Lean-running GS500, all of a sudden?
ClockworkJesu...
PostPosted: 11:15 - 11 Sep 2012    Post subject: Lean-running GS500, all of a sudden? Reply with quote
Hey, so, I've a '98 GS500E with a '94 engine, if that makes any difference.
Anyway, she'd always been great on start-up, firing off the button with full choke whatever the weather. But recently she's been cranking over longer than usual.
So I ignored it for a bit, but today during a few basic checks, I whipped the sparkplugs out and they were white!
Last time I checked they were the sandy-cardboardy colour you'd expect. But for some reason the GS has started running lean?
I've got no idea what it could be. I've had a problem with fuel delivery in the past (Sometimes if I ragged it, usually in 5th, the bike would start to choke and splutter like it was running out of fuel, but, the tank's nowhere near empty. Fuel demand problem?) but it's not a constant, ever-present issue.
Dying sparkplugs not producing a bright enough spark? :S
J.M.
PostPosted: 11:32 - 11 Sep 2012    Post subject: Re: Lean-running GS500, all of a sudden? Reply with quote
I can't comment on the cranking over (my only experiences with this before have been battery related) or the spark plugs.
I think that I can comment on this however. Pre-2004 GS500s have a common problem of suffering from fuel starvation at higher speeds. If it bothers you, you could solve it by fitting a Pingel or fitting the petcock from a 2004+ GS500.
More information can be found here on the petcock: https://wiki.gstwins.com/index.php?n=Upgrades.Petcock Smile
2004 R1 & 2018 XSR900
ClockworkJesu...
PostPosted: 11:40 - 11 Sep 2012    Post subject: Reply with quote
That's a great bit of news. Thanks, J.M.
Doesn't look like Pingel make a fuel-tap for a GS500, but a 2004+ petcock should be easy enough to source. Thumbs Up
ClockworkJesu...
PostPosted: 11:51 - 11 Sep 2012    Post subject: Reply with quote
_Iain_ wrote:
Mine did exactly this.
Air leaks on the intake rubbers & clogged carbs.
Then for my hard work the engine turned itself into a case of metal filings... Mad
._. Damn. I'll have to give those a check then. Laughing not sure I have the funds to stick a new engine in the bloody thing.
Means dedicating a day to pulling the old girl apart I suppose.
orac
PostPosted: 12:16 - 11 Sep 2012    Post subject: Reply with quote
the fastest way to check if you have an intake leak is to get the thing warmed up and idling then spray the rubbers with WD40 or alike, if the revs change then you have a leak, if they stay the same, your rubber are more than likely fine.
after that strip clean and rebuild carbs, if they are both the same (plug colour that is) then it may well be a fuel issue. dont forget that the gs5 has 2 fuel tap, one on the bottom of the tank and a vacumm tap so check thing like vaccum hose.
also another thing to check while you are looking at carbs is float hights, if that are set wrong they will starve the engine of fuel.
alos check you have a strong spark, normally weak spark makes it over rich but it will be worth a check while you are there
ClockworkJesu...
PostPosted: 12:27 - 11 Sep 2012    Post subject: Reply with quote
I'll definately give that a go. If I can find any WD40!
Yeah. Both plugs are about as white as one another.
Good point. Will have to check the vacuum hose definitely. The fuel-lines on there at the moment are braided and quite chunky, and a bitch to get on the nipples. Restrictive fuel-lines could be a problem?
Will do.
Thanks a bunch; Got a nice big list of reasons not to leave the garage!
_Iain_ wrote:
Totally unrelated engine death - ran sweet as a nut after sorting the carbs/rubbers out.
Dont think it appreciated my attempt at beating paddys 120mph on a GS. Managed just over 110mph. On private roads obviously Wink
I've had 110Mph out of it, just, under standard gearing.
Wink Also, on private roads. I mean, where else?
orac
PostPosted: 12:32 - 11 Sep 2012    Post subject: Reply with quote
doesnt have to be wd40, could be brake cleaner, intake cleaner or anything else that will burn. fuel line could be an issue if they are not the standard bore, dont forget suzuki made them that size for a reason
ClockworkJesu...
PostPosted: 12:38 - 11 Sep 2012    Post subject: Reply with quote
Alright, good info.
Thanks. Thumbs Up Think I'll make my way through the list before looking for some standard fuel-lines. Which have always alluded me. :S
ClockworkJesu...
PostPosted: 13:25 - 11 Sep 2012    Post subject: Reply with quote
_Iain_ wrote:
Spray the rubbers with Easy start. Worked a treat to find my leaks - the wd40 wasnt as noticeable & made a mess.
Texaco also sell easy start & its good at cleaning carbs too
Good to know :] thanks.
ClockworkJesu...
PostPosted: 13:42 - 11 Sep 2012    Post subject: Reply with quote
Well, I got the engine warm and ticking over, a little lumpy but ticking over, and sprayed some chain cleaner between the carbs and the rubbers. Nothing.
Sprayed some chain-cleaner between the rubbers and the head; revs rose for about a second and smoothed out, and then dropped back to their lumpy selves.
Looks like leaky rubbers! Thinking a bit of high-temp silicon behind the rubbers might sort things out. Very Happy
The last post was made 14 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 82.48 Kb
