Cant' get fork to come apart....
Matt-
PostPosted: 18:52 - 14 Aug 2012    Post subject: Cant' get fork to come apart.... Reply with quote
Basically having some issue's separating the fork's from their fork tube's :@
Basically 1 of the forks is done but the other is putting up a fight i have managed to get the seized clip out of the top " however " i can NOT get the bottom Allan key bolt out at all to release the fork , it's seems to turn very freely but not come out Sad
it's the bolt where the bolt for the wheel goes through at the bottom of the forks.
The bike is an NSR 125 1993 JC20
any help is very much appreciated
Many thanks
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Borris
PostPosted: 18:54 - 14 Aug 2012    Post subject: Reply with quote
You may need to apply some pressure to the damper rebound inside the tube, sticking the spring back in may be enough
Suzuki EN 125-2
Honda CB 500
cb1rocket
impact gun it while the springs are compressed
Matt-
PostPosted: 19:02 - 14 Aug 2012    Post subject: Reply with quote
i have been doing this but no luck at all Sad just seems to turn and turn, when i shake the shock it feels like something has come off but it's not completely apart :/
Will this not damage the thread's ?
maybe do this with spring in fork compressed ?
Many thanks
Matt
Damon
PostPosted: 20:31 - 14 Aug 2012    Post subject: Reply with quote
Id put the fork back together and then undo the allen bolt on the bottom. It shouldn't spin with the spring in it under pressure.
Damon
Matt-
PostPosted: 20:53 - 14 Aug 2012    Post subject: Reply with quote
Damon
Already have Thumbs Down
put the spring in & the plastic tube then put the top on, put a socket on the nut tightened it up, still nothing Thumbs Down
she's being a right bastard Thumbs Down
PostPosted: 21:20 - 14 Aug 2012    Post subject: Reply with quote
Some bikes need a 'damper rod holding tool'.
I made one for my TT600 using an old lawnmower handle. I recently used an old piece of curtain rail to do it on my FZR400.
I suggest you look at the damper rod that came out of your dismantled fork leg and see if you have anything that will fit tightly into the top of the rod. If you don't have anything that will work, make something.
Once I've made my own tool, I'd then use it in concert with an air impact wrench. Obviously if you don't have access to one then that is a non starter, but with the right tool it should be doable with a breaker bar.
Good luck!
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Matt-
PostPosted: 21:34 - 14 Aug 2012    Post subject: Reply with quote
Good luck!
Thanks Mate Smile sounds good, hopefully it come's out, will have another bash tomorrow Smile
The last post was made 13 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 58.19 Kb
