problems syncing carbs
GZXR400
PostPosted: 12:48 - 03 Sep 2012    Post subject: problems syncing carbs Reply with quote
Hi im having problems syncing my carbs
using a morgan carbtune
Connected evreything up, i couldnt get the tubing all the way over the restrictors as its just too tight so i have carefully taped them over so they are sealed
Fired the bike up and it tells me carbs are out of sync, so i get a screwdriver and before i even turn the screw with a screwdriver the revs fly up to 4-5k then go back to a really low idle
Iv got my idle set to 1500rpm, Valves are adjusted and have been checked, bikes been serviced new filters etc
Only thing i can think of is the baffle is removed from the exhaust and that i have no exhaust gaskets as the ones i bought didnt fit
really confused iv also took the carbs of and refitted them to make sure there secure
out of ideas could really do with some help thanks
PostPosted: 12:59 - 03 Sep 2012    Post subject: Re: problems syncing carbs Reply with quote
Stopped reading there.
Redo it. Use something to increase the size of the rubber pipes...
GZXR400
PostPosted: 13:49 - 03 Sep 2012    Post subject: Reply with quote
i have redone them and managed to get 1 and 2 within 2cmhg and 3 and 4 but i need to bring them level but bikes reving up but im finding adjusting the idle down as it revs is helping
lihp
PostPosted: 22:07 - 03 Sep 2012    Post subject: Reply with quote
I think you're pressing on the screw head a little which causes it to rev, make sure you blip the throttle a couple of times between adjustments
The last post was made 14 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 48.44 Kb
