What is this for...
ScaredyCat
PostPosted: 17:19 - 20 Aug 2012    Post subject: What is this for... Reply with quote
and where should it go...
5.5mb image
Had a minor off the other day, I noticed this when I got back home today.
Anyone know where it should be connected to? I have no idea at all. Sad
Bike is a CBF125
I'm a little bit worried about it dangling there.
Andy / ScaredyCat
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Casper
PostPosted: 17:23 - 20 Aug 2012    Post subject: Reply with quote
Brake light switch mate. It should hook on the back of the lever at some point.
Slacker24seve...
PostPosted: 17:24 - 20 Aug 2012    Post subject: Reply with quote
It almost certainly attaches to the rear brake lever. The thing on the other end is your brake light switch.
Banger rallies are ace
Lone-Wolf
PostPosted: 17:27 - 20 Aug 2012    Post subject: Reply with quote
Wotcha.
Don't panic - it's just the spring that operates your rear brake light switch. Just hook it back onto the brake pedal and the job's a good un !
Cheers.
L.W. - www.moonshiners.org.uk
Teflon-Mike
tl;dr
PostPosted: 18:01 - 20 Aug 2012    Post subject: Reply with quote
As above.
Knowing Honda, it doesn't attach directly to the brake pedal though.
There will probably be some little metal plate extension attached to the brake lever under where the switch spring hangs.
ScaredyCat
PostPosted: 18:13 - 20 Aug 2012    Post subject: Reply with quote
Thanks Guys.
I think my off did a little more damage than expected, I can't get the spring to stay on. It'll do it for one pedal press, but after that if just flops about.
It's got to go in for a warranty fuel pump change tomorrow, perhaps it's better if I get them to take a quick look.
Andy / ScaredyCat
Casper
PostPosted: 18:18 - 20 Aug 2012    Post subject: Reply with quote
Look further up it, the plastic screw thread is the adjuster. Just re bend the end of the metal spring and re adjust where the light comes on.
ScaredyCat
PostPosted: 19:36 - 20 Aug 2012    Post subject: Reply with quote
Ahh perfect, that sorted it. Thanks. Adjusted the brakes a little and took her out for a quick run, she seems a lot happier.
The brake lever is a little high on the toe pad -it's higher than the foot peg, is there a simple way to lower it?
Andy / ScaredyCat
Casper
PostPosted: 21:16 - 20 Aug 2012    Post subject: Reply with quote
Andy / ScaredyCat
Yes. Undo bolt and pull lever out. See the shaft its on? just move down a notch. Worth marking the one you are on before taking it of so you have an idea what one is the next notch.
The last post was made 13 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 61.67 Kb
