The fuel learning curve
Srengam
PostPosted: 16:04 - 04 Sep 2012    Post subject: The fuel learning curve Reply with quote
I've been riding for 3 months now, commuting 30 miles a day, it's certainly been a learning curve regarding which fuel to use.
My experiences:
Shell V-Power:
Runs great but sounds "raspy".
Shell FuelSave:
Runs terrible, stalls when idling, and acceleration is poor.
Tesco regular unleaded:
Runs awful, stalls when idling and "chokes" at 6000-7000 rpms, bike actually judders at this range.
BP regular.
Bike runs greats and sounds great too, the only problem is the garage isn't 24 hours, so if I'm on nights I can't fuel up there.
Esso regular:
Unfair test really, was tried after the Tesco tank full. Bike didn't stall when idling anymore but bike still juddered a little at 6000-7000rpm, but, as mentioned it was contaminated with Tescos fuel from previous fill. I'll try 2 full tanks of this next (garage is also 24 hours).
There ya go, my experiences so far with different fuels.
Suzuki GSX600F Katana (1997)
PostPosted: 16:11 - 04 Sep 2012    Post subject: Reply with quote
Dafuq?
I've never seen any difference between different fuels, least not the sound the bike makes.
Your bike is older and has carbs, and as such shouldn't even have a knock sensor. It should be set up to run on 95 RON octane fuel. This should mean all UK pump petrol should work in your bike. If it doesn't I'd be concerned there is something wrong. It hasn't been tuned has it?
PostPosted: 16:12 - 04 Sep 2012    Post subject: Reply with quote
inb4 its placebo.
Fuel save is normal fuel, regardless of marketing.
V power...overpriced and used by probably 2% of cars on UK roads.
You seem to think petrol is different... maybe you have a faulty bike as all petrol stations listed have never caused any problems with any bike.
In fact I ran 7 fill ups in one day a week ago... in probably 5 different "branded" garages.
No difference.
Are you using diesel. Wink
Walloper
PostPosted: 16:16 - 04 Sep 2012    Post subject: Reply with quote
Have you tried Utterboulderd-ash?
It is better by far than the others.
WannaBeDude
PostPosted: 16:17 - 04 Sep 2012    Post subject: Reply with quote
I'd say many inc me, report better ' performance ' with dedicated fuel stations like shell bp and texaco ... Rolling Eyes Thumbs Up Karma
Alpha-9
PostPosted: 16:19 - 04 Sep 2012    Post subject: Reply with quote
It's a placeb-
Dammit paddy.
It's the same as cleaning your bike, you'll convince yourself its faster Laughing
Fzr-600 1999
hellkat
PostPosted: 16:20 - 04 Sep 2012    Post subject: Reply with quote
Here's a good tip:
DON'T USE DIESEL
(unless you have a diesel powered bike, o'course)
Irn-Bru
PostPosted: 16:24 - 04 Sep 2012    Post subject: Reply with quote
I have never noticed any differences with the fuel I've used. One lad I went out with would only fill up with Shell's premium petrol though, so he planned the route out with regards to Shell petrol stations Laughing I've tried premium a few times and I can never tell the difference apart from it costing a lot more.
PostPosted: 16:25 - 04 Sep 2012    Post subject: Reply with quote
Because your bike is hardly ever used and needs the ridiculous amounts of detergents that 'name brand' fuel companies put in their petrol?
PostPosted: 16:31 - 04 Sep 2012    Post subject: Reply with quote
My little red light comes on I find the closest station regardless of brand and fill the bike up and it makes bugger all difference to the way the bike works.
Top tip on the diesel though. Thumbs Up
map
Mr Calendar
PostPosted: 16:32 - 04 Sep 2012    Post subject: Reply with quote
Alpha-9 wrote:
...It's the same as cleaning your bike, you'll convince yourself its faster Laughing
...but that's true as it reduces friction and drag. It's also true that red bikes go faster because that's at the fast end of the light spectrum Wink
doggone
There's some evidence the supermarket stations sometimes get batches with borderline quality, because they are all about lowest price possible.
You might just get less power/running hot using it.
Some engines are more vulnerable and it depends how they are tuned.
I do remember once filling with petrol in Germany that my Bandit really ran bad on, got very hot and if working hard it started pinking.
I think it was sold mainly for lawnmowers or something.
Usually just like here you just grab the petrol nozzle with lowest price on it.
WannaBeDude
PostPosted: 16:33 - 04 Sep 2012    Post subject: Reply with quote
No, caus placebo is not a myth or made up, my doctor rekons my meds are those placebo things, but without them, i can't ride my bike. Cool Wink
Llama-Farmer
PostPosted: 16:34 - 04 Sep 2012    Post subject: Reply with quote
Hornet rode fine on Tesco regular unleaded when I first rode it back at start of August. Haven't ridden it since due to having my elbow operation.
