Easy way to clear blocked tank drain?
MarkJ
PostPosted: 12:36 - 30 Aug 2012    Post subject: Easy way to clear blocked tank drain? Reply with quote
Afternoon, my Sprint's drain hole (the bit that drains rainwater out of the top of the filler cap so it doesn't drop into the tank) is blocked.
Is there a quick way of clearing it out without having to remove the petrol tank? I sprayed WD40 down it last night and proddled around with some electrical wire, but it gets stuck at what feels to be the bottom of the tank, possibly a 90 degree bend.
I have a compressor, is blasting it with compressed air a bad thing? Will it pop any connectors off? Are there any other tricks like drain unblocker that work? Laughing
Ta Thumbs Up
map
Mr Calendar
PostPosted: 12:39 - 30 Aug 2012    Post subject: Re: Easy way to clear blocked tank drain? Reply with quote
MarkJ wrote:
...drain unblocker that work?...
The chemical drain unblocker/cleaners (Mr. Muscle, etc) are actually very harsh acid based. Do not put these near your tank, or any part of the bike for that matter.
Have you tried on the owner forum or even a quick 'phone call to a local dealer?
PostPosted: 13:59 - 30 Aug 2012    Post subject: Reply with quote
Find the other end of the hose and follow it up to see it's not pinched anywhere. If it isn't - blast away with the air line.
gandy666
PostPosted: 17:48 - 30 Aug 2012    Post subject: Reply with quote
i used a steel guitar string fuel cap top to bottom, then outlet bottom to top.
thinnest one I could find to start then up the fattest that would fit.
MarkJ
PostPosted: 19:47 - 30 Aug 2012    Post subject: Reply with quote
Cool, thanks everyone Thumbs Up Mr Muscle shall be avoided Very Happy
The last post was made 14 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 44.51 Kb
