Suspension Issues
Beez
PostPosted: 16:39 - 07 Sep 2012    Post subject: Suspension Issues Reply with quote
So I went over a bit of bumpy road yesterday and after retrieving my testicles from my mouth and returning them to their proper position - I get the feeling the suspension on my ER5 is a tad on the stiff side.
I've ridden 5 ER5's before this one (lessons), and the suspension on them was absolutley fine, but on this one i can feel literally every bump in the road.
The rear pre-load is as soft as it will go, and I reduced the tyre pressure back to the manufacturer guidelines and yet it is still as bad as it was.
Any easy way to soften it up or tell if the suspension is shot?
Budgetboy
PostPosted: 17:24 - 07 Sep 2012    Post subject: Reply with quote
could be too much oil or wrong oil put it..
If your pre load is all off then it cannot be much mate.. Might be worth whipping the forks off and changing the oil if you dont know when they were last serviced.
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
Fizzer Thou
PostPosted: 15:41 - 08 Sep 2012    Post subject: Re: Suspension Issues Reply with quote
If you can strip out the rear shock see if the swing arm will move through its full travel.If movement is limited then it sounds like the bearings need attention.
Always have a 'Plan B'
The last post was made 14 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 36.23 Kb
