| JackDaniels |
 JackDaniels Trackday Trickster
 Posted: 14:24 - 31 Aug 2012 Post subject: Possible Hornet reg/rec problem ? |
Hi guys,
i have a 2005 hornet 600 and have noticed in the past few weeks that if im only doing my 1 mile each way to work each day my battery is becoming flat, but after a long run the battery is fine again for a few days.
it doesn't discharge if i leave it for a day or 2 after a long run.
I fitted a new Mottorbatt battery this morning as i believe the battery that was on the bike was 7 years old.
After fitting the new battery i hooked up a voltage meter and stuck a vid on youtube.
Hopefully it was just the battery.
https://youtu.be/lguqo1mUSL4 ____________________ THEORY TEST - PASSED! - 02-08-11 CBT Passed - 09-08-10 MOD 1 - 09-08-2011 - MOD 2 - 28-09-2011
2006 Yamaha JOGRR>2010 Yamaha Ybr>1995 Honda CB400 Superfour >2005 Honda hornet>1999 Suzuki Bandit 1200 > 2002 BMW R1150GS > 2013 Tiger Sport 1050 > 2007 GSXR 1000 > 2005 GS500E |
| russell210276 |
 russell210276 Renault 5 Driver
| Scotsman37 |
 Scotsman37 World Chat Champion
| JackDaniels |
| Casper |
 Casper World Chat Champion
| russell210276 |
 Posted: 14:56 - 31 Aug 2012 Post subject: |
yes thats spot on its working perfectly  |
| Scotsman37 |
| Aff |
 Aff World Chat Champion
 Posted: 15:11 - 31 Aug 2012 Post subject: |
Sounds like your just not riding enough to recover the charge lost from start up.
I remember being told by my local mechanic a while ago, that it takes about 10 mins riding at about 40mph to recover charge lost from start up. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 18:15 - 31 Aug 2012 Post subject: |
Your battery voltage does indeed look low. With the ignition on it shouldn't drop below 12V at the very least. With the ignition off you should be getting about 12.5V minimum on a healthy and fully charged battery. The voltage will drop to about 11.5V when you press the starter and should then increase with revs up to 14.5V maximum.
You could also do a current drain check. Take a wire off the battery and connect your multimeter (if your meter measures amps) inline between the battery terminal and the wire. Make sure your meter is set to 20 amps DC. DO NOT START THE BIKE WHILST CHECKING THIS you will blow the meter. You should see 0.00 amps with the ignition off. This is basically to check if the regulator/rectifier is drawing current from the battery even when the bike is at rest. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
The last post was made 14 years, 47 days ago. Instead of replying here, would creating a new thread be more useful? |
