Changed chain and sprockets for the first time :DD
GrumpyGuts
PostPosted: 19:59 - 07 Sep 2012    Post subject: Changed chain and sprockets for the first time :DD Reply with quote
Hi,
Well because I binned the bike and injured myself, I have a lot of time off work. So I decided to begin doing all the things to the bike I couldn't do whilst I was working, such as head gasket, chain and sprockets.
I had to get a friend to help as I couldn't do much with a cast on, but hey ho it's finally been fucking done!
1) First removed the chain guard
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07151953.jpg
2) Removed sprocket cover
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07152454.jpg
3) Remove the nut and washer (after bending the metal back)
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07152659.jpg
4) Slackened the chain adjusters
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07153149.jpg
5) Removed split pin off wheel nut (to replaced another day)
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07153615.jpg
6) Removed wheel nut
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07153808.jpg
7) Removed split pin from chain and removed chain
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07155554.jpg
8) Disconnected brake rod from the drum
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07155852.jpg
9) Remove wheel rod and remove wheel
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07163012.jpg
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07163017.jpg
10) Removed old sprocket
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07164735.jpg
11) Install new sprocket (put the teeth stamp facing towards the drum, hope that isn't a problem!)
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07165712.jpg
12) Replaced wheel
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07171445.jpg
13) Installed new chain and front sprocket, then lubed
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-07184335.jpg
Pretty pleased with myself to be honest!
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
Casper
PostPosted: 20:04 - 07 Sep 2012    Post subject: Reply with quote
Not a problem as that look an easy bike to work on but i would hook a chain up to the old one and pull it through and connect the ends. Leave it hanging to the side when taking sprockets off.
Well done though Thumbs Up
dungbug
PostPosted: 20:15 - 07 Sep 2012    Post subject: Reply with quote
Brought back memories of doing it on my old GN (practically the same bike), virtual pat on the back sir. Thumbs Up
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
GrumpyGuts
PostPosted: 20:59 - 07 Sep 2012    Post subject: Reply with quote
Well it was a pain in the arse getting the wheel rod out but it's all dandy..shame I can't test it!
The previous owner sprayed everything red...looks shite to be honest!
neil.
PostPosted: 21:23 - 07 Sep 2012    Post subject: Reply with quote
Ideal time to give the drum brake a clean-up and service too. Thumbs Up
dungbug
PostPosted: 21:36 - 07 Sep 2012    Post subject: Reply with quote
Don't forget to add a new split pin. Wink
neil.
PostPosted: 21:40 - 07 Sep 2012    Post subject: Reply with quote
Incidentally, even though it's an MOT failure to not have a split pin, has anyone ever seen one of those nuts work loose? I never have.
dungbug
PostPosted: 22:27 - 07 Sep 2012    Post subject: Reply with quote
For the sake of a few pence, it's daft not too. Smile
GrumpyGuts
PostPosted: 22:58 - 07 Sep 2012    Post subject: Reply with quote
The only thing that worried me was putting the rear sprocket the wrong way round, deffo not a big deal? Safe to leave it?
Split being replaced tomorrow as I have no spares Thumbs Down
GrumpyGuts
PostPosted: 23:07 - 07 Sep 2012    Post subject: Reply with quote
OK I will check that tomorrow. I did spin the wheel and it looked OK to me, plus I checked the sprocket to see if was straight either side after noticing my mistake and looked fine to me.
By the way, head gasket is tomorrow. Thread to follow Mr. Green
Kradmelder
PostPosted: 06:33 - 08 Sep 2012    Post subject: Reply with quote
Your sprockets didn't look too bad. How many km did you have on them?
Unless you a fussy bastard like me and like everything just right.
2011 KTM 990 Dakar
2009 BMW 1200 GS
janner_10
PostPosted: 10:23 - 08 Sep 2012    Post subject: Reply with quote
Top job mate. Can I book you to do mine shortly? Wink Wink
nowhere.elysium
The Pork Lord
PostPosted: 10:27 - 08 Sep 2012    Post subject: Reply with quote
Having read your previous workshop thread regarding changing a gear cable, I think that you should indeed be lauded for sorting this out single-handedly.
Congratulations, you've started the epic and painful climb up the rockface that is the home mechanic's learning curve. May it prove fruitful, and slightly less excruciating than garage costs would be.
GrumpyGuts
PostPosted: 23:49 - 08 Sep 2012    Post subject: Reply with quote
The previous owner stated that he had replaced the chain and sprockets before selling, but he must have replaced them with used sprockets or lied to me as they were worn. The chain kept jumping even after re-tensioning it.
I got the bike around 18,500 miles and I have done 2,200 miles since
The last post was made 14 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 104.68 Kb
