chain tension question
open
PostPosted: 09:55 - 08 Sep 2012    Post subject: chain tension question Reply with quote
So I tightened the chain on my cg125 ( while it was on the centre stand) and thought it was ok, but I realized that the chain is extremely tight when taken off the centre stand and has a couple cm's free play when on!
What should do, and is this normal?
"Calamity - A more than commonly plain & unmistakable reminder that the affairs of this life are not of our own ordering."
[s]Baotian BT49qt-9 --> Honda CG125 (4 speed) '51 plate ----- 03/11/2012 Mod 2 PASSED! --> Cb500s[/s] Revoked Sad
GREENI3
PostPosted: 10:13 - 08 Sep 2012    Post subject: Reply with quote
Should be about an inch or inch an 1/4 with the bike on the centre stand.
PostPosted: 15:58 - 08 Sep 2012    Post subject: Reply with quote
What's happened is normal but it's not right as Vincent said. The chain is at it's tightes when the axis of the engine output shaft, swingarm pivot and rear spindle are in line with each other, and that only happens when you are sitting on the bike. Since the shock will be fully extended when the bike is on the stand, that's when the spindle is lowest and the chain is the most slack.
Put it on the sidestand and set it to about 25mm total up/down play.
The last post was made 14 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 40.11 Kb
