| binge |
 binge Emo Kiddy
 Posted: 17:42 - 08 Sep 2012 Post subject: Very low pressure fuel pump |
Hey guys,
I've asked on a few mini-bike / pit bike specific forums already, and cant get much of an answer.
The Chaly will only use the first half of the tank.
Being gravity fed, once the fuel gets lower than that, it cuts out, both on reserve, and 'on'.
It seems to be a common thing with the Chaly and Dax.
I keep seeing vacuum operated pumps on ebay, but I cant help but thinks these are just fuel taps, not actual pumps.
It's just a single 26mm carb, so will literally need a couple of psi, if that.
Are there vacuum pumps available, as I'd prefer one of these.
Ben |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:37 - 08 Sep 2012 Post subject: |
Small fuel pump from an old SU carburated car... if you have a 'head' of fuel pours straight through them, but if there's nothing in the 'out' line they cut in and start pumping. Search for electric fuel pump for Mini, or Morris Minor.
Later engines had mechanical pumps driven off the cam, but early ones had electric pumps, wonderful electro-mechanical things with points in them! After-market replacements had electronic controllers and were a nightmare when they burned out! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stinkwheel |
 Posted: 18:53 - 08 Sep 2012 Post subject: |
I do know an XTZ 750 fuel pump is vacuum operated because my mate fitted one to his transalp for use with an auxilliary fuel tank.
EDIT: Given the relative amounts of vacuum generated by the two engines, it's a fairly safe bet it'll be low pressure.
That said, why low pressure? The needle valve on a C90 carb is exactly the same as the one on a bigger bike and that's ultimately what cuts off the flow of fuel. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| binge |
 binge Emo Kiddy
| Matt578 |
 Matt578 Nova Slayer
 Posted: 21:49 - 08 Sep 2012 Post subject: |
Something like Sucky Blowy Pump ____________________ Your Daddy, Everyone's Friend. |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 05:27 - 09 Sep 2012 Post subject: |
| Matt578 |
 Matt578 Nova Slayer
| binge |
 binge Emo Kiddy
| Pete. |
 Pete. Super Spammer
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
The last post was made 14 years, 41 days ago. Instead of replying here, would creating a new thread be more useful? |
