DRZ400 SM - Surging issues? - UPDATE
Richtea
PostPosted: 19:48 - 14 Aug 2012    Post subject: DRZ400 SM - Surging issues? - UPDATE Reply with quote
I have only had my DRZ for about a week and havent done loads of miles but one thing I have noticed that when I try to hold the bike at a steady speed (eg 30mph) the bike feels like it is constantly surging or lurching backwards and forwards.
I know that the characteristics of a single cylinder are different, and to expect a bit of surging compared to my old GS500, but is this normal?
I've read some stuff about opening up the airbox etc but I want to keep the bike standard as I'm on the 33bhp restriction at the moment and so dont need any performance mods.
Thanks
Rich.
2005 Honda Varadero 125xl > 2005 GS500F > 2007 DRZ400 SM > 600 Bandit & Yamaha YP250
Suntan Sid
PostPosted: 21:20 - 14 Aug 2012    Post subject: Reply with quote
Try doing a search here:-
https://www.thumpertalk.com/forum/17-dr-z-400/
It's one of their favourite topics.
Richtea
PostPosted: 10:50 - 15 Aug 2012    Post subject: Reply with quote
Thanks Sid.
I did do a quick search on there before I posted but their posts relate more to modified jetting/air box versions.
I don't really want to start changing jets etc as a) it's not something I would want to do myself and b) I want to keep it stock.
I can't imagine that the bike was like this from new and so I was just looking for some tips about what to check, rather than rejetting.
Hope this makes sense.
Rich
Fizzer Thou
PostPosted: 10:58 - 15 Aug 2012    Post subject: Reply with quote
It sounds like a throttle position sensor (TPS) problem.
If you have a multimeter check the resistance from fully closed to fully open.On a bike that I tested recently it was 0-5k ohms.
If you bought the bike from a shop tell them that you are experiencing problems with it and what are they going to do about it.
Always have a 'Plan B'
PostPosted: 11:17 - 15 Aug 2012    Post subject: Reply with quote
You will, FMF exhaust and downpipe, 3x3 airbox mod, you'll love it Wink Give it time... it took me a day to get annoyed with a lower power output than could be obtained...snip snip and voila Laughing
hmmmnz
PostPosted: 11:45 - 15 Aug 2012    Post subject: Reply with quote
before i did any thing else, do the basics,
remove, strip and clean the carb, blow through the jets,
replace the spark plug,
check the wiring, make sure all the earths are in good condition, and that none of the wiring has rubbed through against the frame.
if its still not right start looking further afield
the humans are dead
I kick arse for the lord
Budgetboy This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
PostPosted: 13:33 - 15 Aug 2012    Post subject: Reply with quote
Budgetboy wrote:
Balance the Carbs Thumbs Up
Because a single carb needs balancing so bad Wink
reckless_b
PostPosted: 13:51 - 15 Aug 2012    Post subject: Reply with quote
just had a very similar issue on an xbr500 honda single, at lower speeds surging and popping back through the exhaust, checking the carb settings (didn't bother with balancing ) the pilot screw was set to book settings but I opened it up finally by a full turn and was rewarded by a much smoother running bike without the surging. You'd think a single would be so much simpler with only one of every thing but they can still try you.
40 years on the road on and sometimes off bikes with a very recent OFF
Budgetboy
PostPosted: 14:58 - 15 Aug 2012    Post subject: Reply with quote
My bad did not read it fully.. he even said Single cylinder.. Embarassed Thats what you get for doing 3-4 jobs at once lol..
I suspect its fueling though.. Perhaps just clean all of the carb with cleaner and compressed air.. Even a tint bit of rubbish in the jets/airways will cause things like this to happen.. At least it will eliminate it.. Thumbs Up
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
Richtea
PostPosted: 17:24 - 15 Aug 2012    Post subject: Reply with quote
Yeah, with my very limited knowledge I think it is to do with the fuelling.
I think I'll start by cleaning carbs/jets but never done it before Confused
Any beginner tips/no no's to stop me ruining the bike?
I'd like to have a go myself 'cos I'm sure a dealer will be silly money.
Richtea
PostPosted: 22:23 - 18 Aug 2012    Post subject: Reply with quote
So had a mate round who knows a bit more about bikes. After taking a look/listen said that it sounded a bit like a misfire.
Anyway pulled the spark plug an it was a bit carbonated but nothing major. So stuck in a new Iridium spark plug, and put some Profi Fuel Max through the tank/carbs to give it a flush.
End result? The lurching has almost completely disappeared Thumbs Up Very Happy
So thanks to everyone for all their comments but looks like it just needed a good clean.
Rich
The last post was made 14 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 75.6 Kb
