BIKE REPAIR IN NEWCASTLE
NEWBIKER123
PostPosted: 09:09 - 17 Aug 2012    Post subject: BIKE REPAIR IN NEWCASTLE Reply with quote
Hi as some of you may know my bike has broke down, (on the day i bought it).
Im looking for garage around newcastle that wont rip me off, because ill be going in blind, i wont know if they having me on or not.
Has anyone got any recommendations for any particular garage in newcastle?
Thanks
hi
thomp1983
PostPosted: 10:14 - 17 Aug 2012    Post subject: Reply with quote
what bike is it? i assume it's not starting? are you not able to perform any of the basic checks yourself with some guidance from here?
chris
GrantT
PostPosted: 13:12 - 17 Aug 2012    Post subject: Reply with quote
whereabouts in Newcastle are you?
NEWBIKER123
PostPosted: 15:11 - 17 Aug 2012    Post subject: Reply with quote
chris
Its a ybr 125, engine starts but no drive, i had a go at opening the final drive cover, but screw wont budge, and in order to the gear shafts/clutch plates there is alot things to remove which im not comfortable with doing as i doubt ill put everything back properly.
hi
NEWBIKER123
Im from fenham, ne4
hi
iooi
PostPosted: 19:06 - 17 Aug 2012    Post subject: Re: BIKE REPAIR IN NEWCASTLE Reply with quote
Thanks
And you don't think to take it back and get it sorted by the seller ????
thomp1983
PostPosted: 19:10 - 17 Aug 2012    Post subject: Reply with quote
im up in durham next weekend can pop up and have a look at it for you probably sunday afternoon or monday if your in no rush. put up some pictures of the bits your trying to remove so i can see what tools i might need
chris
bencav
PostPosted: 19:45 - 17 Aug 2012    Post subject: Reply with quote
2 that I would call would be:
Barkers bikes in Boldon Colliery
Armstron Engineering on 'The Hill'
t121anf
PostPosted: 20:18 - 17 Aug 2012    Post subject: Reply with quote
highly recommend DIT motor cycles in Sunderland
https://www.yell.com/b/D.I.T+Motorcycle+Repairs-Motorcycle+Repairs+and+Services-Sunderland-SR53JT-5085884/
Jim Mc
PostPosted: 20:37 - 17 Aug 2012    Post subject: Reply with quote
There are at least 3 on westgate road, why don't you go down and have a word with them?
NEWBIKER123
PostPosted: 21:51 - 17 Aug 2012    Post subject: Re: BIKE REPAIR IN NEWCASTLE Reply with quote
iooi wrote:
Thanks
I bought it From a private seller, i can't go back to him, as he gave me every chance to inspect it before i bought it.
hi
kelvyn
PostPosted: 22:04 - 17 Aug 2012    Post subject: Reply with quote
Stan at WSB on 'the hill', westgate road keeps getting good reviews but I haven't used him.
I can only vouch for Darryl at DIT sunderland.
NEWBIKER123
PostPosted: 22:07 - 17 Aug 2012    Post subject: Reply with quote
chris
Hi Chris i would be for ever grateful if you could come and have a look, sunday would be fantastic.
On the ybr the bits that ive tried to remove mainly need screw driver and spanner. I just have had so many people tell me possible faults, i.e clutch lever, clutch friction plates, carburetor, gear shafts, sprocket in final drive, gear shafts. dont know where to start.
hi
thomp1983
PostPosted: 22:30 - 17 Aug 2012    Post subject: Reply with quote
im in a 10k race in stockton sunday morning so it will be lateish sunday afternoon.
have you read the service manual found below,
www.gnuen.dk/binary/YBR125servicemanual.pdf
the screw/bolt you said is stuck do you think it is stuck because it's seized or because you do not have the correct size tool for it?, ill be bringing my own bike so will only be able to bring limited tools so knowing as much in advance as i can would help. do you have access to any tools?
