Starter Motor Turning the Wrong Way!!!!!
Tinkerbell
PostPosted: 20:29 - 08 Oct 2005    Post subject: Starter Motor Turning the Wrong Way!!!!! Reply with quote
I have a Yamaha SR 125 and was wondering if anyone could suggest whats wrong.
I filled the bike up with too much oil (i no im dumb!) so it blew the head gasket, thats been changed now. I did have a problem with my gear box so the friction plates, the steel plates and the flywheel has been changed.
As you can guess we had the whole bike appart to fix it however we put the starter motor back on last night and noticed its turning the wrong way!! Any suggestions or ideas why this is happening?
Thanks Surprised
mchaggis
PostPosted: 20:36 - 08 Oct 2005    Post subject: Reply with quote
You've probably managed to get the earth and live connections the wrong way around somehow. The starter motor won't turn the engine over if it spinning the wrong direction anyway.
I must not be a troll...
Mmmm, Guinness
tatters
Exxon Valdez
Wrong polilaty, swap the postive and negtive connectors around, on the starter motor.
Tinkerbell
PostPosted: 21:14 - 08 Oct 2005    Post subject: Reply with quote
Thanks for your advise we have checked the connections and no luck there Sad
Ichy
PostPosted: 21:21 - 08 Oct 2005    Post subject: Reply with quote
Hi, how do you know its turning the wrong way, have you tried starting the bike?
Tinkerbell
PostPosted: 21:36 - 08 Oct 2005    Post subject: Reply with quote
we did try to start the bike and of course if the starter motors not working its going nowhere lol
Ive double checked whats wrong...its not turning the big cog behind the dymno :S
mchaggis
PostPosted: 00:28 - 09 Oct 2005    Post subject: Reply with quote
Assuming that said large gear is in constant mesh with the flywheel, the starter motor running in reverse won't spin it, as the sprag (one-way) clutch between the motor and the starter gear won't engage.
Mmmm, Guinness
Ichy
PostPosted: 01:35 - 09 Oct 2005    Post subject: Reply with quote
Well the only way a motor can run backwards is if the power is applied the same i.e. pos to neg, neg to pos. There is no other way. try a multimeter across the terminal when you press the starter.
Guest
PostPosted: 06:14 - 09 Oct 2005    Post subject: Reply with quote
Don't know the SR, but all starter motors I've touched use the mounting lugs as earth so there's only the power connection to undo. So you can't wire 'em up back to front.
If you have the motor apart though, and put it back together wrong it will spin the wrong way.
Ichy
PostPosted: 13:37 - 09 Oct 2005    Post subject: Reply with quote
For my own info since I've never had a problem (so far) with bike starters. If the gears aren't engaging could it be that the starter motor is just not (don't know proper name) ejecting the starter gear on the the main cog. I know this can be a common problem on some cars and the fix is usually to hit the back of the starter with a SOFT hammer to release it.
Guest
PostPosted: 15:06 - 09 Oct 2005    Post subject: Reply with quote
Marki, if you mean a Bendix type arrangement you generally only find them on BM's, Guzzis and the like.
If it was a Suzuki I'd say the rollers or the springs that push them onto the drive boss were knackered. that way the starter motor turns fine but the rollers don't grip what they oughta and the engine doesn't turn.
Is that the set-up on the SR?
https://70.85.253.252/spst/1979%20GS1000S/46.gif
The rollers (#5) grip the boss on the big gear wheel until the engine's spinning fast enough for the centrifugal effect to overcome the 'push' of the springs. It's a common wear problem on old GS fours.
There is a gap of 6 years, 339 days between these two posts...
oceandp
PostPosted: 09:05 - 12 Sep 2012    Post subject: Reply with quote
try turning the starter housing about 1/4 turn to right..and align screws in newopening between magnets, that will reverse polarity on windings...
oceandp
nowhere.elysium
The Pork Lord
PostPosted: 09:08 - 12 Sep 2012    Post subject: Reply with quote
I'm sure that they've sorted the problem in the intervening seven years.
Read the date before posting.
PostPosted: 09:21 - 12 Sep 2012    Post subject: Reply with quote
Maybe its time to reverse the polarity of the neutron flow?
oceandp
PostPosted: 09:37 - 12 Sep 2012    Post subject: Reply with quote
thaks guys you are too helpfull...now maybe you can tell me how the h do i delete myself from your high and mighty group...
BTW my starter run backwards and your group never had an answer..
oceandp
PostPosted: 09:41 - 12 Sep 2012    Post subject: Reply with quote
https://t3.gstatic.com/images?q=tbn:ANd9GcRT84FHUzLjV7Rpl_DPEZLG9XtMMwQiSLUGu6E3vJbVibr7_2yNKmwHyNrO
nowhere.elysium
The Pork Lord
PostPosted: 09:48 - 12 Sep 2012    Post subject: Reply with quote
That's the crappiest reason to flounce in the history of forums.
If a thread is more than, say, a year old, then it can safely be considered to have been long abandoned. It's usually worth starting a new one, as it won't attract the ire of established users.
If, however, you still wish to depart BCF, none of us will stop you; although contacting the admin to have your account deleted may result in an exceptionally long wait on your part.
PostPosted: 10:25 - 12 Sep 2012    Post subject: Reply with quote
Here's an SQL query that Korn can run:
Delete from USER where flounce = 1 and post_count < 10 and sense_of_humour = 0 and sensitivity > 0.5;
matto
PostPosted: 11:13 - 12 Sep 2012    Post subject: Reply with quote
wonder if Tinkerbell is sore after 7 years of riding like this:
https://www.motorcycleinsurance.com/wp-content/uploads/2012/02/Bob-Duffey-BackwardXR.jpg
Timmeh
PostPosted: 11:14 - 13 Sep 2012    Post subject: Reply with quote
haha
janner_10
PostPosted: 12:46 - 13 Sep 2012    Post subject: Reply with quote
https://t1.gstatic.com/images?q=tbn:ANd9GcRaxgCIEsKNxXLiI0D0V97sJmjGaG98-VfJEbwrr5w8ad45HJkdkR3jru76
The last post was made 14 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.84 - MySQL Queries: 13 - Page Size: 110.97 Kb