Can't see it running worse on Momentum 99 or V-Power or anything higher. It might work better due to the detergents in premium fuel which clean the fuel lines, engine internals (particularly injectors, but they don't have them on a carb'd bike lol) and valves.
With my car it does make a difference in the feel and response, and over 20,000 miles I worked out costs me around 0.5p less per mile, which equates to around 5%. Gets slightly more power (RR proven) and higher mpg though with further range. I suspect that is less directly down to the fuel and more the fact the injectors and valves should now be nice and clean.
With my old diesel it made a significant difference, V-Power diesel was far and away better and gave it a good 3bhp more after the first tank, and a further 9bhp more after a few thousand miles on the stuff. Not to mention increased mpg, but actually cost a fraction more (several per thousand miles) because of the cost difference between regular and super diesel.
Walloper
PostPosted: 16:37 - 04 Sep 2012    Post subject: Reply with quote
So long as the knobend in at the till doesn't force me to remove helmet I'll use any fuel.
EXCEPT OF COURSE DIESEL in my bikes.
Thanks for reiterating that point hellcat. I almost forgot Embarassed .
PostPosted: 16:42 - 04 Sep 2012    Post subject: Reply with quote
I R dubious.
Dazbo666
PostPosted: 16:53 - 04 Sep 2012    Post subject: Reply with quote
I've run two different bikes on branded and supermarket petrol for thousands of miles each, and never noticed any appreciable difference in performance...
although I'd be more than happy to be proved wrong - for Now I'll just keep going to the nearest convenient pump
Word of the day : DILLIGAF
Llama-Farmer
PostPosted: 16:56 - 04 Sep 2012    Post subject: Reply with quote
##Paddy## wrote:
I R dubious.
Diesel works differently to petrol, it has a cetane number which is a measure of how quickly it burns. Petrols octane number is its resistance to detonation.
The quicker diesel burns, the more effective the power stroke, and it does not need the ecu to adjust timing (since there is no ignition in a diesel).
Petrol on the other hand needs the ecu to adjust the ignition timing to get max power, with a fuel that resists detonation, you can delay timing and get better power stroke. The average car out there probably doesn't adjust automatically for the rating of fuel in there, so no direct benefit, but secondary benefits might be there.
Over 6 years and over 100k miles, you build a lot of crap up in the engine and on the injectors and valves, particularly with diesel which is greasy and oily and full of crap. Cleaning all that off will make a significant difference. The car had never had things like fuel treatment or injector cleaners before I bought it, as far as i'm aware.
Bendy
Mrs Sensible
PostPosted: 16:58 - 04 Sep 2012    Post subject: Reply with quote
Apart from a brief period where filling up at the BP in Shepherd's Bush would make my CBR pop and burble more than normal, I've never noticed any difference whatsoever between fuels.
I don't work out my fuel consumption because I don't care. And frankly it could make the thing put out an extra 20bhp and I'd be none the wiser. Laughing
Im-a-Ridah
PostPosted: 17:11 - 04 Sep 2012    Post subject: Reply with quote
It wouldn't be the first time people have complained about Tesco's fuel
Walloper
PostPosted: 17:13 - 04 Sep 2012    Post subject: Reply with quote
I took the plugulators and Injecticators out the head of my auld Mazda (wot had did 70K+ over five years running on Supermarket Splosh).
Nada (significant) build up of any fing on any fing.
So I will stick to my guns and refrain from using expensive Placebonic Clap Trap in my veehikels.
And... My Deezil kar uses Supermarket-cetane-woteva-the-fuk-is-cheapest. I run a fuel computer on it and document mileage and notice Hee-Haw difference on the 'Hi-Grade' shite.
ajag
PostPosted: 17:45 - 04 Sep 2012    Post subject: Reply with quote
The most likely reason for your issues OP could external pollutants in the fuel (like water).
Did you try several different stations of each brand or you only went to one of each? My bet is on the fuel being contaminated with something else.
Street Triple
PostPosted: 17:56 - 04 Sep 2012    Post subject: Reply with quote
Ah, so my bike being purple explains why it's slow - it's almost ultraviolet Smile
nowhere.elysium
The Pork Lord
PostPosted: 18:06 - 04 Sep 2012    Post subject: Reply with quote
Never had a problem with Tesco's cheap (sic) fuel. Or any other fuel, for that matter.
Methinks the OP is looking for problem where there aren't any.
The last post was made 14 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 135.99 Kb
