol Resistant Lacquer - Dog shit
binge
Emo Kiddy
PostPosted: 17:30 - 12 Aug 2012    Post subject: Petrol Resistant Lacquer - Dog shit Reply with quote
Has anybody had any experience with painting using the petrol resistant stuff from Halfords Retail store?
Reason I ask, is because I painted my Chaly last week, and then decided to throw a bit of petrol resistant stuff around the tank.
It just turned into a cloudy white orange peel. Even when applied super thin.
So I rubbed it back, and just painted in blue, and used standard lacquer again.
I dont have an issue getting a fantastic finish with standard stuff.
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-prn1/s720x720/528755_10151074529130606_1391068969_n.jpg
Then I started to set the carb up, and splashed a load of petrol onto the frame around the carb. It fucked the paint right up.
So engine out, rub down, and re-paint.
Decided to have another go with the petrol resistant stuff, straight onto the fresh blue paint.
It went on fine, but it's dried really dull and flat. Looks like it has the original 1987 paint job on it again. Laughing
So how do I get rid of this?
Can it be brought back to life? Or is there a knack to applying this petrol resistant stuff?
Ta
Ben
The Artist
PostPosted: 17:33 - 12 Aug 2012    Post subject: Reply with quote
Yeh I used to use it all the time painting petrol tanks.
Key for me was lots of thin layers in hot weather. I was painting over gloss black.
Still wasn't very good but worked better than standard lacquer.
Like this but that one I used to use was green.
https://washford.scene7.com/is/image/Washford/768697?$prod$
Teflon-Mike
tl;dr
PostPosted: 18:02 - 12 Aug 2012    Post subject: Reply with quote
That Halfords Petrol Proof is nasty stuff.
Its not even petrol proof!
Petrol 'resistant' for a minute may-be, but sure as feck not 'proof'!
And yes, had it turn some colour coats milky.
https://i178.photobucket.com/albums/w269/teflons-torque/030_035_Yamaha_DT/imag2464.jpg
Pissed off with non-petrol-proof when I did the DT, I had a word with my localk freindly paint shop.
2-Pack in a Rattle Can!
Went over yellow (not metalic) celulose great. And IS petrol proof!
Expensive though, (£15 for 150ml can!)
And you get ONE shot... soon as whats on tank is hard, so is whats left in tin!
You have to be careful laying it on, too, becouse without solvent, what goes on stays on, and it rund easily if you put it on too heavy.
_matt
PostPosted: 08:36 - 13 Aug 2012    Post subject: Reply with quote
as above.
Halfords spray on stuff was fine, emptied the full can in 10 thin layers over an hour on a hot day. looks... alright, nothing special
isn't petrol "proof" for shit tho! seems resistant to splashes etc in any case
1990 Yamaha XV 535 (Alive Again!) / 2007 Jinlun Texan 125-11 (formerly 2k3, wrong details, now going rusty in the back garden )
binge
Emo Kiddy
PostPosted: 12:14 - 13 Aug 2012    Post subject: Reply with quote
In which case, I may as well just key it, blow it back over with blue paint, then lacquer it with the standard stuff again.
Then just be careful not to spill petrol on it.
It looks like it's been painted with a crayon at the moment.
Lone-Wolf
PostPosted: 15:54 - 13 Aug 2012    Post subject: Reply with quote
Wotcha.
Yep - I used Halfords petrol resistant lacquer. Stuff started crazing all over the place . . . . .then I read the tin.
No more than three coats, within a one hour "over coating" window.
Use it like that, and it works fine.
Moral of the story ?
Read the bloody tin first Embarassed
Cheers.
L.W. - www.moonshiners.org.uk
U_W v2.0
PostPosted: 16:23 - 13 Aug 2012    Post subject: Reply with quote
add Hycote petrol resistant lacquer to the shit list as well!
seriously, multiple decent coats and a little petrol spill and CAPOW! fucked up paint work.
hycote etching primer,
hycote polar white color coat
hycote petrol resist lacquer
and it made 0 freaking difference, still utter shit
AVOID!
binge
Emo Kiddy
PostPosted: 17:23 - 13 Aug 2012    Post subject: Reply with quote
I might just book the frame in for spraying professionally now I've got all my additional parts painted.
The reason I didnt get it sprayed pro to start with was because I have been undecided on so many things.
Just a shame because I can get an absolutely perfect finish with the blue paint in a tin, even with regular lacquer, it looks spot on.
But just not resistant to petrol. Sad
PostPosted: 17:48 - 14 Aug 2012    Post subject: Reply with quote
You know that rattle can lacquer takes weeks to cure, right? It's not going to resist so much as a hard stare until then.
mentalboy
PostPosted: 18:06 - 14 Aug 2012    Post subject: Reply with quote
It's not just rattle can lacquer that takes ages to cure. when it gets sprayed on here we've got about a two week window to polish it up, it's an absolute nightmare trying to polish the stuff when the item's been thrown in the corner and we come to polish it months later!
With the new stuff you have to avoid fingernails, bumps and solvents for ages, Id be surprised if it was any different for petrol resistant canned stuff.
