GSXR 750 - Fuel injection light & won't accelerate
Snorty
PostPosted: 19:10 - 28 Aug 2012    Post subject: GSXR 750 - Fuel injection light & won't accelerate Reply with quote
So the problems begin
I was out in the GSXR 750 today, and the fuel injection light came on - seemed ok. Then I noticed when I accelerated up to high revs and backed off again - the throttle wouldn't respond at all for a few seconds, then would suddenly start working again, same for changing gears. It seems to be when I chop the throttle it stops working.
No problems at all before this, just suddenly started happening today Sad
Any ideas what this could be?
It's not bogging down or anything like that - the throttle literally just does nothing, so the engine slows down, then the throttle will respond again.
PostPosted: 19:16 - 28 Aug 2012    Post subject: Reply with quote
Mine did similar, turned out to be one of the injectors. The wire leading to it was frayed and kept shorting!
Fisty
PostPosted: 19:20 - 28 Aug 2012    Post subject: Reply with quote
Does it bring up a fault code?
Fatter and faster than Fret
Snorty
PostPosted: 19:23 - 28 Aug 2012    Post subject: Reply with quote
No it just says "FI" on the dash where the temperature should be.
It starts up fine, runs as it should, but if I accelerate up to say, 7000rpm, then just close the throttle, the throttle will just not respond to anything and the bike will slow, then the FI light will come on and stay on.
If I just crawled around at 4,000rpm it would be fine, but anything around 7 or above and the FI light comes on.
PostPosted: 19:25 - 28 Aug 2012    Post subject: Reply with quote
FI means it has a fault code.
You'll need to honk it into dealer mode, a quick google will tell you how, mine was 2 pins near the rear light.
My guess is the secondary valve thing that usually goes wrong.
Fisty
PostPosted: 19:30 - 28 Aug 2012    Post subject: Reply with quote
Not sure if the fi system is the same as the tl, but the TL brings up a fault code on the speedo.
Have a look under the LHS of the tail fairing (just lift the seat up) Do you see a plug with a blank in it? If it has short it out with a paperclip, turn on the ignition and it should give a fault code on the dash.
GSXR Fuel Injection (FI) Code List:
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR (01-02 1000 and 06-07 600/750/1000 ONLY)
PostPosted: 19:37 - 28 Aug 2012    Post subject: Reply with quote
My bet is 28/29/30 Thumbs Up
Old Git Racing
PostPosted: 12:46 - 29 Aug 2012    Post subject: Reply with quote
Go on the Gixxer forum and there is a sticky all about FI problems and how to id them.
OGR
Snorty
PostPosted: 13:54 - 29 Aug 2012    Post subject: Reply with quote
c00 - no fault apparently!
PostPosted: 14:10 - 29 Aug 2012    Post subject: Reply with quote
Did you do this with the FI light still lit on the dash?
Snorty
PostPosted: 14:33 - 29 Aug 2012    Post subject: Reply with quote
Bizarre - I got it into dealer mode but the FI light wasn't on as you said, so c00 was showing.
Now I took it up the road with the dealer mode still engaged, usually it messed up right away, and starts being irritating. So I gunned it up the road, running fine, then about a mile later, it does it.
C24 and C25.
What could this mean?
PostPosted: 14:38 - 29 Aug 2012    Post subject: Reply with quote
Something is pissing around with the ignition side of stuff...
Unsure how you check ignition signal. Laughing
Snorty
PostPosted: 14:55 - 29 Aug 2012    Post subject: Reply with quote
I can only think perhaps it's a wiring fault somewhere - the bike pulls hard and strong, it's just when I back off the throttle, the engine dies instantly, pull the clutch in and the engine actually isn't even at idle, so it's nothing to do with the throttle.
So annoying.
PostPosted: 15:17 - 29 Aug 2012    Post subject: Reply with quote
Hence ignition. Laughing
Possibly time to whack those fairings off and have a look round the loom. Ignition down to the coils, on to the HT leads.
Snorty
PostPosted: 15:22 - 29 Aug 2012    Post subject: Reply with quote
This is way beyond me at this point I think.
I don't have a multi-meter, I don't have many tools, I think I'm going to have to take it to the garage. Perhaps I've saved myself some money in diagnosing it.
Have to wait a couple weeks now and ride as-is, til I can afford it.
The throttle position sensor is quite low I think? It says _c00, though I doubt this will be the problem, I may as well get it fixed at the same time.
Kris
PostPosted: 15:23 - 29 Aug 2012    Post subject: Reply with quote
Does it have an alarm / immobiliser?
www.prisonplanet.com
Fisty
PostPosted: 15:30 - 29 Aug 2012    Post subject: Reply with quote
Its a coil.
sickpup
Old Timer
PostPosted: 15:32 - 29 Aug 2012    Post subject: Reply with quote
mr_fisty wrote:
Its a coil.
X 2 coils or connections.
Fisty
PostPosted: 15:36 - 29 Aug 2012    Post subject: Reply with quote
Indeed, possibly HT leads cracking? Though the fault codes point to coils.
Snorty
PostPosted: 15:40 - 29 Aug 2012    Post subject: Reply with quote
I reckon it's a connection fault as you say - I took it quite far today without any of the symptoms, revved it up to 12k rpm up the road with no ill-effects, then it started randomly doing it again.
Seems like if the coils were gone, they'd not be intermittent? Whereas a wiring fault is? I'm probably wrong though.
I will add at this point - the battery had been run completely flat by a knackered rectifier - to the point where it was absolutely drained. New rectifier was fitted and the battery charged itself back up. Don't suppose this could have any bearing on the situation?
Also, I meant to ask, you guys know what you're talking about - what effect does the throttle position sensor have, in real terms of riding the bike? As I say mine is at the bottom position
PostPosted: 15:43 - 29 Aug 2012    Post subject: Reply with quote
Coils can be intermittent and break down under load.
Just whip the tank/panels and airbox off. See if you can locate the coils
stonesie
PostPosted: 17:33 - 29 Aug 2012    Post subject: Reply with quote
WOAH FELLAS!
Try the wiring and connectors first, then move onto the spark plugs, they can also break down and start to misfire under load when the temperature rises rapidly then go back to normal service when they cool.
Cheapest fix first Thumbs Up
My bike was running not bad maybe slightly lumpy but nothing really to worry about, 8K miles from new and the plugs looked like this...
https://img821.imageshack.us/img821/6214/imag0126f.jpg
PostPosted: 18:11 - 29 Aug 2012    Post subject: Reply with quote
Duff plug won't throw an FI light - the ECU has no way of knowing about it.
Stick coils have a habit of cracking and breaking down. Swap the two coils with the other two and see if the fault moves.
Snorty
PostPosted: 20:26 - 29 Aug 2012    Post subject: Reply with quote
Just been out on the bike now, did around... 6 miles. The last two miles I caned it where possible... no fault code, no problems.
I don't know if this helps narrow things down for the more knowledgeable?
stonesie
PostPosted: 20:32 - 29 Aug 2012    Post subject: Reply with quote
I hate electrical faults Laughing
First thing to do is check all the wiring connectors that have anything to do with the coils, a shot of WD-40 or ACF 50 won't do any harm. Any green fur in there or rust is corrosion and needs cleaning out if possible.
The last post was made 14 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 128.67 Kb
