What sort socket do i need for these ?
Matt-
PostPosted: 11:26 - 20 Aug 2012    Post subject: What sort socket do i need for these ? Reply with quote
Just wondering what sort of socket i need for the clamp nut's and bolt's on my NSR 125, so i can do the head bearing's on them?
( Picture below )
https://i46.tinypic.com/n2heso.jpg
Any help much appreciated Thumbs Up
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Suntan Sid
PostPosted: 11:40 - 20 Aug 2012    Post subject: Reply with quote
The picture is very confusing.
Are talking about the nut in the centre of the picture?
Are you sure you need to remove it?
Matt-
PostPosted: 11:45 - 20 Aug 2012    Post subject: Reply with quote
I'll be honest suspension is not really my sort of area i know a bit about it but this is my first time replacing head bearing's,
where you see the small Gold nut in the center of the picture ( also a gold head to the right of the gold nut is what i think i need to loosen it order to get the stem out, it's a sort of clamp device, with 2 bolts on top and to on the bottom, ( i was told i had to undo these by my local shop ) but i am confused because some one else said undoing the lock nut at the top of the picture would allow the stem to fall out Confused
i really just need to know how it come's out ?
Many thanks sid
Matt
Raffles
PostPosted: 12:08 - 20 Aug 2012    Post subject: Reply with quote
Those ''gold nuts'' look as though they are fixed to the clamping plate and are not meant to be removed. I imagine that if you look to the other side of the clamp then you will see the screw heads that you may need to unfasten.
Suntan Sid
PostPosted: 12:29 - 20 Aug 2012    Post subject: Reply with quote
Remove the castle nut, on the steering stem, the bearing cap should lift off to reveal the bearings.
I wouldn't remove or loosen the other two nuts/bolts until you see if that plate stops you removing the lower bearing shell.
Matt-
PostPosted: 12:47 - 20 Aug 2012    Post subject: Reply with quote
Yeah that's what i was going to do, by the way it's been sprayed gold and with different shape nut's and bolt's suggests it's for show rather than they are meant to be taken off Thumbs Up
Thanks Very Happy
if anyone else has any views feel free to share Very Happy
Matt
The last post was made 13 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 49.71 Kb
