Cyclone Alarms - Are they worth it ?
Matt-
PostPosted: 23:38 - 19 Aug 2012    Post subject: Cyclone Alarms - Are they worth it ? Reply with quote
Are the really worth the money?
How easy are they to wire in & do I have to cut any wires?
And I'm after what you guy's think of them ?
Thinking about putting one on my bike Smile
Many thanks
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
map
Mr Calendar
PostPosted: 00:04 - 20 Aug 2012    Post subject: Reply with quote
They are cheap and they work.
Arguements are that any alarm is better than none versus people ignore vehicle alarms nowadays. However, that's nothing to do with the actual alarm unit.
Downside is that they may not get you and insurance discount the same as the approved installation job ones. Then again, that's nothing to do with how the unit actually works either.
In summary, buy one and then post your opinions for others to share Thumbs Up
Llama-Farmer
PostPosted: 00:49 - 20 Aug 2012    Post subject: Reply with quote
Generally people ignore alarms, unless you're the one stealing thats making the alarm go off, then you usually do a runner. Result is bike is not stolen.
Worth it imo.
U_W v2.0
PostPosted: 00:54 - 20 Aug 2012    Post subject: Reply with quote
okay i will try to be as informative as possible.
considering you dont say which cyclone alarm i will base this post on the £23 Cyclone C-11 alarm. Yes i do own this alarm.
good points:
Randomly coded remote controls of which you get 2. They are fairly rebust but i wouldnt go stomping on them or throwing them around.
The buttons work well and are quite "clicky" so you can feel you've pressed them.
remote reception, well mines not great, but thats because i just dumped the antenna in a hole. but it works without obstruction for a good 15-20 feet away.
125bd siren: On my bike its located under the seat with about 1" between the siren and the seat and is PLEANTY loud. place your hand over it though and its muffled. so make sure its placed somewhere you cant just cover it over with.
remote start: if this takes your fancy. be wary though, it DOES bypass the clutch switch so if its in gear and you use it, your bikes going to fall flat on its side if its on a side stand.
immobiliser: well i assume its working, not really tested it haha.
overtake warning: biggest pile of shit anyone has ever thought off.
you push a button twice and it flashes the indicators and chirps the alarm. pointless and frankly dangerous. DO NOT USE THIS FUNCTION. it DOES distract other road users and could cause a RTA because of it.
now the bad points:
chirps once when you arm the alarm and flashes the indicators, thats fine, BUT when you turn off the ignition (key still in or not, doesnt matter) it will then flash the indicators (fine thats cool) and chirp the alarm 3 times. this triple chirp is really annoying, especially if you come home late at night. it will wake the neighbors up.
remote start: sorta covered that. it bypasses the clutch switch so be wary of it if you leave your bike in gear.
onwards -
wiring:
for my bike all i had to do was remove a connector on my loom and plug it in. and it was good to go from there. other bikes this will vary but its a very simple installation.
blue flashing LED warning light:
i drilled a hole into my dash and popped it onto that, nice BRIGHT flashing led. on = 1 second / off = 1 second.
battery wear:
not had any problems, left the bike standing for 3/4 days and its still fired up fine so hasnt drained my battery and its only a tiny ass thing.
overall:
for a £23 pound alarm its definatly worth it. They claim you can turn off the engine if its stolen UP TO 100m away. but havent tested it. for the better part, if you alert your neighbors to the sound of your alarm then it will add to its effectiveness.
its a good alternative to expensive alarms and easy to operate
hope this helps.
Mr Krispy
PostPosted: 01:59 - 20 Aug 2012    Post subject: Reply with quote
+1 Usually_Wrong
I also own one and have tried the anti hijack feature and can say it works with or without the remote start connected.
When fitting it I ran into trouble, being the first alarm i have installed didn't help. The owner (Nigel iirc) spent nearly an hour on the phone running me through what to do until it was working.
Pretty good customer service for a £20 alarm imo.
Teflon-Mike
tl;dr
PostPosted: 03:26 - 20 Aug 2012    Post subject: Reply with quote
Installed three of them.
For £20-£25?!?!?
Yeah... they are worth the while.
Pretty easy to wire.
