Head shaking...
gorillaonabik...
PostPosted: 19:35 - 13 Aug 2012    Post subject: Head shaking... Reply with quote
OK, this is a weird one. I have a bit of a head shake between 25mph and 50mph. When I let go of the handlebars, the head shakes almost to the stage where a tank slapper could be imminent. Before and after, it is perfectly smooth, even when I take my hands off the bars at 80mph.
This is a CB1300, clean history, almost all the history is there, last two services done by a main Honda dealer.
Anyone experienced this? Is this just a CB1300 thing?
FZR400 (blown engine), ZXR750 (blown engine), ZX6R (accident), CBR600 which had engine issues after which I learned to change gear..., CBR900, CBR924 (stolen), CB600, CB1300 (everything blew up), BMW K1300GT (written off, hit from rear while stationary), Bandit 1250 for a couple of months, Triumph Sprint ST 1050 (nicked) and somewhere in there, I wrote off a Ducati 748 at Cadwell.
lihp
PostPosted: 19:38 - 13 Aug 2012    Post subject: Reply with quote
get wheel balancing checked
MarkJ
PostPosted: 19:43 - 13 Aug 2012    Post subject: Reply with quote
Also might be worth checking to see if the head bearings are ok.
goto10
PostPosted: 19:49 - 13 Aug 2012    Post subject: Reply with quote
I had a similar problem, turned out to be the tyre (irritatingly there was also plenty of tread left, but something failed in the tyre's structure) - new tyre fixed it.
The advice I had was to check tyre, head bearings and wheel balance.
iooi
PostPosted: 19:52 - 13 Aug 2012    Post subject: Reply with quote
Top box ? Panniers ?
Mikey3
PostPosted: 19:54 - 13 Aug 2012    Post subject: Reply with quote
I've thought this, of my two hornets (I took the front wheel and tyre off the old one) and both had a headshake on certain roads at certain speeds, I'm getting a new tyre at the weekend so perhaps this will solve that issue.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
anthony_r6
PostPosted: 20:59 - 13 Aug 2012    Post subject: Reply with quote
I've literally just had this issue resolved. Mine was a missing engine mounting bolt. I've been dealing with it for about 2months. Whenever I let go of the handlebars it wobbles, then it gets worse and worse. First time I saw it happen that apparent I almost let it bang from side to side because I was in utter disbelief at how bad it had got.
I also found it was very very wobbly at Motorway Speeds. But yes, check your mounting points.
Suntan Sid
PostPosted: 22:11 - 13 Aug 2012    Post subject: Reply with quote
Had exactly the same problem on my CBR600.
First thing I checked was the head bearings, didn't need to look any further than the castle nut, it wasn't even finger tight! Shocked
Nipped it up and that cured the problem.
The last post was made 14 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 55.91 Kb
