Aligning and adjusting front forks NSR125 alcast
Matt-
PostPosted: 16:21 - 12 Sep 2012    Post subject: Aligning and adjusting front forks NSR125 alcast Reply with quote
Hi guy's
Think I have fixed the front brake issue now I have have another issue
The brake disks seems to rub in the caliper some how, pistons are not seized, pins are not seized, carrier, seems ok and sliders seem to work fine, pads have good meat left on them, disc is good and not warped.
So it leaves forks to look at now?
Any help is appreciated, also the caliper seems quite loose on the carrier, slide is good and other slider is good.
Seems to have little play in it but I think it's because the pads arnt sitting on the disc yet.
Many thank
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Islander
PostPosted: 16:37 - 12 Sep 2012    Post subject: Reply with quote
Unless the pads are actually binding on the discs, I wouldn't worry. Disc brakes are designed to have the pads in contact with the discs at all times.
Matt-
PostPosted: 16:41 - 12 Sep 2012    Post subject: Reply with quote
It's for the MOT so is got to spin freely Sad
Islander
PostPosted: 16:48 - 12 Sep 2012    Post subject: Reply with quote
So are the pads binding on the discs? Can you spin the wheel without undue resistance?
Matt-
PostPosted: 16:54 - 12 Sep 2012    Post subject: Reply with quote
Theirs resistance on one mark on some places of the disc, it's not a constant resistance ??
Hmmm really confused !
Islander
PostPosted: 16:57 - 12 Sep 2012    Post subject: Reply with quote
Spin freely just means that the pads shouldn't be binding - you should be able to spin the wheel without undue resistance.
Matt-
PostPosted: 17:21 - 12 Sep 2012    Post subject: Reply with quote
It's not a normaly pad running noise though it's like a metal to metal noise ? My forms have been out as I hav done fork seals, so they may need aligning ?
Islander
PostPosted: 17:58 - 12 Sep 2012    Post subject: Reply with quote
With the handlebars set straight across the line of the bike is the front wheel pointing straight ahead? Are the tops of the legs set to the same height in the clamps? That's about it for fork alignment really.
If you think something is rubbing where it shouldn't then you need to have a closer look to see what's going on. Shine a torch down into the calipers while you're spinning the wheel. You could also remove the pads and remount the calipers (if you do this then be very careful not to touch the front brake lever) to see if anything's catching.
To be honest, without actually seeing the bike it's hard to say whether things are normal or not.
Matt-
PostPosted: 18:10 - 12 Sep 2012    Post subject: Reply with quote
Yeah that sound's great. Il try that then il have a closer look and make a video and upload to YouTube Smile
The last post was made 14 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 59.56 Kb
