KDX betor rear shock
isle of man kmx
PostPosted: 17:33 - 01 Sep 2012    Post subject: KDX betor rear shock Reply with quote
I recently purchased a Betor rear shock and spring for my bike.(ebay)
Although my bike is a kmx the shock fits perfectly.
The problem i have is when i have the bike stood on the ground it doesnt bounce back up correctly.The best way to describe it is that i push down on the seat and the bike comes back up in slow motion!!
The Shock is one that cant be opened for servicing but does have a schrader type valve for putting Nitrogen in.
One other thing when the bike is on its stand i can pull the back wheel up and it bounces back down perfectly.
I think someone has let the nitrogen out.
What do you think?
Many thanks for reading
John
Matt-
PostPosted: 17:46 - 01 Sep 2012    Post subject: Reply with quote
Post a picture up of your shock so we can have a look Very Happy
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Budgetboy
PostPosted: 18:22 - 01 Sep 2012    Post subject: Reply with quote
It could be that the nitrogen has come out or leaked over time ,,or that the bladder is leaking itself. Add to this that the oil in the shock might be like frothy milk due to years of use..
Show us a pic of the said item.. Thumbs Up
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
Budgetboy
PostPosted: 18:56 - 01 Sep 2012    Post subject: Reply with quote
Also make sure your linkages are all lubed up and not sticking as this will also cause the same symptoms.
Id check this and what vincent has said first.. Thumbs Up
isle of man kmx
PostPosted: 08:45 - 02 Sep 2012    Post subject: Reply with quote
Thanks for the replies.
The shock is on the bike using the correct bolts etc which are only finger tight at the moment. The linkage is all lubed and moves freely/
lihp
PostPosted: 11:03 - 02 Sep 2012    Post subject: Reply with quote
Is the shock adjustable? Since it was never designed for use on your bike, the rebound damping may be too much. If you can, reduce rebound damping and try again.
isle of man kmx
PostPosted: 15:39 - 02 Sep 2012    Post subject: Shock update Reply with quote
Ive got the shock off the bike and removed the spring.
I can compress the shock quite easily by hand but it is quite a struggle to extend it again.I have to hold it in a vice and use both hands to pull it out.
There is nothing leaking anywhere..
dangerousdave
PostPosted: 17:51 - 02 Sep 2012    Post subject: Reply with quote
does sound like there is too much rebound damping.
are there any adjusters on the shock at all ?
did you buy it secondhand then off eBay? If so if no joy with above can you go back to the seller and ask what the solution to it is?
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
isle of man kmx
PostPosted: 18:08 - 02 Sep 2012    Post subject: Reply with quote
There is no adjustment at all on this shock.
Ive checked out a few website and it sounds like too much rebound damping can be caused by nitrogen leakage/someone fiddling.
Do you agree?
Frost
PostPosted: 18:09 - 02 Sep 2012    Post subject: Reply with quote
See that screw up by the gold end, turn it.
Compress the shock by hand then turn that and you'll find it uncompress much more easily.
Frost
PostPosted: 20:23 - 02 Sep 2012    Post subject: Reply with quote
re-read it, he said he removed the spring and compressed the shock by hand.
isle of man kmx
PostPosted: 20:34 - 02 Sep 2012    Post subject: Reply with quote
I need to tell you the photo i posted is a google image.
My shock is exactly the same but DOESNT have the gold screw.
sorry for any confusion
lihp
PostPosted: 00:02 - 03 Sep 2012    Post subject: Reply with quote
is the preload adjustable?
If the shock has no adjustments at all, and is for a different bike, I would hazard a guess that it isn't suitable for what you want it to do.
isle of man kmx
PostPosted: 18:36 - 03 Sep 2012    Post subject: Reply with quote
Good news
I took the shock to my local dirt bike mechanic 'Juan Knight in Sulby'
He filled it with Nitrogen,i put it on the bike and it works great. Very Happy
Thanks for your advice
John
The last post was made 14 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 91.26 Kb
