new brake pistons
GZXR400
PostPosted: 22:46 - 10 Sep 2012    Post subject: new brake pistons Reply with quote
So today i stripped my brakes as when i tried to clean my pistons the tops started to peel apart, removed the calipers and got the pistons out but a few were so stuck they had to be removed with molegrips.
This has put a few scratches in the pistons on the side nearest to where the pads would be, i have cleaned them up and got the rust of the tops but there are small holes there still
I will put some pictures up tomorow but i want to know if there going to be any good, i will defiantly get new seals but pistons are expensive, having said that brakes are important and cant have them fail, once again sorry for no pics thanks
GZXR400
PostPosted: 21:26 - 11 Sep 2012    Post subject: Reply with quote
Hi iv been told the pistons are fine so i will be reusing them
i have removed the seals and spent a good few hours trying to remove all the dirt from the calipers, absolute nightmare iv been using brake cleaner with a toothbrush and also tried soapy water and still cant get it off
https://img341.imageshack.us/img341/9364/20120911165351.jpg
GZXR400
PostPosted: 21:43 - 11 Sep 2012    Post subject: Reply with quote
yeah theres a few brisles from the toothbrush i found just hope theres no inside where the fluid does
Raffles
PostPosted: 21:52 - 11 Sep 2012    Post subject: Reply with quote
Just blow some compressed air into all of the holes in order to remove any debris and all should be good. Wear some safety glasses or goggles whilst doing so.
GZXR400
PostPosted: 22:03 - 11 Sep 2012    Post subject: Reply with quote
ahh right awesome il get a seal kit ordered then
these are the pistons iv been told these are ok though
this is the worst piston
https://img402.imageshack.us/img402/2640/dsc0038edit.jpg
Frost
PostPosted: 22:27 - 11 Sep 2012    Post subject: Reply with quote
That's a nasty mark, but i don't think it's far enough down the piston to matter. When fully pushed in the seals only come up so far on the piston and i think the mark isn't on that surface. Once some pads are in there and the pistons pumped out a bit it'll be clear for sure.
Remember to coat the seal in brake fluid during reassembly as that's what they use for lube.
GZXR400
PostPosted: 22:37 - 11 Sep 2012    Post subject: Reply with quote
I know its concerning me a bit, there was no way i could get the pistons out tried compressed air and in the end they had to be pulled out with molegrips.
and ok will coat them in brake fluid do i need to use any sort of grease when fitting the new seals ?
Thanks
Frost
PostPosted: 23:05 - 11 Sep 2012    Post subject: Reply with quote
For future reference the best way to push pistons out is to use the system purpose built for it, the braking system!
Stick a screw driver where the disc would go on the calliper and pump the pistons out onto it. If you're careful you can get all the pistons 99% out and they will literally fallout when you remove the screw driver.
GZXR400
PostPosted: 23:14 - 11 Sep 2012    Post subject: Reply with quote
yes i tried this but couldnt get them to come out evenly im rather annoyed with myself iv took chunks out of my pistons. is a brake master cylinder seal kit needed aswell ? thanks
stonesie
PostPosted: 23:42 - 11 Sep 2012    Post subject: Reply with quote
Thanks
Look on evilbay for red rubber grease, will only set you back a couple of quid for Castrol stuff and you won't use much.
Fizzer Thou
PostPosted: 14:52 - 12 Sep 2012    Post subject: Reply with quote
https://www.mandp.co.uk/products/list/Spares/Brake-Piston-with-Seals
Always have a 'Plan B'
GZXR400
PostPosted: 16:13 - 12 Sep 2012    Post subject: Reply with quote
iv been told to use only geniune pistons these are 37 quid each
Budgetboy
PostPosted: 16:39 - 12 Sep 2012    Post subject: Reply with quote
Pistons are pitons mate,, its the seals you dont want to skimp on.Cheap seals will leak so get good ones.
Dont forget to clean the grooves out on the piston seal area.Red rubber grease when fitting new pistons as well. Thumbs Up
If it were me i would add in the split caliper seals (half seals). like a small o ring.
And if you wanted to clean the years of brake dust from the caliper you will need to bead blast it IMO.
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
PostPosted: 16:46 - 12 Sep 2012    Post subject: Reply with quote
Got a dishwasher?
Stick them through on a super wash with finish tablets and you're laughing. Thumbs Up
An ultrasonic cleaner does a good job too but not everyone has access to one.
Or try soaking them in paraffin overnight (you wash the paraffin off with the brake cleaner after).
GZXR400
PostPosted: 19:01 - 12 Sep 2012    Post subject: Reply with quote
i have ordered a decent seal kit it has all the seals
i dunno if i should get new pistons then is it necesary ?
GZXR400
PostPosted: 09:00 - 13 Sep 2012    Post subject: Reply with quote
Got a dishwasher?
iv got a dishwasher but dont like the idea of putting something that has had brake fluid and brake dust etc through it, i think il leave the calipers now they arnt super clean but there is no loose dirt on them
stonesie
PostPosted: 19:19 - 13 Sep 2012    Post subject: Reply with quote
Try some Mr Muscle oven cleaner Thumbs Up
If you haven't got any in the house then add a pair of marigolds to the shopping list and some really cheap stiff brushes (not metal bristles).
GZXR400
PostPosted: 23:00 - 18 Sep 2012    Post subject: Reply with quote
Are there any real differences in brake fluid brands for example castrol dot 4 fluid at £10 or £5-£6 universal fluid ?
Frost
PostPosted: 23:20 - 18 Sep 2012    Post subject: Reply with quote
Provided they're both DOT4 there won't be much difference at all. Maybe a slight change in the boiling point, but unless you're doing track days there's no point at all. Use generic stuff and you won't be afraid of wasting some as you properly bleed the brakes.
GZXR400
PostPosted: 20:15 - 23 Sep 2012    Post subject: Reply with quote
bit of a problem, rebuilt calipers with new seals and pistons, new pads and pins, took about 2hrs to bleed but brake lever still spongy.
Noticed brake fluid leaking from one of the calipers so looks like a piston is leaking
what now ?
herulach
PostPosted: 20:43 - 23 Sep 2012    Post subject: Reply with quote
what now ?
Caliper off, see if you can see where its leaking from, my money would be on you either nicking or forgetting one of the seals between the two caliper halves.
YBR 125>FZS600
GZXR400
PostPosted: 21:31 - 23 Sep 2012    Post subject: Reply with quote
all seals are defiantly in there as i have none left and i remember putting 2 seals in each piston hole and the caliper half seals.
Is is possible that my half seal has moved when tightening up the assemble bolts ?
The last post was made 13 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 131.14 Kb
