| gandy666 |
 gandy666 Nova Slayer
 Posted: 21:00 - 29 Aug 2012 Post subject: GSX1100g slipping hydraulic clutch |
hello there,
have a strange issue with the hydraulic clutch on my GSX1100g.
I've had it about 2 months, it was in storage for a year or so. Clutch has been fine up to this point, but have been using the bike in anger for the last 2 weeks, doing about 80 miles a day. had no issues up until friday when there was no pressure on the lever at all. closer inspection revealed that the reservoir was empty and the fluid had turned into a kind of waxy oily stuff.
so i cleared all the oil out of the pipe by blowing through, bled it though, took the slave cyclinder off and cleaned that thoroughly as well, then checked the spring and all seemed well, put it all back together,took the bike to work this morning and all was well.
brought it back tonight and the clutch started to slip after about 35 miles, so was thoroughly warmed up. Plenty of tension still on the lever, I'm thinking that the fluid has warmed up, expanded and is engaging the clutch without me actually putting pressure on it. I changed the oil in the bike about 4 weeks, using synthetic motorbike oil (Motol 5000 10w40) so I dont think the oil is to blame.
I'm thinking it will be fine tomorrow once it cools off, then will start slipping again when it warms up.
I cant find a method of adjusting the clutch as it just engages a lever that activates the clutch mechanism?
has anyone ecountered this kind of thing before?
I was thinking I would open the bleeder nipple when the bike is warm this morning, without pulling the clutch lever to relieve some pressure but the assumption is as soon as I pull on the lever the pressure will go back up and I'll be back to square one.
wondering is the master cycllinder should perhaps have a small valve somewhere that releases pressure in the case of fluid warm up and perhaps that is blocked?
any help appreciated.
cheers! |
| gandy666 |
 Posted: 22:37 - 29 Aug 2012 Post subject: |
It does point to a blocked return port. The way to test for it is to crack open a banjo when the clutch is slipping to let out some fluid. If that cures the slipping, the port is blocked. ____________________ a.k.a 'Geri'
| gandy666 |
| bikenut |
 bikenut World Chat Champion
| bikenut |
| gandy666 |
| gandy666 |
The last post was made 14 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
