| rumppole |
 rumppole Trackday Trickster
 Posted: 15:20 - 27 Aug 2012 Post subject: NC30 Main Fuse Blowing. |
The gremlins are showing themselves on the new (19year old) bike.
Girlfriend out on the bike the other day. Did about 5 miles and the bike went dead. No power at all.
Turn the ignition on and nothing, no lights, no click of the starter motor, nada.
Back home on the rear of a truck.
I set to checking all the fuses and found the 30A main starter solenoid fuse had blown. Replaced this and as soon as I attempted to place the solenoid lid back on, pop, it went again. This is with the ignition off.
Ive traced the wires from the battery to the solenoid and all looks good. I have also traced the wires from the solenoid to the ignition and can see no scorch marks or areas where the wire could be grounding. All earth wires I can find look secure.
Then I checked the regulator and found this:-
https://i209.photobucket.com/albums/bb70/rumppole/Regulator.jpg
Is the regulator toast?
Could this be causing the short in the main fuse?
Advice welcomed...
Rumps. ____________________ Sermo datur cunctis; animi sapientia paucis. |
| moonzoomer |
 moonzoomer World Chat Champion
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 15:42 - 27 Aug 2012 Post subject: |
Disconnect the reg-rec to isolate it, put in a new fuse and see if it all works.
The bike should start and work fine without it connected. Obviously it won't charge up mind you, so don't ride it further than you are prepared to push it!!
I think it is best to test it this way before buying anew Reg-rec that you may not NEED ... ____________________ The purpose of life is to fight maturity. |
| rumppole |
| Frost |
 Frost World Chat Champion
| J.M. |
 J.M. World Chat Champion
| Frost |
| P.addy |
 P.addy Red Rocket
 Posted: 19:26 - 27 Aug 2012 Post subject: |
I think shereen advised getting a new one on your last post with this bike
You can move it to the left hand side of the bike behind a fairing vent, will get some cold air there and mount to the frame to remove more heat  |
| rumppole |
| tammie |
 tammie L Plate Warrior
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 09:29 - 23 Sep 2012 Post subject: |
If you doing a tiny bit of wiring etc, I do believe the R1 or R6 regulator can be retrofitted to any Hondas (someone correct me if I'm wrong). But these are diode units and the chances of them failing are second to none, although they are quite sort after for this reason and as a result a little more expensive than a Honda one. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| rumppole |
The last post was made 14 years, 54 days ago. Instead of replying here, would creating a new thread be more useful? |
