Is a K&N Dangerous to my bike ?
Matt-
PostPosted: 15:10 - 27 Aug 2012    Post subject: Is a K&N Dangerous to my bike ? Reply with quote
Well i have read somewhere that a K&N on some 2 stroke bike's can very dangerous, is this correct ?
The bike is a 1991 Honda NSR125FM De-restricted with Full Arrow exhaust system, the k&N is a cone type filter, when i have ridden it it seems to run fine ?
Many thanks
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Bezzer
PostPosted: 15:34 - 27 Aug 2012    Post subject: Reply with quote
A K&N in most cases is more free flowing, more air into the system=weaker mixture=meltdown in some cases dependant on how weak the mixture is and more so with a 2T than a 4. If you bought it like that with everything fitted, pound to a pinch it's been sorted......hopefully.
Matt-
PostPosted: 15:39 - 27 Aug 2012    Post subject: Reply with quote
Just before the K&N their is a 5 inch piece of plumbing pipe, so would that suggest it's been sorted it seems to run ok, ( for what i have rode it ) would it be best if i went back to a standard air filter?
Matt
moonzoomer
PostPosted: 15:44 - 27 Aug 2012    Post subject: Reply with quote
Check your sparkplug for colour, this will give you a basic idea if the bike is running rich or weak due to the mods, also check your carb jets sizes and compare to original spec, normally jet size will have been increased after an exhaust and filter mod
Matt-
PostPosted: 15:51 - 27 Aug 2012    Post subject: Reply with quote
So if it's wet it's running rich and if it's Dry it's running lean ?
what color's should i be looking for ?
Matt
moonzoomer
PostPosted: 15:55 - 27 Aug 2012    Post subject: Reply with quote
https://www.verrill.com/moto/sellingguide/sparkplugs/plugcolorchart.htm
Bomberman
Spark Chart Thumbs Up
I always read (on here mostly) that they would run far worse on my TZR than the original so I avoided them. If the carb has been set up though, fair D.
Matt-
PostPosted: 16:06 - 27 Aug 2012    Post subject: Reply with quote
Think i am going to re fit a standard air box Thumbs Up
U_W v2.0
PostPosted: 18:16 - 27 Aug 2012    Post subject: Reply with quote
if its had a K&N filter fitted with a bigger jet and you reinstall a stock airbox you will need to reduce the jet again
Matt-
PostPosted: 18:37 - 27 Aug 2012    Post subject: Reply with quote
We will see what happens, i have bought a standard JC20 Air box just in case, so if i get the jetting right will it be ok and safe and not harm the engine ?
What jet size do i need ?
jet's and tuning really confuses me Thumbs Down
Matt
U_W v2.0
PostPosted: 18:39 - 27 Aug 2012    Post subject: Reply with quote
best thing to do would be get the haynes manual or manufacturers manual for your bike and check the carb jet sizes in there.
if its a truely stock air box for your bike then the sizes in the manual will be fine.
however, if you already have the K&N + correct size jet for it, why not leave it as is?
what was the result on checking your spark plug?
Matt-
PostPosted: 18:49 - 27 Aug 2012    Post subject: Reply with quote
Have not yet checked it as bike's at another location to where i am,
The bike seems to be running 85% fine so i have left it but due to people saying it's dangerous having a K&N i have got a bit worried ?
Matt-
PostPosted: 21:24 - 27 Aug 2012    Post subject: Reply with quote
Very helpful sir Thumbs Up
Karma Given, i did know some of what you said about ratio's etc but never ever had to re Jet anything, 2 Stroke's really interest me so it's all now being sunk into the brain. Thumbs Up
So standard Air box back on?
As i have a ARROW exhaust system will i still have to re jet, i would of thought NOT as my NSR is naturally DE - restricted as it's an import and full power it should have correct jetting, being honest an arrow exhaust system wouldn't really upset the ratio anyway, it's only lighter, slightly bigger expansion chamber ?
to be honest as well i only like K&N for noise Wink
Fizzer Thou
PostPosted: 23:23 - 27 Aug 2012    Post subject: Reply with quote
Matt
That 5" length of plumbing pipe sounds as though it is non-standard.It changes the intake length if the OEM was say 6".The shorter the intake length the higher in the rev band the power is.But changing the intake length as well as the exhaust pipe will change engine characteristics from standard and generally it is better to have the bike checked on a rolling road dyno that rely on a seat-of-the-pants feel as to whether you have it correct or not.
The worst case scenario is that you change jets/needles/air filter and it holes the piston or seizes.If it runs okay with the K&N filter in place then leave it as is.
Always have a 'Plan B'
Bomberman
PostPosted: 00:35 - 28 Aug 2012    Post subject: Reply with quote
Yeah. You should probably quit the WONDERMAN account too.
Robby
Dirty Old Man
PostPosted: 01:08 - 28 Aug 2012    Post subject: Reply with quote
_Iain_ wrote:
Optimal air/fuel ratio is 14.7-1. I.e 14.7 litres of air, to one litre of petrol.
