fecking 2 stroke
Kawksam
PostPosted: 21:28 - 16 Aug 2012    Post subject: fecking 2 stroke Reply with quote
i washed the kawasaki kh100 and after wards she wouldn't start for love or hope, fiddled with carb and checking stuff managed to get it running and then died off and wouldnt start again afterwards plug was wet, dryed and it would start die and not start, made a loud bang and end cone flew off again.
left it several hours started first time idles and ran fine for 30 mins went into tesco and wouldnt start again plug was wet changed plug still no start and had to push it home.
any clues before i set fire to it
titan666
PostPosted: 21:33 - 16 Aug 2012    Post subject: Reply with quote
Did any water get into the airfilter?
and i assume its dried out, but from what you said id say no:)
i suppose you could remove the plug and leave it out .
other than that it could be water in the electricals(time and electronic contact cleaner)
sounds like pure joy!Smile
if all else fails, start and leave to idle for as longs as you can,so to really get the heat going.
love my susuki gz 125 maraurder 1998
WannaBeDude
PostPosted: 21:34 - 16 Aug 2012    Post subject: Reply with quote
Pics of end cone please !
Sounds like its running rich and plug fowling. Try a new plug for a start and get the mixture right.
Kawksam
PostPosted: 21:49 - 16 Aug 2012    Post subject: Reply with quote
think its running rich but plug was chocolate brown when working, how would i go about that after 2nd kick the plug is wet
Matt-
PostPosted: 22:26 - 16 Aug 2012    Post subject: Reply with quote
May have filled the cylinder with water when your engine was on it's intake stroke may have taken in water from the air filter, water not being combustible causing the plug to be wet and not fire.
take the plug out, if you have starter on bike crank it over for 20 seconds and with the spark plug removed look at the cylinder when turning over to see if anything comes out the cylinder. once you have done that, leave plug out and let the cylinder dry and also the plug dry and you should be fine Very Happy Thumbs Up
Hope this helps
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Kawksam
PostPosted: 22:33 - 16 Aug 2012    Post subject: Reply with quote
just seems to be fuel flooding it at moment not water, but ill check the settings and leave the plug out
Matt-
PostPosted: 22:37 - 16 Aug 2012    Post subject: Reply with quote
Washing the bike would not have made no difference on your carb setting's, it may have got water in the bowl, that's about it though...
even with to much fuel in your cylinder she will not fire, it will only keep fowling the plug, dry the cylinder out over night and try it in the morning.
Hope this helps
Matt
PostPosted: 00:03 - 17 Aug 2012    Post subject: Reply with quote
It'll be water ont the plug leads causing a short and crappy spark.
Spray all the electrics between the coil and plug with copious quantities of number forty water displacing fluid (WD40). When this fixes it, you know you need a new HT lead and possibly plug cap
tahrey
PostPosted: 04:07 - 18 Aug 2012    Post subject: Reply with quote
^ this sounds pretty on the money --- if you were getting serious amounts of water in your cylinder, the result wouldn't be difficult starting, it'd be an apparent seizure or possibly even a cracked head/piston/block.
Whereas I've had enough trouble with ageing HT leads in the past, when they've met with excess moisture. Brand new ones are damn near waterproof, old ones are very porous. And can be further damaged by rubbing on exposed hard/sharp parts, I found out earlier (...time to break out the electrical tape and get a fresh lead on order for the cg...)
mentalboy
PostPosted: 14:03 - 18 Aug 2012    Post subject: Reply with quote
Keep it simple and start with the air filter.
Make mine a Corona.
symonh2000
PostPosted: 16:39 - 18 Aug 2012    Post subject: Reply with quote
If it is the airfilter wet of the plug leads damp they should soon dry out if you leave the bike in the sun for a while.
Four strokes is two strokes too many.
The last post was made 14 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 68.41 Kb