Gives imobiliser, light and sound, to detur scroats. WONT stop the deturmined, as proven in our case, but, makes the kiddies thing twice about it.
dungbug
PostPosted: 04:11 - 20 Aug 2012    Post subject: Reply with quote
Fitted a Cyclone to my Ped years back, certainly was the best 'deterrant' I found. I didn't have the immobiliser or auto start fitted, just the alarm and wired to the indicators. Very loud which is all I wanted, for sub £30 and bugger all time needed to fit it's a no brainer really, well worth having. Thumbs Up
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
Efes123
PostPosted: 07:07 - 20 Aug 2012    Post subject: Reply with quote
Yep, I have the cheap one too. Easy to fit, and simple to use. The remote start is fun for surprising people Laughing
I have heard of a few problems after a year, and for some reason my speaker has stopped working. Really do need to get the multimeter out, but the rest still works, and the blue light is the main deterrent. But for £20 + you can't complain.
I have heard that people who get the talking one tend to turn it off after a while as they feel a bit embarrissed by it.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
Matt-
PostPosted: 12:39 - 20 Aug 2012    Post subject: Reply with quote
Cheer's everyone Very Happy
It;s for my 1993 NSR 125 FM
i will use it for the alarm and immobilizer, don't need it for the Remote start,
1- because it's pointless if your not showing it off,
2- because I'm clumsy as fuck and would probably start it in gear Thumbs Up
Marmalade
PostPosted: 17:27 - 20 Aug 2012    Post subject: Reply with quote
But one off ebay you cheapskate. £20ish delivered to the door, new, boxed with fitting diagram for your bike.
Or get one used via your bcf ad with cut wires only one remote and no instruction for a tenner plus a fiver postage.
Matt-
PostPosted: 17:32 - 20 Aug 2012    Post subject: Reply with quote
i was thinking like £10 inc postage Wink
you see, i like to save money Wink
Marmalade
hahadumball wrote:
I had the cyclone c11 on my ns125 it was awesome tbh
worth every penny and when ther alarm went off it would kill the power to the bike, bit of a pita when i had the keyfob in my pocket it would randonly die on me with the alarm going off so had to attach it to keys and try not to press it lol.
Donkey.
If you fit it properly it won't do that.
UnspeedySam
PostPosted: 17:58 - 20 Aug 2012    Post subject: Reply with quote
I've been looking at one of these lately too. Does anyone know if the triple chirp when the ignition is turned off applies to both the C-11 and the V2?
Wave2k
G's Stalker
PostPosted: 18:14 - 20 Aug 2012    Post subject: Reply with quote
Alarms are nothing but a pain in the ass.
All the bikes ive had, they have caused more problems than they have solved.
When a bike has broken down, it was down to the Alam/immob.
In 2007 while on track at Cartegena mid corner just about to start giving it the beans coming out and the alarm/immob borks itself.
Bike cuts out, upsets the bike and i go flying off into the gravel trap.
Thumbs Up Yea alarms are great.
Ducati 1299 Panigale
2009 Corvette C6 z51
U_W v2.0
PostPosted: 23:57 - 20 Aug 2012    Post subject: Reply with quote
use a better alarm then Laughing
EazyDuz
PostPosted: 00:12 - 21 Aug 2012    Post subject: Reply with quote
Ive heard too many stories of these draining the battery to make it worthwhile imo.
That plus i dont want to butcher/splice any wiring.
Matt-
PostPosted: 00:21 - 21 Aug 2012    Post subject: Reply with quote
Lot of mixxed opinions then :/
Just what I thought I'd get, il ask the company if I have to cut Any wires if I don't have to I am going to test the alarm out & also do a YouTube video review of it Smile
For £22 it's a bargain !
Matt
neil.
PostPosted: 06:45 - 21 Aug 2012    Post subject: Reply with quote
Please don't use those scotch block connectors - they are awful. Do it properly and solder/heat shrink everything. It takes longer but it's much more reliable. A year and 17'000 all-weather miles on my little CBF125 and the Cyclone V2 is still working perfectly. Every feature wired in. Get one. Thumbs Up
EazyDuz
PostPosted: 08:16 - 21 Aug 2012    Post subject: Reply with quote
_Iain_ wrote:
Again, as stated above Rolling Eyes
Those pinch connectors are naff though and will fail long term.
I'd be pissed if i went to my bike one day to find the battery is flat lol.
Each to their own i guess, id rather just have an alarmed disklock on the front wheel, and a thick chain going through the back wheel.
AlexW
PostPosted: 08:31 - 21 Aug 2012    Post subject: Reply with quote
Hate so much of this thread. Hate cheapo shitty alarms and I hate those scotch locks.
The last post was made 14 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 146.27 Kb