Wrong. Molar ratio, no volume. 14.7 moles of air to one of petrol.
If it was 14.7 litres of air to one litre of petrol, a tank of fuel would last a little over 90 seconds on tickover.
Matt-
PostPosted: 09:11 - 28 Aug 2012    Post subject: Reply with quote
Thanks for all the reply's, I have bought a old standard air box off eBay which will hopefully fit my bike, bought a new air filter element for it as well, il put that back on, if it runs better I am going to keep the standard on their, the after market exhaust system should not make much difference to how my air / fuel ratio as its not a high end pipe,
The derearitcted bikes were jetted high anyway for the winter, so my arrow shouldn't make all that much difference, it's just lighter.
Also the exhaust has a lot of carbon in it?
Would this be a symptom of it running lean?
Matt
PostPosted: 09:54 - 28 Aug 2012    Post subject: Reply with quote
It is a bit more complicated.
There are several ways the carb controls the mixture, depending on how much throttle you are using. At idle and just off idle it is controlled by the idle air screw or idle mixture screw depending on the bike (similar functions, one controls the fuel through the idle circuit, the other the air through the idle circuit). The needle controls the mixture for most of the throttle range (the shape of the bottom of the carb slide controls it on the transition from the idle screw to the needle) and at large throttle openings it is controlled by the main jet. Some carbs also how power jets to give further fuel on very large throttle openings.
With these combinations it is entirely possible for the engine to be running rich at one point in the throttle / rev range and lean at another.
Also on a basic slide carb there is nothing to make up for user error. Whack the throttle wide open at low revs and it is going to give a really dodgy mixture. Gas speed through the carb will be low, hence the air pressure drop through the carb will be minimal and little fuel will be drawn from the float bowl (hence most carbed larger bikes using CV carbs which are far more idiot proof).
Added to that there are the resonant frequencies that Fizzer Thou touched on. The lengths of intakes sets up pressure waves at certain rpm which bounce around forcing more mixture in. However this can also land up with air going through the carb, then bouncing back and then through the carb again at certain revs (you might be able to see this with no air filter in place, with a mist of mixture appearing to sit in the air before the carb).
A K&N cone filter can be freer flowing and hence lean the mixture off in general (although I wouldn't guarantee it, and it might well have a smaller area than a conventional filter). However they also have a metal end cap which can screw up the pressure waves through the carb.
It is possible to get them to work but takes a bit of time playing around with jets.
You shouldn't have to worry about the 2 stroke oil on a bike running an oil pump. However is a bigger issue on a bike running premix.
A seized engine and a lack of forward motion.
Running rich is safer than lean. Rich will just accelerate wear due to washing oil the the bore, but you have a fairly large safety margin for that. While lean can easily give a sudden and expensive engine failure. So start rich and work your way down.
skatefreak
PostPosted: 10:15 - 28 Aug 2012    Post subject: Reply with quote
For the carbon deposits in the exhaust I suggest for standard pipes, this:
https://t2.gstatic.com/images?q=tbn:ANd9GcQdsm7-ejPR78CyyU_t6llTwnzPBbQCwPYp7DZwt0z-cRYWeyPu&t=1
Pull off the engine, bung a carrot in the end and throw some of this in with water.
It will bubble for half an hour or so, drain, repeat then rinse and run to dry.
Be warned, if you have a non standard pipe you may have aluminium in there and this may corrode it badly Neutral
-Jvr
Matt-
PostPosted: 15:22 - 28 Aug 2012    Post subject: Reply with quote
So what would you suggest doing Keith ?
I am really confused on what to do for the best, i want the bike to have some reliability so the K&N Filter is a DEFINITE no.
I want to keep the arrow exhaust as it's light weight, and a better sound plus i don't want to have to buy a standard exhaust.
I have some sense in mechanical knowledge of 2 stroke's what i have learn t on here.
Any idea's what i can do ?
Matt
Bezzer
PostPosted: 16:08 - 28 Aug 2012    Post subject: Reply with quote
For all you know it might have already been sorted properly for it's current set up and running fine mixture wise.
For peace of mind have a dyno run to show how the fuelling is then you can take it from there knowing it's either OK or you have a benchmark to sort it out .
Matt-
PostPosted: 16:15 - 28 Aug 2012    Post subject: Reply with quote
Yeah i know but for the hassle it's worth i am going back to standard, and if the k&n get's wet it will be UN - reliable Thumbs Down
Will this jetting kit be ok? it's an upgrade kit for a Honda NSR 125 ?
https://www.dellorto.co.uk/merchandise/products_details.asp?PartNo=NSR%20JET%20KIT&CategoryID=2&PartsectionID=24
Matt
Bomberman
PostPosted: 21:11 - 28 Aug 2012    Post subject: Reply with quote
Confusing Matty King? A user from the same place as you, who hasn't posted since 2011 yet is regularly on the boards doing nothing but uprate your posts? Confusing indeed Thinking
The last post was made 14 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 139.16 Kb
