CBF125 Headlight bulb
wots
PostPosted: 07:47 - 13 Sep 2012    Post subject: CBF125 Headlight bulb Reply with quote
I bought a new H4 OSRAM bulb, the clearer ones. However I've just noticed that the existing is 35w and the new one is 55w. I take it this is a no go then? As there would be an extra 20W load and the headlight unit is probably not designed for that extra bit of heat?
Matt-
PostPosted: 10:03 - 13 Sep 2012    Post subject: Reply with quote
No don't don't do it, has the effect of a overload not only can damage your bike, can also brake the bulb, i suggest getting the correct one.
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
wots
PostPosted: 10:04 - 13 Sep 2012    Post subject: Reply with quote
Thanks, thought that was the case.
Matt-
PostPosted: 10:08 - 13 Sep 2012    Post subject: Reply with quote
Just take the bulb in to your local motor shop, and show them the old bulb and they can match it up to a new one Thumbs Up
wots
PostPosted: 10:12 - 13 Sep 2012    Post subject: Reply with quote
Electrically I'm quite savvy, which was why I thought the extra loading for wiring and the headlight can only handle the heat from a 35W bulb by design. I just wanted to confirm this was the case, which you've done. Cheers Thumbs Up
Islander
PostPosted: 10:50 - 13 Sep 2012    Post subject: Reply with quote
The main risk is overloading the cabling which can cause the copper to heat up and can eventually melt through the insulation. If you have a fuse specifically feeding the lights it may weaken that too. You've effectively increased the current demand for the headlight by 50% from approx 3 amps to 4.5 amps.
The last post was made 14 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 3.34 - MySQL Queries: 13 - Page Size: 46.3 Kb
