sheared oil filter cover bolts, I'm an idiot!
Ribenapigeon
PostPosted: 16:44 - 09 Sep 2012    Post subject: sheared oil filter cover bolts, I'm an idiot! Reply with quote
I did a really reallly stupid thing. I over torqued two of the bolts holding my oil filter cover on. It was entirly my own fault, instead of checking the manual I 'remembered' the torque level for the bolts as 14nm. Of course after shearing the bolts I consulted the manual and its said 10nm. Luckily the bolts were standard M6x20 bolts and I had some in my tool kit and also enough of the bolts were left sticking out of the engine block to get a grip with some pliers and withdraw them. Otherwise god knows what I would have done. It just goes to show though that the old adage "measure twice cut once" or in my case "RTFM.....twice" is always appropriate. :-/
carvell
Scuttler
PostPosted: 16:50 - 09 Sep 2012    Post subject: Reply with quote
You sheared an M6 bolt with 14nm?!
Yamaha TDM 850
Ribenapigeon
PostPosted: 16:54 - 09 Sep 2012    Post subject: Reply with quote
Well 14nm is an estimate as the lowest setting on the wrench was 20 but I moved the vernier adjuster around to loosen it to what I aproximated was 14nm. Another stupid move on my part.
snikks
PostPosted: 17:25 - 09 Sep 2012    Post subject: Reply with quote
Those wrenches are pretty inaccurate at the extreme ends of their rated ranges - let alone past them. This was a lesson learnt by shearing off the bolts on my own oil filter cover on my Varadero =_=.
You're better off just going finger tight, then another turn or two in until it's tight enough to seal, rather than trying to torque it.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
J.M.
PostPosted: 18:51 - 09 Sep 2012    Post subject: Reply with quote
I did this too. I've been far too used to tightening things up until I physically can't tighten them anymore.
This. After snapping one of the bolts in the exact same way as OP I was told about this technique. Works a charm. Smile
2004 R1 & 2018 XSR900
Ribenapigeon
PostPosted: 19:25 - 09 Sep 2012    Post subject: Reply with quote
Phew glad I'm not the only one Smile
PostPosted: 19:54 - 09 Sep 2012    Post subject: Reply with quote
This is why I still use an old stylee deflecting beam rather than a clicky wrench, when I even bother to use it at all. It's an aid to mechanical sympathy, rather than a replacement for it.
jeddy11
PostPosted: 20:27 - 09 Sep 2012    Post subject: Reply with quote
you snapped 2 before realising ??
Agree these are not critical bolts so no need to torque i hear a lot of stories of snapped bolts whilst using torque wrenches. whats wrong with nipping them up with a socket/spanner ? you can tell when its tight..
Engine bolts and heads criticle aqreas etc yes use proper torques .
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
Ribenapigeon
PostPosted: 20:29 - 09 Sep 2012    Post subject: Reply with quote
I couldent find the old style ones anywhere Sad
The first one I think I mistook the shearing for the click.
PostPosted: 07:54 - 10 Sep 2012    Post subject: Reply with quote
Umm, a FLAT or two, not a turn mate. Thumbs Up
Triumph Trophy Launch Edition
snikks
PostPosted: 08:33 - 10 Sep 2012    Post subject: Reply with quote
Maybe I just have girly weak fingers then Wink
covent.gardens
World Clap Champion
PostPosted: 08:55 - 10 Sep 2012    Post subject: Reply with quote
For a normal nut/bolt I'd do finger tight and then at least another 3/4 turn, unless it started to feel wrong. One or two flats would be too loose still, unless your idea of finger tight is different to mine.
The last post was made 13 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 15 - Page Size: 77.71 Kb