chris
NEWBIKER123
PostPosted: 22:32 - 17 Aug 2012    Post subject: Re: BIKE REPAIR IN NEWCASTLE Reply with quote
I know there is three on the hill, i want to know peoples recommendations, ive spoken to ard and wsb they seemed nice, but then again they wont say "yeh mate im a rip off merchant" will they. so trying to find the one with good reputation.
hi
thomp1983
PostPosted: 22:49 - 17 Aug 2012    Post subject: Reply with quote
just about any garage are likely to charge you £80+ plus to change the clutch, quick look on ebay shows new plates are less than £20. have you followed tef's advice from your workshop post and checked that a, when you pull the clutch lever the arm at the gearbox end moves and b, the front sprocket hasn't worked loose, aside from either of those 2 issues you can be fairly sure to say that on a bike you were riding perfectly fine with no grinding or banging noises before hand that suddenly won't take up drive that it's just the clutch plates have gone, id expect a failure of something such as a shaft in the gearbox to be giving quite a noticeable whine for awhile before failing so id honestly order the clutch plates and diy it
chris
NEWBIKER123
PostPosted: 23:16 - 17 Aug 2012    Post subject: Reply with quote
chris
Ive tried to follow tef and other peoples advice as much as i could, ive got ybr manual and haynes manual.
I managed to drain the engine oil Smile lol
I thought it was the clutch plate as most people on my other thread have said, but when i spoke to the wsb guy he said that its unlikley to be the clutch friction plates as it only done 6000 miles.
I wanted to try and replace the clutch plates but i got to take the stand assembly off, and some rod attached to the break, which if im quite honest im scared ill royally fuck it up.
Thanks,
hi
NEWBIKER123
PostPosted: 23:18 - 17 Aug 2012    Post subject: Re: BIKE REPAIR IN NEWCASTLE Reply with quote
the screw is one the final drive cover, there are two screws, i managed remove one, but other wont budge, and is started to strip slightly.
hi
NEWBIKER123
PostPosted: 23:33 - 17 Aug 2012    Post subject: Reply with quote
chris
When you say grinding, i was on the dual carriageway and trying to change gear up, when in the highest gear and it was grinding but apart from that no.
hi
NEWBIKER123
PostPosted: 03:42 - 18 Aug 2012    Post subject: Reply with quote
chris
Ive got the general diy stuff, screwdrivers, spanners, pliers, drill, saw, etc,
hi
tahrey
PostPosted: 05:26 - 18 Aug 2012    Post subject: Reply with quote
Odd, with a sequential gearbox if you push up on the pedal whilst easing off the gas it should snick into the next gear quite easily without grinding...
Downshifts are quite another matter, but if your clutch has gone phut you can get a grindy, jerky change by winding on the throttle whilst stamping down.
Or is it that this is the noise it's making whilst supposedly in a gear, and you've released the clutch, but no power is going to the wheel?
NEWBIKER123
PostPosted: 10:28 - 18 Aug 2012    Post subject: Reply with quote
it was grinding once, because i wasn trying to change up gear when i was in highest gear. only did that once.
hi
johnsmith222
PostPosted: 13:48 - 18 Aug 2012    Post subject: Reply with quote
Bad advice there.
When slowing, put a slight downward pressure on the shifter with the throttle off.
It won't move until it's time for it to click down a gear nice and smoothly with no crunching or bullshit or any chance of flipping the bike.
thomp1983
PostPosted: 19:04 - 25 Aug 2012    Post subject: Reply with quote
did you get this sorted or did you need me to have a look still? if you still need a hand pm me your address and contact details
chris
RichieZX6R
PostPosted: 08:54 - 26 Aug 2012    Post subject: Reply with quote
If you don't mind me asking how much did you pay for it? And where did you find it? I'm not far from you and been 125 shopping for some friends.
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
The last post was made 14 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.88 - MySQL Queries: 13 - Page Size: 127.4 Kb
