| MarJay |
 MarJay But it's British!
 Posted: 16:44 - 18 Oct 2004 Post subject: Steering Head Bearings - Renewal |
Hi people,
Does anyone have any hints or tips on Steering head bearing renewal? I'm just about to attempt it for the first time on the TT.
I have removed the top ball race and the outer race from the lower taper roller bearing. I need to pull the inner race from the steering stem.
I realise that I will have to use a drift to replace the Bearings, and I have a suitable one made of some soft composite stuff.
What I really really need to know is, where do I grease, what sort of grease should I use, and how much grease should I use?
I'm going to try the 'leave the outer race in the freezer' trick on the bottom bearing. Good old Haynes manual!
Any other hints appreciated!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
 Posted: 18:24 - 18 Oct 2004 Post subject: |
So you have managed to get the bottom race out of the headstock then? If not, my top tip is to get someone with a welder to run a ring of weld in a circle round the inside, this makes it contract as the weld cools and a sharp tap with a drift against the lip of weld either makes it drop out or shatter to bits.
I use Molybdenum disulphide grease (the black stuff) as this is a high-load, low movement application, put it on the actual bearings, as much as you can fit.
If you get a big bit of threaded bar (M10) you can put it through the headstock and use the old races to pull the new ones in with the assistance of a couple of nuts and a big washer. Just wind them in with a spanner. Saves a lot of hammering and swearing.
Don't do so many wheelies next time  ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MarJay |
 Posted: 19:16 - 18 Oct 2004 Post subject: |
My main problem is pulling the old steering race from the steering stem. Thats the last part I need to remove.
Putting the new ones in shouldn't be too much of an issue - I have a lovely steering stem sized drift that should do the job.
The main trouble I have is that there is a rubber gaiter around the old inner race on the steering stem. This does not come with the new bearing. This means I have to remove the old bearing without damaging the gaiter. what I really need is a bearing puller. Unfortunately I don't have one.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Robby |
 Robby Dirty Old Man
| MarJay |
 Posted: 22:17 - 18 Oct 2004 Post subject: |
The bearings are pattern ones, but they are the same make and model as the 'official Triumph ones'. They just cost half the price!
The original top race said it was made in poland and the bottom race made by a japanese company. Both of the new bearings are made by the same Japanese company as the original bottom race.
The trouble is, the new pattern bearings don't come with a seal!
Raaaaagggghhhh!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
 Posted: 22:29 - 18 Oct 2004 Post subject: |
I am sure a new seal doesn't cost all that much, trumpet parts aren't all that expensive. Then you can roast the hell out of the old one with a blowlamp to get it off. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Big Pete |
 Big Pete Spanner Monkey
| Big Pete |
| MarJay |
| Git |
 Git Brolly Dolly
The last post was made 22 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
