| cyclistbruce |
 cyclistbruce Derestricted Danger
| _Iain_ |
 _Iain_ Banned
 Posted: 21:20 - 11 Sep 2012 Post subject: |
Clutch dragging.
Tighten up the adjuster and see what happens.
Failing that - assuming its a wet clutch an oil change has helped my bikes in the past.  ____________________ Please be aware that the above post may be full of complete nonsense.
| chris-red |
| map |
 map Mr Calendar
 Posted: 21:43 - 11 Sep 2012 Post subject: |
An 06 so that'd be the 1300.
Also check oil. If too full or too old can cause problems.
You might want to check out my-mc.com, specifically the ST1300 topics. You can also delve into the old my-mc.com forum for information. Search on either of these to see if your issue reported/solved. If not don't be afraid to sign up and ask on there. They are quite friendly although replies not as immediate as on here due to the different nature of the members there.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| stonesie |
 stonesie World Chat Champion
 Posted: 23:50 - 11 Sep 2012 Post subject: |
Agreed with Chris Red, I had this on the Suzuki and a mate on his ZX9R, both had a load of gunk in the shift pedal pivot so a swift strip/clean/grease sorted them An instructor bike will have been out in all weathers so it could well be gunged up. |
| Fizzer Thou |
| cyclistbruce |
| map |
 map Mr Calendar
 Posted: 10:35 - 13 Sep 2012 Post subject: |
Can you also check the fluid in the clutch? When was it last changed and how dark is it? Do you have air in the lines? (try bleeding, ott article here).
I also know on the ST1100 the seals can go on the slave cylinder so you get air into the system (but not so it leaks strangely). I say this because I need to look at mine, clutch doesn't like being used in traffic as bite point moves back to the bars to such an extent doesn't disengage. Leave if for 20 minutes or so and back to normal!
Not saying you have this issue but on mine before it gets really bad it makes gear selection really hard. Like the gear lever is stuck as you describe.
There is a gap of 3 years, 278 days between these two posts... |
| Dave B. |
 Dave B. L Plate Warrior
 Posted: 20:46 - 17 Jun 2016 Post subject: ST1300 Gear selector problems. |
Getting worse over a period of months trouble shifting down gears when still cold got worse. Worried I Googled symtoms and found that a linkage from nearside shift pedal, under the engine, to offside gear selector can become dry and stiff! Spray lubrication of the linkage joints was like getting a new gearbox! The linkage is exposed to spray, wet, dirt and dust so just needs a bit of care and attention! (Like us all!)! Problem solved!  |
The last post was made 10 years, 115 days ago. Instead of replying here, would creating a new thread be more useful? |
