CG Speedo - Fixed. Now brakes!
Chalky.
PostPosted: 17:38 - 18 Aug 2012    Post subject: CG Speedo - Fixed. Now brakes! Reply with quote
Bought CG today, speedo not working.
Stripped down to try to find cause and struggling.
The little gold bearing type thing in the drum, when turned by hand, makes the speedo wire connector turn but when all put back together and wheel turned, there's nothing.
So I think the problem lies between the wheel itself and the gold part in the front drum?
Ta
carvell
Scuttler
PostPosted: 17:40 - 18 Aug 2012    Post subject: Reply with quote
Yes, the 'gold thing' (speedo drive) has probably worn down to such an extent that it's not contacting the lugs in the wheel that spin it. You need a new speedo drive. Won't cost much off an old CG125, or you can fork out for a new one.
Either that, or someone's put it back together wrong in the past.
Yamaha TDM 850
matto
PostPosted: 16:13 - 19 Aug 2012    Post subject: Reply with quote
On mine the crown gear which drives the speedo had broken in the wheel... assuming you have an old one with drum brakes like mine.
Chalky.
PostPosted: 10:50 - 20 Aug 2012    Post subject: Reply with quote
Fins on the speedo drive were slightly bent upwards so were missing and not turning. My good friend the hammer sorted than and now working. Thumbs Up
Front brake's crap now though. Shoes look like they've got plenty of life and had a pay with the cable etc but not got anywhere. Any ideas?
matto
PostPosted: 11:02 - 20 Aug 2012    Post subject: Reply with quote
If it was ok before you took it apart... Smile
You'll need to be a bit more descriptive though, crap because it doesn't work? or grabs? or is stiff?
Chalky.
PostPosted: 11:10 - 20 Aug 2012    Post subject: Reply with quote
It was bad but not as bad - there's nothing there now!
Pull the brake all the way back and the bike just keeps on going Laughing
Matt-
PostPosted: 11:12 - 20 Aug 2012    Post subject: Reply with quote
if they were " OK " before you touched them...
what have you touched to make them bad, have you touched the adjustment's of the brake's at all ?
what are the symptom's of bad brake's ?
Squeaking ?
No feel to the lever ?
explain Thumbs Up
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
matto
PostPosted: 11:20 - 20 Aug 2012    Post subject: Reply with quote
I guess you've probably not done the adjuster nut up far enough.
https://images.cmsnl.com/img/partslists/honda-cg125-1995-england-front-brake-panel_bigecchrb1f__0800_288b.gif
#15 on here.
Chalky.
PostPosted: 14:10 - 20 Aug 2012    Post subject: Reply with quote
To be fair chaps I've not really looked at it yet. Just went out yesterday on it and had to use back brake everywhere Laughing
Adjuster nut thread has gone, where can I pick one up? Even so, I think it's right at the end of the screw so wouldn't have much of an effect?
Matt-
PostPosted: 14:20 - 20 Aug 2012    Post subject: Reply with quote
https://www.ebay.co.uk/itm/HONDA-CG125-CG-125-PAIR-OF-LOCK-NUTS-FOR-FRONT-AND-REAR-BRAKE-ADJUSTERS-/300760484097?pt=UK_Motorcycle_Parts&hash=item4606b8c901
or your local bike shop
Hope this helps
Matt
Chalky.
PostPosted: 14:23 - 20 Aug 2012    Post subject: Reply with quote
Sod that, I'll just raid the random nuts and washers pot!
Cheers for the help, have some Karma
tomh
PostPosted: 21:40 - 20 Aug 2012    Post subject: Reply with quote
You need to adjust the thread on the cable on the brake lever all the way in and then tighten the nut on the wheel hub until the brake begins to be effective and then fine tune it by turning the thread out on the lever.
Also make sure that all the wheel spacers as that can cause similar symptoms.
The last post was made 13 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 68.88 Kb
