Polishing Kit for angle grinders
cb1rocket
PostPosted: 20:35 - 19 Aug 2012    Post subject: Polishing Kit for angle grinders Reply with quote
Is there such a kit? I want to be able to use a bonnet type polisher with my angle grinder than to go out and buy another orbital polisher.
Or am I best off getting a kit for my drill?
Bezzer
PostPosted: 21:27 - 19 Aug 2012    Post subject: Reply with quote
Machine Mart used to do angle grinder polishing pads probably still do. Depends on what you're polishing really, if it's paint then a grinder will be too fast and powerful but fine on metal.
cb1rocket
PostPosted: 21:34 - 19 Aug 2012    Post subject: Reply with quote
i want to polish my fork legs, and to be honest I hate elbow grease work!
recman
PostPosted: 21:46 - 19 Aug 2012    Post subject: Reply with quote
Angle grinder will be too fast for a polishing kit and wreck it instantly.
cb1rocket
PostPosted: 22:02 - 19 Aug 2012    Post subject: Reply with quote
Did thought about doing it this way at this link
https://www.bikechatforums.com/viewtopic.php?t=222429
Then using the angle grinder with some polishing compound on a felt pad using this
https://www.ebay.co.uk/itm/General-Angle-Grinder-Polishing-Kit-44-Dull-Marked-Metal-to-High-Mirror-Finish-/400315371457?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item5d34a7cfc1#ht_1523wt_1037
recman
PostPosted: 22:28 - 19 Aug 2012    Post subject: Reply with quote
You'd have to check out the speed rating of that ebay kit fella if your solely going to use the rotary action of an angle grinder.
It looks like the sander used in the restoration link you posted has an orbital attachment fitted which may well be easier for you to use. Wink
ruck bodgers
PostPosted: 01:24 - 20 Aug 2012    Post subject: Reply with quote
you can buy a attachment to fit standard polishing mops that also fits your standard grinder at the other end . if i knew the direct name for them i would find you one . i will take a look in a bit
i polished a few engine cases with a drill once all i used was a bolt to hold the mops on the drill couple of nutts to hold it firm. using a drill works just fine however it will kill your drill . unless you have something heavy duty . this is a piece i did with it .its just 2 stage polished here grey/black and green . looked better afterwards
i dont reccomend using a drill but if your in a pinch and your drills heavy duty . may as well . theres not all that much to cover on the forks . no need to use any force on it really . if your drill brakes please forget my post Neutral
https://img9.imageshack.us/img9/7863/p1010016uq.jpg
Uploaded with [URL=https://stupidgit underpants .us[/URL]
ruck bodgers
PostPosted: 01:38 - 20 Aug 2012    Post subject: Reply with quote
ah shit sorry im a doghnut i misunderstood the post . i thought you meant metal polishing not the other kind
cb1rocket
PostPosted: 18:25 - 20 Aug 2012    Post subject: Reply with quote
ok thanks for tips guys, ordered polishing stuff, so i'll see what happens
The last post was made 13 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.77 - MySQL Queries: 16 - Page Size: 60.85 Kb
