srad 1st gear clunk
choonsy
PostPosted: 11:53 - 10 Sep 2012    Post subject: srad 1st gear clunk Reply with quote
the problem seems to happen more when the bike has warmed a little but what happens is when i set off in 1st gear bike will roll and clunk loudly, then that is it until about 7-9k revs and then a crunch of gears happens, had a bit of advice off various people but nothing concrete. ive got a gear box to fit if needed but didnt want to rave all that out if could be an easy fix... any questions will be answered asap, many thanks in advance
Budgetboy
PostPosted: 13:40 - 10 Sep 2012    Post subject: Reply with quote
Does not sound good.. Sounds like gearbox selector forks to me..Or it could be just the gearbox itself.. hard to tell over the net, but you should really not be riding it as you WILL do more damage..
Change the gear box and measure the selector forks to make sure these are in spec.
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
choonsy
PostPosted: 11:25 - 11 Sep 2012    Post subject: srad gear box Reply with quote
thanks for the advice , i have someone researching how to fit a gear box now who is quite mechanicly minded but any links to help if you know any would be good, any idea how much a garage would charge to fit the gear box? i have one ready to fit. many thanks
PostPosted: 15:41 - 11 Sep 2012    Post subject: Re: srad 1st gear clunk Reply with quote
You're getting clunking when pulling in 1st and then when you get to high revs it turns into a machine-gun reptition of same noise?
Rounded gear dogs on 1st gear. You've probably battered a notch in the shift drum too.
The gearbox had to come out. Being a gixxer, you might be lucky and find you can pull the bottom casing off to get at the gearbox without stripping off the top-end.
choonsy
PostPosted: 19:14 - 11 Sep 2012    Post subject: Reply with quote
cheers , were changing gear box tommorow onwards, complete gear box change,,, gonna be as simple as cheese , lol yep right. any further advice would be greatly recieved guys, any links, or just knowledge from the wise
MaybeGuy
PostPosted: 20:27 - 11 Sep 2012    Post subject: Re: srad 1st gear clunk Reply with quote
Yeah, this is the case. I did the gearbox on a 750 SRAD not too long ago, and as far as gearboxes go, it's bloody simple to do. Sump off, split casings, gearbox comes out. Engine upside down preferably.
Reverse the process, job done.
Symptoms were what you describe, but in 6th gear, but IIRC, they're linked.
You'll need a new sump, clutch and generator gasket, and a tube of crankcase sealant. Fuck that thought we, so we just bought some cereal. If you ever find you have a weetabix sump gasket on your 750 gix, chances are I've been in it.
The SRAD in question was then test ridden... from Plymouth to Leeds... No problems, and now sold.
The last post was made 14 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 50.56 Kb
