Top end death rattle **Added video**
karthead
PostPosted: 11:26 - 24 Aug 2012    Post subject: Reply with quote
Someone is sure to fill you in more about the rattle...
For the oil, if you are sure there aren't any leaks, then its probably burning up the oil, and that seems like a lot of oil to burn up in a week or so. Could be bad rings, dont know what to think, but if this is the case, the rings would usually slowly ware, rather than suddenly allow nugget loads of oil to flow past.
I'd say its a good idea to take off the valve cover for a decent look. Could be a bad valve stem seal also?
Is it 4 or 2 stroke?
It could be a cam chain tensioner also.
Take a couple pics when/if you get that valve cover off. Good luck! Thumbs Up
karthead
PostPosted: 09:41 - 25 Aug 2012    Post subject: Reply with quote
_Iain_ wrote:
Shifty
PostPosted: 09:42 - 25 Aug 2012    Post subject: Reply with quote
Safety pin distributor cap boy can't tell if its 2 or 4 stroke yet mentions a chain tensioner.
Go eat needles.
Iain, it sounds fine Thumbs Up Smile
karthead
PostPosted: 10:40 - 25 Aug 2012    Post subject: Reply with quote
Go eat needles.
I replied when there was no video. Besides, whats wrong with that?
Sorry for trying to help Thumbs Down
PostPosted: 10:43 - 25 Aug 2012    Post subject: Reply with quote
Check his sig, does it list any 2 strokes at all?
mysterious_rider
PostPosted: 11:46 - 25 Aug 2012    Post subject: Reply with quote
sounds ok to me.
nowhere.elysium
The Pork Lord
PostPosted: 11:47 - 25 Aug 2012    Post subject: Reply with quote
It's an air-cooled twin. They're noisy by their very nature.
karthead
PostPosted: 11:49 - 25 Aug 2012    Post subject: Reply with quote
Dafuq is a sig?
Oh, right........ Confused
I didn't realize everyone had a list of all the bikes they've owned Embarassed
Anyways, does it matter?
nowhere.elysium
The Pork Lord
PostPosted: 11:50 - 25 Aug 2012    Post subject: Reply with quote
It does if you're trying to advise someone on technical matters, yes.
nowhere.elysium
The Pork Lord
PostPosted: 12:04 - 25 Aug 2012    Post subject: Reply with quote
What colour is the smoke, and have you run a compression test on it yet? I have a compression tester that you're welcome to use, should you need it.
PostPosted: 12:08 - 25 Aug 2012    Post subject: Reply with quote
_Iain_ wrote:
Paddy - any chance i can pop down and get the dremel? Need to put the side cover on the engine propperly as water in there isnt going to help!
No probs! I'm in all day thanks to the rain and the police telling me if I ride on the road an S59 shall be issued Middle Finger Evil or Very Mad
Also may have a favour I require of you... Mr. Green
Also if you pop the bike down.. I have a few tools here so I can take a quick pokey in your head, see if there is a lot of oil in there Thumbs Up
ThoughtContro...
PostPosted: 12:45 - 25 Aug 2012    Post subject: Reply with quote
Not everyone. Paddy needs it so he can remember how many bikes he's crashed Wink Razz
Prize cunt
karthead
PostPosted: 12:56 - 25 Aug 2012    Post subject: Reply with quote
I wouldn't think it would matter too much if i were to mention cam chain tensioners, or rings, or valve stem seals. Common sense really Wink
Well at least 'safety pin boy' has something to pay him out about Very Happy
nowhere.elysium
The Pork Lord
PostPosted: 12:58 - 25 Aug 2012    Post subject: Reply with quote
You may want to read up on the fundamental differences between four stroke and two stroke engines, if you're going to start mentioning valve stem seals after claiming ignorance of the engine type.
karthead
PostPosted: 13:12 - 25 Aug 2012    Post subject: Reply with quote
I just assumed he would know that if i were to talk about valve stem seals, or cam chain tensioners as a problem, i would be referring to a four stroke Crying or Very sad
https://1.bp.blogspot.com/_4B6BR9aWHAk/SL7gXrHm9AI/AAAAAAAAA1c/Hd9sLtfY7Ng/s400/weird-faces-069.jpg
I felt like uploading this as well...
Jim Mc
PostPosted: 13:32 - 25 Aug 2012    Post subject: Reply with quote
Don't 2 strokers have a chain tensioner, to drive an oil pump? Or do they just rely on the gearbox to circulate the oil?
russell210276
PostPosted: 13:46 - 25 Aug 2012    Post subject: Reply with quote
2 strokes dont have cam chains, rockers or anything like that they get there oil from mixing petrol and 2 stroke oil via premix or oil pump a 4 stroke has oil in the sump and the bearings sit in that oil where as a 2 stroke does have a sump but its only for the gears and clutch someone can elaborate a bit more but im sure u get the idea
theres nothing mechanical in a 2 stroke except the piston and conrod thats why there so light.
and the oil pump on my rg is connected to the side of the engine on a gear so the faster i go the more oil flows and vise versa
nowhere.elysium
The Pork Lord
PostPosted: 13:50 - 25 Aug 2012    Post subject: Reply with quote
You're not getting out of that one so easily.
Matt-
PostPosted: 16:50 - 25 Aug 2012    Post subject: Reply with quote
Sound's fine Thumbs Up
Is it 2 stroke or 4 Stroke
That made me giggle Laughing
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
DrDonnyBrago
PostPosted: 19:39 - 25 Aug 2012    Post subject: Reply with quote
I think the safety pin gudgeon pin circlip has failed.
Time to hammer out a new one from a coke can and plasticine Thumbs Up .
karthead
PostPosted: 01:14 - 26 Aug 2012    Post subject: Reply with quote
I would have thought copper wire would do the trick Wink
Timmeh
PostPosted: 13:46 - 28 Aug 2012    Post subject: Reply with quote
Have you checked your powerband recently? They stretch over time like chains do
Police
The last post was made 14 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 136.45 Kb
