Cracks around drilled vent holes on rear disc - MOT failure?
Cheeseybeaner
PostPosted: 18:08 - 09 Sep 2012    Post subject: Cracks around drilled vent holes on rear disc - MOT failure? Reply with quote
Wondering if cracks forming around the drill holes on my rear disc (diversion 900) are an auto MOT failure?
The mounting holes are fine they're just small crack a few mm each
that seem to be forming around the drilled vent holes.
It was a cheap replacement, about £40 on ebay rather than an original Yamaha one - probably a good reason to pay the extra for the dearer discs though must have had a good 70k miles use nonetheless...
Hetzer
PostPosted: 18:14 - 09 Sep 2012    Post subject: Reply with quote
If the MOT doesn't fail it (and it will if the tester spots them) the crash you'll probably have when the disc disintegrates on a high-speed brake will almost certainly fail your life-support systems. Laughing
Islander
PostPosted: 18:26 - 09 Sep 2012    Post subject: Reply with quote
Hetzer is right. What is going to happen if you get a stress fracture between the cracks on the disc and it jams on the pads? Rolling Eyes
Cheeseybeaner
PostPosted: 19:11 - 09 Sep 2012    Post subject: Reply with quote
Thanks I only just noticed them coming up a new disc shall be fitted . Unusual thing to happen though don't you think? Maybe the materials just aren't up to scratch on these cheaper rotors.
janner_10
PostPosted: 19:16 - 09 Sep 2012    Post subject: Reply with quote
Who gives a fig what the tester thinks. You have dangerous disc, change it as soon as!
sidewinder
PostPosted: 20:57 - 09 Sep 2012    Post subject: Reply with quote
Big danger coming to you soon .Change it now Thumbs Up
Hetzer
PostPosted: 21:02 - 09 Sep 2012    Post subject: Reply with quote
Probably made in china, and as we all know those cheap prideless cunts couldn't make a paper bag fit for purpose unless a westerner is holding their hands and watching over their shoulders.
PostPosted: 21:12 - 09 Sep 2012    Post subject: Reply with quote
It's actually pretty common, even on OEM discs.
UrbanRacer
PostPosted: 21:15 - 09 Sep 2012    Post subject: Reply with quote
Yep, it happens on drilled discs. even ultra expensive Porsche's have this problem.
Islander
PostPosted: 22:08 - 09 Sep 2012    Post subject: Reply with quote
Yep. It used to be common on Brembo discs fitted to BMW tourers. Brake discs have to handle a lot of physical and thermal stress.
The last post was made 14 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 70.5 Kb