Make mine a Corona.
binge
Emo Kiddy
PostPosted: 22:17 - 14 Aug 2012    Post subject: Reply with quote
I'm not expecting it to be resistant straight away. That isnt my problem.
My problem is, that as soon as I spray it on, no matter what method I use. It clouds up straight away, making the paint job look dog shit.
I've rubbed the affected area back now, and re-painted with standard paint and lacquer.
Will just have to be extra careful. Cant be arsed fucking it up again.
Might look out for some of that 2k stuff.
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/432168_10151095428040606_1471254588_n.jpg
Shaft
PostPosted: 23:28 - 14 Aug 2012    Post subject: Reply with quote
Sounds like you're using cellulose; takes a fortnight to cure, then dries so hard, you could flat it with a brick and not leave much of an impression.
You need to get into modern paints; I started with a primered repair this morning, had it based, lacquered, flatted and polished by lunchtime.
Frost
PostPosted: 00:19 - 15 Aug 2012    Post subject: Reply with quote
I've battled with the halfrauds stuff too, but i got it to work in the end.
Everything must be super dry including the humidity or it goes milky. The milkyness does disappear after 24h though.
The petrol resistance doesn't seem to kick in for at least a week. Flatting things down after a week, then applying wax also helps a great deal as it means the petrol beads up and rolls off rather than sitting on the paint. It's still only splash proof though, soak something in fuel and it'll dissolve.
PostPosted: 07:18 - 15 Aug 2012    Post subject: Reply with quote
That sounds like good advice. I got OK results from the Halfrauds stuff but in hot, dry weather, and applied as per the instructions. It ran like a French soldier though.
mentalboy
PostPosted: 08:17 - 15 Aug 2012    Post subject: Reply with quote
I couldn't tell you, my mate does the spraying, I'm more into the mechanicals. I know that it's solvent based, rarely 2k, and that he uses primer, basecoat and clearcoat lacquer whenever he can.
Judging by the stink of the cleaning solvent I'd say it's cellulose (definitely not Acetone!)
I know the primer and base go off pretty quick but we can't go near the lacquer with a polisher for at least twenty four hours
Have you gone down the waterbased route like our U.S friends?
Make mine a Corona.
Shaft
PostPosted: 20:08 - 15 Aug 2012    Post subject: Reply with quote
Yup, we've been compliant for quite a while now, we do so much insurance work, we couldn't really avoid it.
To be honest, it cost a fair bit to swap everything to HVLP and we were a little bit wary of aquabase, but after a couple of early teething troubles around thinning ratios, it was worth it.
We still occasionally use 2K, mainly for repairs on older cars (we do a lot of classics) but it's getting to be less and less.
mentalboy
PostPosted: 22:13 - 15 Aug 2012    Post subject: Reply with quote
I'm sure all the guns that we have are HVLP, regulator set low enough not to fill a bike tyre! Have to check it out.
Water based paints much cheaper?
Make mine a Corona.
Shaft
PostPosted: 23:00 - 15 Aug 2012    Post subject: Reply with quote
For us, yes, but only because we've found that there isn't so much variance in quality between the different brands of aquabase.
When we used exclusively 2K, we stuck with ICI, because the colour was always right and it went on and polished up easily, unlike some other brands we tried, so we were always paying top dollar, for a top brand.
Now, we've done some experiments, we're confident in using a cheaper brand and haven't had any colour or application problems.
mentalboy
PostPosted: 19:17 - 16 Aug 2012    Post subject: Reply with quote
It would appear that our guns are LVLP, presumably this still works with aquabased paint?
Make mine a Corona.
Shaft
PostPosted: 22:17 - 16 Aug 2012    Post subject: Reply with quote
I can't see why they wouldn't, but I would check with your paint supplier.
mentalboy
PostPosted: 14:21 - 17 Aug 2012    Post subject: Reply with quote
We've just had this come in. Not a self do job, only done 3 or 4 months ago. Paint peeling off and when we removed the warning sticker (which owner was told had been put in different place to original because it looked better) we find it's been used to cover up where the monkey sanded through the lacquer - that smudge just behind the hinge.
Owner was told by the paint shop that if he wanted the tank resprayed properly to rectify their peeling paint it'd cost him again!
Looks like two different primers used, one of which has let go from the bare metal.
This is the second job we've had in recently from other places that have done a slap dash job - so if you want a paint job done properly make sure it's from a reputable (preferably recommended)sprayer.
https://i1174.photobucket.com/albums/r601/mentalboy1/P8170190.jpg
Make mine a Corona.
Shaft
PostPosted: 01:04 - 18 Aug 2012    Post subject: Reply with quote
TBF, that's a bloody awful picture, so it's a bit hard to see what's going on, apart from there's far too much material on there and it hasn't been taken far enough up the filler neck.
I'm also a bit wary of slagging off other painters, because you'll never know what they were actually asked to do; in my experience, the vast majority of punters haven't the first idea what the cost of a quality paint job is and, even worse, they've always got a mate/work colleague/bloke down the pub, that has clued them in, so they know what needs to be done, regardless of what the painter has advised them.
Some people will just go ahead and do whatever the customer asks for, which is fair enough, but it sometimes ends up in someone else putting it right, when it was really the fault of the customer.
The last post was made 14 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 137.55 Kb
