| headlamp |
 headlamp World Chat Champion
 Posted: 13:17 - 23 Oct 2004 Post subject: FZR 600 Tyres (Again) |
Hi,
After buying a digital tyre pressure checker and finding the pressures really low - I started pumping the rear tyre and noticed that it was seriously worn - to the extent I reckon it needs replacing! I have done 7,300 miles - is that about the life expectancy of the tyre? Also if I pump it up to the recommended tyre pressure I will almost be riding on slicks, whereas leaving it as it is there will be some tread due to the lower pressure!
BTW the front is fine and now pumped up to the recommended tyre pressure!
Suggestions?
Thanks
H ____________________ Using a mobile phone while driving a car should be made a capital offence! |
| Hex |
 Hex Party Boy
 Posted: 13:26 - 23 Oct 2004 Post subject: |
Pump it up to its correct pressure, ride to the shop and get another tyre.
Tyre wear depends on the compound of the tyre (the softer ones can go in 3000 miles), weight of the bike, power going through the tyre and type of riding you do.
I expect I'll get about 4000 or so out of my rear tyre. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
| stryker |
 stryker Brolly Dolly
 Posted: 14:02 - 25 Oct 2004 Post subject: |
To the first question, I am very light on tyres and the best I get is around 10000 miles from a set. It is easy to get less miles.
For the FZR600 there is very little choice of tyres. Like none. Your bike should have a 4" rim (earlier ones had a 3.5" rim, think the FZR600R from 1994 had 17" rims), but I suspect a 150 is the largest you can get on there due to the chain (check how close the chain runs to the tyre).
The only tyre that still seems to be available that is V or Z rated and is available in the correct size (140/60 18, stretching to a 150/60 18) is the Bridgestone BT010 (and the new BT014 which replaces it). Cheapest price I have found for BT010s is £180 fitted to loose wheels from "Road & Race Ltd" in Oldbury on 0121 544 5146. If you find a better price than this then please let me know (quickly ).
There are plenty of H rated tyres available in the right size (commonly used on the VFR400), but the FZR is a touch quicker than the VFR and thus edges out of the range of these lower rated tyres.
| stryker |
| stryker |
| yzf750r |
 yzf750r World Chat Champion
| stryker |
 Posted: 19:07 - 05 Nov 2004 Post subject: |
I don't know if the FZR600R rear wheel will fit in an FZR600.
The R uses a 17" rear wheel, which tends to suggest you would want a 160/60 tyre to have about the same diameter, and I am not sure that there is enough clearance between the tyre and the chain for this. This may not be a massive problem. If the rear sprocket on the replacement wheel is only slightly offset then it might be possible to get a front sprocket made up with a small amount of offset.
I also have a feeling that Yamaha might have used a larger wheel spindle on the R than on the earlier bike.
If there are no issues with the chain clearance then I suspect you could fit a complete FZR600R swinging arm with wheel. Yamaha are quite good at keeping things fairly standard. Also suspect that a Thundercat back end would fit just as easily.
The 1989 model has the 3.5" rim which had a 130 tyre as standard. Think there is a tyre still sold in that size, but if not the 4" rim used on the 1991~1993 bikes should fit and then you can use the BT010 in 150/60 18 size. Looking through a few listings it looks like you could get away with running a 160 rear tyre on the 4" rim, and the early FZR1000 used a 160 on an 18" rim so that might open up a little more choice (Michelin sell a few 160 tyres in that size).
The last post was made 21 years, 319 days ago. Instead of replying here, would creating a new thread be more useful? |
