Problems already...
Speed
PostPosted: 21:54 - 13 Aug 2012    Post subject: Problems already... Reply with quote
Hey everyone, only had the bike a couple of days and it's already let me down... The engine has started to idle roughly and when revs are applied it dies. It then struggles to start, if at all. I noticed as i was going down the gears, pulling the clutch in, the revs would drop and cut out. I'd only been on the bike 5 minutes and noticed the pipes to the radiator were extremely hot but the engine was cold to the touch. Anyone have any ideas that i could try before i get financially raped at a garage? Its a 1997 ZX6R F3. Cheers
Spudda
PostPosted: 21:58 - 13 Aug 2012    Post subject: Reply with quote
I'm guessing youve checked all of the fluids ??
Coolant, Oil, Water etc
It's Nice To Be Important BUT Its Important To Be Nice ©
www.tankslap.co.uk
Triumph Daytona 650 Union Jack Nose Cone.Metzeler M5's.Carbon Bling.ASV Levers.LED Adapted Rear.LED Adapted Indicators.RIM Tape.PiperCross Filter. Smoked Aero Screen.Harris Hanger.Carbon Wrap.Renthal Sprockets.Coded Chain Guard.Shortened Carbon Can
Speed
PostPosted: 22:00 - 13 Aug 2012    Post subject: Reply with quote
I have mate, everything is topped up etc.
Spudda
PostPosted: 22:06 - 13 Aug 2012    Post subject: Reply with quote
Starved of fuel ??
Either a kink or a blockage in a fuel line ??
www.tankslap.co.uk
Speed
PostPosted: 22:39 - 13 Aug 2012    Post subject: Reply with quote
No blockages or kinks mate. I did notice that as the revs dropped, so did the lights on the dash. Could it be a battery issue?
monkeyman
PostPosted: 22:45 - 13 Aug 2012    Post subject: Reply with quote
Before worrying about fueling, I would investigate radiator problem. It may be nothing though, best to check though. Sounds like the thermostat or water pump could be faulty. Did you touch both the top and bottom of the radiator a significant difference in temp indicates a problem.
Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750
Speed
PostPosted: 22:53 - 13 Aug 2012    Post subject: Reply with quote
Bottom hose was significantly hotter than the top hose. We stripped a pipe which had a small, plastic water filter inside which was blocked so gave that a clean out. Can't start it now to see if it rectified the overheating issues.
monkeyman
PostPosted: 23:04 - 13 Aug 2012    Post subject: Reply with quote
Have you got spark?
Do you have fuel in the float bowls?
Speed
PostPosted: 23:26 - 13 Aug 2012    Post subject: Reply with quote
Given up for tonight and wont be till Wednesday before i can check again. Will keep you posted. Cheers for the suggestions Thumbs Up
promufa
PostPosted: 10:44 - 14 Aug 2012    Post subject: Reply with quote
I had a similar thing on my bike a few weeks ago... Turns out the battery positive was not not tightened properly. Poor contact gave intermittent power to the engine and caused it to cut out at low revs.
Might be worth giving you battery and charging system a once over
'02 Triumph Speed Four
Speed
PostPosted: 10:52 - 14 Aug 2012    Post subject: Reply with quote
Getting it to start last night drained the battery so we took it out and stuck it on charge. Put it back in and it died after a few turns. Hooked up the jump leads and she started fine. But then cut out when it was idling and wouldnt start up. It was only idling at around 500-1000 rpms which i thought was a bit too low. Shouldnt they idle at around 1500rpm? Put the missus on hold for tonight so going to spend tonight working on the bike. Hopefully clean the carbs out.
P.
PostPosted: 10:56 - 14 Aug 2012    Post subject: Reply with quote
Should be ~1400rpm when warm, ~1000rpm when cold.
Increase the idle speed and double check the battery voltage is above 12.5v when off and around 14v when running.
mentalboy
PostPosted: 11:08 - 14 Aug 2012    Post subject: Reply with quote
Presume you've checked that the air filter's not lagged up?
Make mine a Corona.
Speed
PostPosted: 11:24 - 14 Aug 2012    Post subject: Reply with quote
Will check that tonight. It's only recently had a service but worth checking anyway Thumbs Up
promufa
PostPosted: 11:49 - 14 Aug 2012    Post subject: Reply with quote
Did it start first time with the jump leads? Also did it cut out with the jump leads connected or after you took them off? If it died after you removed the jump leads your battery and most likely your charging system are FUBARed.
Helpful diagnostics flowchart here
If it died with the jump leads still attached it is most likely not electrical. Other people on here can give you a lot more help than I can if it's that.
Good luck
Speed
PostPosted: 11:57 - 14 Aug 2012    Post subject: Reply with quote
With the jump leads attached it started staright away and was ticking over nicely. We then disconnected the jump leads and let it ran for a bit for which the revs gradually died down and then cut out. Had to bump start it and it was still idling rough (when it did start Laughing )
Thanks for everyones advice so far Razz
promufa
PostPosted: 11:59 - 14 Aug 2012    Post subject: Reply with quote
OK then, I am fairly confident that your battery and charging system are to blame here. If it runs fine with a steady power supply (jump leads) and dies off when that is disconnected, the bike is not generating sufficient electricity.
Grab a multimeter and go through the flowchart I linked in my previous post. You should be able to nail it in a few minutes.
Speed
PostPosted: 07:33 - 15 Aug 2012    Post subject: Reply with quote
Problem solved! Just about to take the carbs off when we noticed that the choke cable was sticking by about a quarter of its play. Freed it off and now it goes like a stabbed rat. Would have been slowly flooding and explains the over fueling issue. Thanks to everyone for their help Thumbs Up
The last post was made 13 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 95.6 Kb
