what's the effect of having squared off tyres?
WULFSTAN
PostPosted: 18:53 - 16 Sep 2012    Post subject: what's the effect of having squared off tyres? Reply with quote
like the title says really just got back from the outer hebs and there a right mess.
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
Eddie Hitler
PostPosted: 18:55 - 16 Sep 2012    Post subject: Reply with quote
Not really hard to figure out the effects.. right?
Odd feel to the bike, steering harder, feels like it's dropping suddenly into the corner..
Replace it, if that's what you're actually asking.
Formerly known as
P.
Feels weird and doesn't like to turn properly.
WULFSTAN
PostPosted: 18:56 - 16 Sep 2012    Post subject: Reply with quote
thats my bike all over thanks
Eddie Hitler
PostPosted: 18:58 - 16 Sep 2012    Post subject: Reply with quote
Derivative
The rear on my CB is squared off.
I've not noticed any real negative effects. Still have a good amount of tread left, probably >5mm.
Is it actually that significant as long as you're not trying to get your knee down? I'd be replacing the rear every 5k or less, all I do is motorway.
arry
PostPosted: 19:01 - 16 Sep 2012    Post subject: Reply with quote
Had my rear BT023 square off on the Triumph not so long ago, it was horrible. Fine in a straight line, fine at a slight bend, fine when right over on its side, but on a medium lean it was like a knife edge. And especially accelerating out of a bend, it'd make the back feel like it's wobbling when you roll on the throttle and get a bit more on the gas as the bike comes upright.
Awful.
Eddie Hitler
PostPosted: 19:02 - 16 Sep 2012    Post subject: Reply with quote
No, I just attempted to answer the OPs question about it. Although If his motorbike was acting oddly, then saw his rear tyre was squared, how didn't he link where the problem was for himself?
Or am I a cunt. Probably a cunt. Laughing
Handsome
PostPosted: 19:04 - 16 Sep 2012    Post subject: Reply with quote
My last rear part worn was squared off, had all the effects of the above mentioned, took it out for a good 60 odd mile or so scrub in and it sorted it out, just take it easy in corners until the profile wears down again...
map
Mr Calendar
PostPosted: 19:10 - 16 Sep 2012    Post subject: Reply with quote
Eddie Hitler wrote:
...feels like it's dropping suddenly into the corner...
Interesting as I've been having issues setting off at junctions. When turning right the bike does feel it's going to fall, as in turn in quicker. Will go and check when it's light.
Eddie Hitler
PostPosted: 19:14 - 16 Sep 2012    Post subject: Reply with quote
When I first bought my FZR the front tyre had almost had it. After riding it 3 weeks, I kept losing the front, felt horrible turning in like yours, etc. Basically looked like /^\ when a normal tyre is (^) if you see what I mean. Replaced it and felt great.
Would also check your headrace bearings, I know that causes a horrible sensation turning in too, when knackered.
Resistance to turn-in, then 'falling in' when you've got it turning. Squirming over white lines.
moppy
PostPosted: 19:30 - 16 Sep 2012    Post subject: Reply with quote
Aside from feeling like you're falling in, is it actually dangerous to use squared off tyres? As in, do you suffer any loss in grip due to the profile?
Handsome
PostPosted: 19:34 - 16 Sep 2012    Post subject: Reply with quote
I never noticed any adverse effects, but like I said above, I took it on a good run with varying degrees of lean and speed to scrub it off, just feel funny as you lean then tip over the profile, once you get used to that feeling you're ok, just don't go mad on it...
CaNsA
PostPosted: 19:40 - 16 Sep 2012    Post subject: Reply with quote
When leaning with squared rubber your contact patch is greatly reduced until you pass the "lip".
Makes for interesting riding in the wet.
andi
PostPosted: 19:43 - 16 Sep 2012    Post subject: Reply with quote
loss of man points! Rolling Eyes Laughing
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
TaiChi This post is not being displayed because the poster is banned. Unhide this post / all posts.
WULFSTAN
PostPosted: 19:49 - 16 Sep 2012    Post subject: Reply with quote
its called doing near 800 motorway miles in the last few days
LordShaftesbu...
PostPosted: 20:28 - 16 Sep 2012    Post subject: Reply with quote
TaiChi wrote:
Riding mostly 'upright' & being a pussy in the corners, is not the cause of tyres squaring off !
No but it could be the result.
The last post was made 13 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.97 - MySQL Queries: 13 - Page Size: 100.28 Kb
